Question about RCA HD56W58 56" TV
Service Menu RCA HD56W58 56" TV
Does anyone Know how to enter the service menu on the Set?
Model # HD56W58 Chassis # ATC321 I have tried numerous ways that I know oh.. Power set off hold down channel down vol down....etc... Does anyone know the correct way. Please help i need to perform an advanced convergence, and I cant becuase i cant access the service menu.
Thankyou, Josh
    Genius:
  • 1,665 Answers
Http://www.hdtvoice.com/voice/showthread.php?t=24248
go to http://www.thomsonnetwork.com
Click on "publications ordering" (in the list on the lefthand side of the homepage)
Click the box for service information. Enter the model number (or click the chassis button and enter the chassis number).
In the list of documents you can purchase for $40 ESIATC32X -- the service manual on CD for your set.
This disk will have the info you need.
If you do decide to purchase it (and I highly reccommend you do so), send me the alignment chapter and I would be happy to post it for others who have the same set on my homepage.
Posted on Jan 28, 2008
RCA 42 in Replaced the 42RE010C878LNA0-A1 Board now a good picture but upside down how do I fix it
from remote press menu and highlight contrast enter code 1950 and see the service menu comes up. if not try 9735 same way.and change product id in service menu. try different .ids. each time you change id unplug tv and plug in .see if picture change.or do same process each time until show good.
Jan 19, 2015 | RCA 42la45rq 42-inch 720p lcd tv
How to enter service mode for WS73615 tv
Model is a v-25 chassis which has 3 hidden menus:
Done with the original remote: Menu 2470 enter is option menu (hard reset etc.)
Menu 2457 enter is circuit adjust menu
Menu 2459 is convergence adjust menu
be rather careful in the circuit adjust menu and write down settings before adjusting there
Oct 29, 2012 | Mitsubishi WS-73615 73" TV
Mitsubishi VS-50803 Big Screen TV - Trying to hook up an HDTV cable box, I was told to hit: menu, 1, 3, 7, 0 - to get to the service menu and switch DTV over to HD and that would solve my no signal...
First please confirm actual model number on rear of set.
Something is not right here, I am looking at Mitsubishi material downloaded in my computer; shows all codes for sets up to 2004. VS-50803 is a VZ6 Chassis made in 1998 and I doubt it is HD set, if it is one of the early ones it will have beneath the HD input vert sync and Horz sync---those required a special box from Mitsubishi etc.
Set has 3 hidden menus:
1. Option menu (for hard reset)= Menu 1,3,7,0 enter
2. Circuit adjust menu= Menu 2,3,5,7 enter
3. Convergence adjust menu= Menu, 2,3,5,9,enter (#4,5,6 on remote then change modes)
Does the DTV input have the two vert, horz jacks as well?
First is the Option menu is really only for a hard reset of the entire set, if you engaged it you may have de-converged the set.
The adjust menu is for height, width etc
The convergence menu is for convergence.
If you did something and did not save it, unplugging set should put it back to before what you did.
In the OPTION MENU WHAT DID YOU SELECT AND DID YOU HIT ENTER WHEN YOU FINISHED?
STEVE
Oct 08, 2011 | Televison & Video
Is there anyway to hard reset a Model 27v412t?
There is no way to hard reset this chassis TV. All of the settings are stored in an EEPROM chip that is programmed at the factory. There is a service menu to change these values but only some can be changed. The only options that can be changed on this model are CRT screen voltages and yolk alignments.
The only real way to completely reset the this TV is to replace the EEPROM with a new one, it would then have to be realigned and calibrated using the service menu with at least a Volt Meter.
This model chassis is plagued by many problems, usually with IC 301 which is your screen vertical control, it can cause lots of problems. The most common problem is a random shutdown of the set. Sometimes the board just needs to be soldered in that area.
If it's a parental code that needs to be cleared, this can be accomplished by pressing the Volume + button on the remote and the Channel + button on the front of the TV set. This will display the parental code. You will need the Original Remote to do any programming of this TV.
Jul 18, 2011 | RCA Televison & Video
I installed a new color wheel in my RCA 50inch DLP TV but now the facial tones are now purple. I believe I need to somehow index the wheel using a service menu but do not know how to access it. The TV...
This might help ,the Fix for Pink Picture on another Set was to replace the Formator Board and the DVI Cable .
Formator Board PN# 263247
DVI Cable PN# 263254
The way to Enter Service Menu for most RCA is to turn TV off, Then Press and Hold at same Time
CH- and Vol- wait untill TV turns on then release and Service Menu should come up.
Encompass Parts Distribution 1-800-638-3328 they might have the Parts you need.
Jan 14, 2011 | RCA HD50LPW42 50" Rear Projection HDTV
Sanyo mode...
Hello
You just try one the procedure given below. One amoung will lead you to its service mode.
Unplug the power cable.
* Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
* Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
* Use the {CH+} {CH-} buttons to select menus.
* Use the {VOL+} {VOL -} buttons to change settings.
* Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
* Press the {MENU} button or turn the TV off to exit.
* Press and hold the {VOL -} button on the TV
* Keep pressing the {VOL -} button until
Dec 16, 2010 | Televison & Video
RCA d52w26 Field service menu
RCA > HD52W66
itc222a chassis
Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec.
http://home.austin.rr.com/doctorjoe/ITC222align.pdf
Oct 03, 2008 | RCA HD52W59 HDTV Projection Television
Insufficient width
You can goto www.wa6ati.com and search for your model and it may tell you.
Dec 06, 2007 | RCA P61310 TV
Geometry settings all wrong
I wish I could help you but you will more than likely have to take your set to an authorized service center. Philips doesn't like to send service manuals to anyone except their service centers. Stargazer
Feb 20, 2007 | Philips Magnavox 32PS55S 32" TV
RCA HD56W58 56" TV Logo
783 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
