Question about Carrier 38CKC042 Air Conditioner
Unit/control panel completely dead
We have a Carrier Comfort Zone ducted air conditioner it has been working fine when about 2hrs ago it was noticed the house was getting warn. When went to check vents No cool air, went to check control panel and it was completely dead. Please help......Thanks Nikii & Pete
  • zombi8 Jan 29, 2008
    Dear bobotfel, Pete checked the breaker and said everything was ok but I will try you advise when I get home. Hopefully it is only a blown fuse in the control panel and nothing to expensive. Thanks for your help..
  • l. keightley Sep 08, 2013
    is ther a reset button and where is it
  • 236 Answers
Check your circuit breaker, "off" and "on" the breaker it my be tripped off. If it wont work may be some fuse blown in the control, or the control itself may be defective.
Posted on Jan 28, 2008
Zone control
reset the zone system and see if it still flashes
May 23, 2014 | Fujitsu Heating & Cooling
The Carrier comfort zone thermostst displays the
Go to panal and reset control. Small reset button on control board. Let me know if it clears.James
Oct 12, 2009 | Carrier 38CKC042 Air Conditioner
Comfort control center not working properly
You need to check the cable that connects the Comfort Control to the upper unit. This cable has four wires and should have continuity through all wires. If there is a break in one of the wires or a short, it will cause the CCC to fail and report an error. If all this is fine, then you have a bad control unit in the main unit. Try unplugging the rear unit from the control board and then resetting the Tstat, if this works, then there is a communication problem between the front AC control board and the rear AC control board or the rear control board is bad. Check the cable between the front and rear AC for OK. If it is alright, then you have a bad control unit in the front unit.
Another quick check is to remove the inner shroud from the front unit pull down the control box. Remove the access cover and view the dip switch panel located inside. It should be labeled Zone 1 Zone 2 etc...try turning off Zone 2 and furnace and resetting the tstat. If this works then turn zone 2 on and reset the tstat. If this is ok, then turn the furnace on and reset again. If this works, then all should be ok. If one of these fails, then you can pinpoint the problem there and move forward.
Hope this helps,
Jeff
Rate me please!!!
Jul 04, 2009 | Dometic Rooftop RV Air Conditioner
Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
Jul 01, 2009 | Carrier 38CKC042 Air Conditioner
Carrier Comfort zone 2 is flashing e1 after a storm/power outage
HEY THERE, DID YOU TRY POER CYCLING THE UNIT? TURN IT OFF AT THE BREAKER THEN BACK ON
SETH
Jun 27, 2009 | Carrier 38CKC060 Air Conditioner
I get the error code E2 It only shows 2 zones on my 4 zone syst
I reset the circuit breaker to the panel and everything is good now.
Jun 24, 2009 | Carrier 38CKC060 Air Conditioner
Failure in comfort zone one
There is a capacitor connected to the motor on the compressor. If it fails, the motor won't start and the safety thermal cutoff will stop voltage at the motor terminals. There are fuses inside the power interrupt box on the side of the outside unit. One of them may have blown
May 09, 2017 | Amana Comfort Zone 18M33PCEH Air...
Carrier 38TXA030 not working
That sounds like a very efficient system Gratz. You can try a reset by throwing the breakers off and back on and check all your micro fuses on boards and zone controllers. GL!
Jun 11, 2008 | Heating & Cooling
Carrier 38CKC042 Air Conditioner Logo
274 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
