Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
Picture quality I have had the tv for three picture has shadows/blurry on it. Cable direct to TV does the same thought it was cable box at first.It is a couple months out of warranty. Any suggestions? Maureen
  • Avonlea405 Jan 28, 2008
    I dont plan to buy another plasma tv. does your solution include the screen is fine and then it is the whole screen with the blurriness is that a word and it flashes then goes back to being fine..Thanks
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Hello - it's called burn-in and is a common problem with Plasma TVs. It happens around the 3 year mark. Later models from Hitachi have a white-wash option which can wipe the screen free from blurred marks etc. Have a look in your manual to see if this feature is available in your TV. If not, and you have a video camera, you can replicate the effect by filming a white sky or something similarly bright and white, then playing it through your TV and pausing the plainest, whitest shot you have. You'll need to keep this showing for around 24 hours. It's important that it is completely white, as if any of the film has a dark dot or mark, this will add to your burn-in problem. It's a bit of a long work-around, but it does work. Bear in mind that as your screen ages the problem will return at some stage. LCD displays don't suffer from this problem so that's something to bear in mind when the time comes to replace your TV. I hope that helps :o)
Posted on Jan 28, 2008
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
Hi My LG 52LB9DF tv is slightly blurry - I'm not sure if it's the size or quality of the tv? Even the HD channels are slightly pixellated. My friend has a smaller tv with a much sharper resolution....
1. Your TV has a digital tuner built-in, you do not need a set-top box to receive local digital channels.
2. Try to disconnect the box, hook up the antenna directly to the TV antenna input & program the tuner, you may getting better picture.
Aug 29, 2017 | LG 52LB9DF LCD TV
New flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Jan 05, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
Insignia 42 LCD TV Blurry Picture. Computer
tuner is going bad use a cable box that has hdmi or component video to bypass the tvx tuner
Jul 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Turn on your projection TV and wiggle the coax cable from your cable box or antenna where it connects to the TV. If the picture fluctuates, you know that you have a loose connection, or that the coax cable is bad.
Jun 10, 2009 | Televison & Video
Shaky Picture only during Advertisement or... Mitsubishi SC 27403
If you have cable then put the cable wire directly in the TV, bypassing the cable box. If the pix is Ok it proves that the problem is the cable box. If the problem is still there then it proves the the TV needs parts inside.
Mar 24, 2008 | Televison & Video
42" pansonic plasma hdmi problem
if I understand your question properly.. its because your direct tv output doesnt broadcast in high def so its giving you the standard tv definition inputs which are RGB or you will lose picture quality cos its running at fewer lines or pixels. hope this helps
Mar 12, 2008 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Ghosts on my tv
if you can, try hooking up the tv to a different cable line in the house or bring a different tv into the room where the bad picture is [ you may have a bad connection or wire ] if this doesn't help, try rabbit ear antennas just to get a picture. if you still have ghosts on your tv, the problem is with your tv.if the picture is fine, there maybe a problem with your cable service.
hope this helps
Feb 10, 2008 | JVC AV-56WP74 56" Rear Projection...
Ghosting and popping noises
slag, Has the cable signal been branched off to another TV (or more) from the same feed? Ghosting and shadows are usually the result of bad impedance matches on those lines. Try connecting the prime TV directly to the cable box (or cable jack) output and note if there is any improvement. Make sure the cable itself is of the RG-6 type (not RG-59) and has no sharp bends or kinks. The center pin of the cable should be clean without corrosion. The RF IN jack on the TV should be checked to make sure the threads for the connector are clean and the plug should be attached firmly but not too tight. These steps should help solve this at least assuming the cable signal is good. [Checking it shows the "level" coming off the pole, not necessarily the quality of that level.] Hope this helps.
Oct 31, 2006 | Toshiba 34HF83 34" TV
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
172 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
