I suggest You Go to Official Xerox Printer Page For You Xerox Printer Problem On Below Xerox forum URL Link: Clearing Paper Jams In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Xerox Printer Support
Under rubber roller of the presenting the paper is located brake platform. Check as she works. This often can be that paper pulls not exactly. Follows to restore the brake platform. Good luck.
The paper pick up rollers have lost their grip and need replaced, but I wouldn't put that much expense into fixing it. That xerox is a sharp in disguise, although supplies are not interchangeable the parts are. Common repairs for that machine is the gear on the fixing roller will break, to pick up tires dry rot and the heat lamp will blow. For the expense to fix it can almost buy a new one with more features and cost less to operate. The xerox supplies are very expensive.
Just use the by pass until something else goes wrong.
Good luck
TRY TO CLEAN THE RUBBER ON FEEDING PAPER WITH A DRY CLEAN CLOTH AND DROP A SOME ALCOHOL IN CLOTH AND CHECK THE PAPER PATH IF HAVE SOME A LITTLE PAPER ON PATH PAPER...
ABOUT CATRIDGE...TRY TO REPLACE A NEW CATRIDGE.. DO THIS NECESSARY UR COPIER IS ON.
[email protected]
