Question about Jeep 10 x 20
1992 jeep cherokee
Yes I have a 1992 jeep cherokee and when i drive it it will drive but it won't want to like go the speed limit the guy i bought it off from said it might be the transmission filter if you could get back to me it be wonderful
You gotta be specific. coulda be fouled plugs, tranny, coil.
Posted on Mar 22, 2008
I have a 1992 jeep cherokee 2dr 4.0 H/O 5spd. that lost most pressure in the clutch
It sounds as though the seals in the master cylinder have perished and aren't doing their job. The reservoir is full, yes .. but the fluid isn't getting pumped because of worn seals... there's no pressure developing.
If there are overhaul kits available - try one. They're much cheaper than buying a new clutch master cylinder. It isn't a difficult job.
0results for 1992 jeep cherokee clutch master cylinder repair
Mar 15, 2017 | 1992 Jeep Cherokee Sport
1992 jeep cherokee starter will not turn off
sounds like soleniod.pull starter & bench test it.lets hope ignition switch is OK.
Dec 16, 2017 | 1992 Jeep Cherokee Limited
My 1990 Jeep Cherokee Limited idle speed fluctuates up and down..when I am driving at cruising speed the car begins to shake. When I am driving on the freeway above 55mph the car shakes constantly. I...
hey there, artismo here! I have a similar problem with the idle fluctuating, and the trans down shifting itself at light throttle, which is the lock-up in the converter getting the wrong signal ? from the ECM.
Aug 12, 2010 | 1990 Jeep Cherokee Limited
Clunking sound in 4 wheel drive
Could also be a jammed transfer case linkage.. I had the same problem and it was the linkage getting jammed up and not pushing all the way and only half catching the sprocket. $10 part *crosses fingers*
Jul 04, 2009 | 1992 Jeep Cherokee Limited
2006 Jeep Grand Cherokee Laredo ac not cooling
My 1999 limited does this. When i bought it off the guy he said that its because of some flap down by the passengers left foot. In mine the passenger air barely even blows because of this.
Jun 17, 2009 | 1999 Jeep Grand Cherokee
Shuttering at highway speeds
well the kickdown cable out of adjust ment would only screw up your shifting timing and when the vehicle downshifts when you press the accelerator hard. usually a shudder at cruise speeds 40 mph or higher indicates a torque converter problem or the govenor pressure solenoid and sensor. i personally would start by replaceing the sensor and solenoid and install a new filter
Jan 05, 2009 | 1997 Jeep Grand Cherokee
92 Jeep Cherokee Laredo odometer broke
I have the same problem on my 1992 cherokee...it's the vehicle speed sensor...it's located at the transmission/transfer case.....
Oct 30, 2008 | 1992 Jeep Cherokee Sport
1992 jeep cherokee limited fuel pump problems
have u flushed tank,try a different brand fuel pump remember u cant buy any thing worth a **** anymore
Jul 09, 2008 | 1992 Jeep Cherokee Briarwood
Jeep 10 x 20 Logo
74 people viewed this question
Top Jeep Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
Are you a Jeep Optic Expert? Answer questions, earn points and help others
