Question about Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard
I had a problem my pc
I have just put a new powersupply but now the know electricity signal to my pc
    Sergeant:
  • 201 Answers
Hey there biggy100, I suggest you start by completely disconnecting and removing the power supply. Now reinstall it taking care to ensure it is plugged in to all required ports. The connections for the front power panel and led can be confusing, if you misread the motherboard manual, or are missing it. This manual can really help guide you through the installation, so getting one could be a very useful step. also ensure you are connected to all power connectors on the board. One will be 20 or 24 pins and the other will be 4pins. Beyond this, the power supply unit is in serious question. Another big question is as to why you are changing the power supply. If it is to correct another problem, then your problems may be more serious. Good Luck!
Posted on Jan 28, 2008
  • 53 Answers
1.If u have ups ,first u disconnect it and system  directly connected to mainboard.
2.Even it is not powering on first u check the powerswitch means in frontpannel connections
on motherboard u short the powerpins then check it
 If u have some idea about the hardware u will do otherwise u dont touch the board
3.Eventhough it is not working, problem may with motherboard.
Regards.
My asus Eee pc1005HAC powersupply plug short circuited and causing my asus laptop i guess not to turn onn ?What is the volt. and name of the fuse/part that may be needed 2 replace Pls?
for now if you can find someone with the same laptop u can use its battery to check if your laptop will power up and if it doesn't then there might be a prob with ya motherboard.
Aug 27, 2012 | ASUS Computers & Internet
My Gateway GT5252 won't power up but after unplugging the P2 connector on the motherboard it does power alright. Does anyone know what P2 powers and/or have any suggestions? thanks, PCBob
the p2 connector is for monitoring purposes i believe in regards to the powersupply fan, it isnt a requirement to plug in, in this regard but if it boots fine with out the connector then the possibility is there that you might be looking at getting a new powersupply eventually.
Nov 16, 2009 | Gateway GT5252 PC Desktop
Two months old dead no power
Check the Power cable of your PC for any damaged or burn/cut. Firmly check the connection on the slot of the CPU Power Supply,
Check the Electrical outlet , or better plug the cord on a different electrical outlet.
If all of this has nothing to do and the problem was still there, possible problem on the powersupply are, it is advisable that you have to replace this part, a possible burnt or a short circuit has happen inside, due to some electrical malfunction on your area.
HOpe this helps.
Let me know for any clarification
Oct 08, 2009 | ASUS Computers & Internet
Errore codeoxe0000227
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button.
Try to boot the pc.
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker, put the powersupply in a different pc, or try a different powersupply in the problem computer.
Could be bad ram, motherboard, cpu, powersupply, videocard.
Jul 06, 2009 | ASUS P5P800-MX Motherboard
Flashing orange light on front of my dell 5150 desktop, will not turn on, even after unplugging for one hour. when plugged back in, flashes orange, no fan, no power. JK
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
Try to boot the pc.
Jul 05, 2009 | Dell Computers & Internet
Graphics upgrade needed
the computer has one PCI-Express slot (x16) which will take most of the latest video cards out there.
All you have to worry about if you buy a brand new card for it, in the 200-500 price range is does your computer have a good enough powersupply?
the computer comes with a 300W powersupply, which you might need to upgrade to w500 or more,
600W powersupply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171036
that one will go a long away, you should be able to keep the powersupply even if you decide to upgrade the cpu/memory and the motherboard, making it a brand new computer, the powersupply has enought juice to power it.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=ati+radeon+4830
theres a 512MB and 1024MB cards. look around for cheaper deals if you want a smaller card with less memory.
May 25, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Upgrading the power supply for new card evga 9800 gtx+
What kind of help do you need?
Open two screws in back of the computer case, take the side panel out, unscrew old power supply, disconnect the cables also, take the powersupply out, insert new powersupply, screw it in and connect the cables.
surely 500-800W will be enought.
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=58&name=Power-Supplies
Let me know if you need anything else.
Thanks and good luck.
Ekse
May 05, 2009 | HP Pavilion a1610n PC Desktop
Plugged my computer into a 220 outlet!
You burned the Power supply you don't need to switch motherboard out just knew power supply. And in the future there is a switch located on the back of them that will make them a 220v powersupply. But usually only a high end PC for gamers will need that so just put in a new powersupply and you should be good
May 03, 2009 | Logitech R-20 Computer Speakers
Only the cpu fan spins
I guess it's a powersupply issue. what wattage and amps on +12v is your powersupply?
Jun 10, 2008 | Biostar P4M80-M4 Motherboard
New video card keeps monitor blank
you have to reprogram your pc. or try changing the jumpersetting. disabling your onboard video display. hop this solves the problem.
Jan 10, 2008 | E-Machines W3052 PC Desktop
Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard Logo
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
