Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
My hard drive is not working
I plug the Hard Drive into the computer, it seems to register that it is connected, because the fan starts to spin and the light goes on (the light only goes on when it is actually connected to the computer), but then everything stops, and even when I unplug it the light stays on... It is not registering on my computer or seeming to aknowledge that it is connected after the initial response...
What works?
  • Anonymous Feb 24, 2008
I need the setup exe file for the 320 gb drive
Posted on May 02, 2008
    Genius:
  • 1,226 Answers
is the system load the bios or nothing happen ? In this case the system not detected the memory maybe the memory lessen, fix it firmly and start the system again.
disregard the solution above if the harddrive is detected in the bios. there is a four connection in the IDE /PATA hard drive.
P master
P Slave
S Master
S Slave
if you connect or use one IDE cable in two connection, the other should be in slave. master is where the Operating system is.
try to verify the hard drive label for a master or a slave harddrive.
If this solution not solve, please notify me b4 u rate so that i can give you further solution. thanks!
Posted on Jan 28, 2008
  • Emelio Navaja
    Emelio Navaja Jan 29, 2008
    what happen? Did you try replacing the PSU .. some psu we don't know that there is shorted, you can test that by using the tester. If you can fix the PSU by your self maybe better but if the don't want risk then maybe u should replace the PSU.
    thanks may his help.
Spins but makes a beeping sound and wont register.
Well, It sounds like there is something lodged in your Hardware drive...The beeping is probably a warning signal to tell you that it is not properly booting up...You should go to a Computer Repairman...
Jul 11, 2013 | Seagate FreeAgent GoFlex Desk 1TB USB 3.0...
HD-PE250U2 had it for 3 years - very much loved and working last night. Computer will not recognise it this morning - but power and blue lights are on. Computer does not register the 'name' of
Either the hard drive went bad or the electronics of the enclosure went fubar. Suggest you remove HD and directly connect it to your desktop computer to see if the cmos recognizes it along with the OS. If so you can access your data. If not, the drive is ng - if the drive at least spins and is recognized you may be able to retrieve the contents using windows explorer. If unit will not spin you are in deep doo doo.
Do not format - that will erase everything - try to access the data.
Sep 03, 2017 | Buffalo Technology (HD-PE250U2/BK) 250 GB...
I have a computer that would do nothing when turned on, including giving no beep codes. Everything seems to be getting power - the CD drive, CPU fan, and hard drive all start spinning. I disconnected...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Dec 05, 2010 | Acer Computers & Internet
MY HARD DISK SV4002H 40 GB IS NOT DETECTED BY THE SYSTEM AND I NEED THE DATAS. WHAT IS TO BE DONE
If the computer cannot boot up then to retrieve your data then remove the hard drive from the computer and connect it to an USB hard drive adapter. Then plug the adapter into a working computer's USB port. This computer will detect this as an external storage device. You can then click on this device and open the folders and files to copy and backup your data files.
Nov 10, 2010 | Samsung (SP0822N) 80 GB Hard Drive
My 120 Hitachi hard drive is not detecting any more
All I can think of is to completely remove all ya USB layer, via Device manager, uninstall & remove drivers on everything USB, then reboot, and then after try to plug ya drive in again BUT after it finishes re-installing the USB layer give it 5 mins or so...then do so. GL
Jan 26, 2010 | Computers & Internet
Drive is a blinking brick of garbage.
Is the hard drive a USB external device?
Does the hard drive spin up at all or does it make clicking sounds?
If the hard drive spins it may not be faulty, it may be a faulty USB hard drive adapter case.
Put the hard drive in another USB hard drive adapter and connect it to a computer, if it still doesn't work then the hard drive has died.
Jul 24, 2009 | Seagate Free Agent Go Small 12 GB USB...
I think the hard drive crashed.
Dude, check when you start your PC if the fan spin, if not, the problem isn't your HDD could be your motherboard or your power supply.
Mar 29, 2009 | Western Digital Caviar SE 80 GB Hard Drive
Western Digital hard drive problem
Ok.  I have a WD 500 and I have ran into similar problems.  First, shut your computer down.  Unplug the hard drives USB cable and the power cable.  Wait for about 2 minutes.  Plug the USB cable into the computer, plug the power cord in...wait for 30-45 seconds and then start your computer.  That hopefully should solve your issues.
Mar 01, 2009 | Western Digital My Book Essential Edition...
500 gB doesn't respond to anything!
Leave it unplugged for a minute or so and see if it boots up.
Check the Power supply if it still works.
Aug 21, 2008 | Western Digital 500GB My Book World...
Computer powers off during boot
Hmmm...try resetting CMOS & checking all external peripheral connections: (KB/mouse, monitor, etc.)
Oct 26, 2007 | ASUS A8N-E Motherboard
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
335 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
