Question about HP Easy Refill Kit for (HP) Black Inkjet Cartridges Printer
Hp 57 tri colour cartridge refill
Hi I have the ink but have lost the instructions, can anyone tell me whitch colour to put in what hole?
michelle
Wrap the tip of a straight pin with a little cotton and stick in the hole do this for each hole with new cotton each time of course.
Posted on Oct 28, 2008
Had refill at Costco for hp 4620 printer 564 cartridge and now printer will not print in color. What do I do to make it print?u
That's means you didn't refill the colour ink properly.
Try this method, use the injection to draw any of the colour of about 2mm of the refill you bought, inject it into one of the tiny holes of the cartridge and draw a little back so as to remove the dirt in the foam inside the cartridge.. That's all
Aug 09, 2014 | HP Office Equipment & Supplies
Tip
How to Refill Hewlett Packard, HP Cartridges
Works With 21,22,27,28,56,57,58,74,75,60b,60c,92,93,94,95,96,97,98,99,100,901b,901c
To refill a HP Cartridge the cartridge must be directly from the printer, not one that has been out for two weeks or more as it might not work.
Full Printable instructions with pictures are Downloadable from here for free.http://www.ziddu.com/download/15223497/HPCartridgeRefillInstructions.pdf.html
  1. To Start simply remove the label from the top of the cartridge.There a five holes on the top of the cartridge (see image in download)
  2. Using your 10ml syringe and 19 gauge tip inject the correct colour into the correct hole.
  3. When the ink is visible in the top, withdraw approx .25ml of ink out to ensure you have not over-saturated the sponge.
  4. Repeat for each colour, For black cartridges simply fill it from the top hole.
  5. let it sit for 5 Mins to ensure there are no leaks and replace in the printer.
This method will save you plenty of money and if done correctly the cartridge can last 10 plus refills.
Happy Printing
RegardsGM
on Jun 03, 2011 | Office Equipment & Supplies
HOW CAN I REFILL HP 802 TRI COLOUR CARTRIDGES WHICH COLOUR IN WHICH HOLE
Hello, be careful, because all recent hp cartridges have a chip which even though you've refilled the cartridge, the chip 'tells' the printer logic that it's empty. And it's not possible to reset the chip if it's a genuine hp cartridge. You can buy a chip resetter tool but they only work on non-genuine hp cartridges. That's not all though,;in order to refill the hp cartridges successfully you need a vacuum filler, and it's nigh-on impossible to do it at home. If you want to save money and not end up with nasty ink everywhere, buy a cheap copy of a hp cartridge. I know they're available on Amazon, but the place I can recommend is inkrite (I'm assuming you're in the UK due to your spelling of colour) This isn't an ad for them; I personally used their products and have done for years. www.inkrite.com
Regards, nicam49
Jun 16, 2011 | Office Equipment & Supplies
How to refill ink in hp blck cartridge
  • Purchase an ink refill kit at an office supply store. (Staples, Walmart, and Costco all carry this inexpensive kit. It usually costs about half the price of an average printer cartridge.)
  • Gather your kit, a roll of paper towels, and some clear scotch tape together on a large flat working surface, a table or desk.
  • 3Remove the empty cartridge from your printer. (Remember to close your printer lid or door while you are working.)
  • 4Cover your hands with a pair of disposable plastic gloves while you work with the messy ink.
  • 5Take a paper towel and fold it in half twice. Work over the paper towel to catch any leaking ink.
  • 6Place the empty cartridge on it.
  • 7Read the instruction manual included with the refill kit to learn how to refill your particular type of cartridge. (The following instructions are just a general guide).
  • 8Locate the fill holes on the top of the cartridge. The depressions can be felt by rubbing your finger across the label.
  • 9Use a sharp pencil to pierce the refill holes in the top of the ink cartridge. (Correct places can also be found in the kit instructions).
  • 10In addition to black, there are three colors of ink: magenta, cyan, and yellow. Follow the kit instructions on which hole to insert each color OR push a toothpick into the holes to identify the colours as markings on the printer cartridge are sometimes there to fool you into putting the wrong colours into the cartridge ink chambers.
  • 11Insert the long needle on the refill ink bottle into the correct hole.
  • 12Slowly, add the ink. Carefully watch to be sure that you do not over-fill.
  • 13Stop quickly as soon as you see a bit of ink oozing out of the hole. Without letting go of the bottle, slowly release the air, sucking a little ink back out of the ink cartridge, before you remove the needle completely.
  • 14Carefully daub the cartridge contacts on the paper towel, you should see a splotch of the ink leaking out onto the paper towel.
  • 15Cover the hole with a small piece of clear scotch tape. (This works better than the seal dots included in the kit.) Make sure that no ink is leaking out of the top holes. (That's where the clear tape comes in handy.) Be careful not to cross contaminate the colors.
  • 16Repeat steps 11-15 for each ink color.
  • 17After you have refilled all three colors, carefully blot (don't wipe or rub) the cartridge printhead on a folded piece of paper towel. You may need to do this several times. Do this until it stops bleeding and you see an even stripe of three colors showing up on the towel.
  • 18If the blot shows the colors either faded or not at all, blot on wet paper towel and again on dry, to get the ink flowing.
  • 19Replace the ink cartridge into the printer. Never, ever install a leaking print cartridge.
  • 20Immediately print something, anything, just to get the ink flowing. Print several test pages, preferable photos with a lot of different colors.
  • 21Follow the cleaning or priming cycles for your specific printer.
  • May 25, 2010 | Office Equipment & Supplies
    Do I need to mix 2ml of each colour in siringe and mix
    HI,
    Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
    thank you,
    vijay (vote for me)
    Sep 24, 2009 | Canon Office Equipment & Supplies
    How to refill hp 818 inkjet cartridge
    on 818 hp cartridge five holes are there, which colour ink on which hole i have to put ink on them
    Dec 03, 2008 | HP DeskJet F380 All-In-One Printer
    Refilling HP 56 Cartridge
    USING THIS TYPE OF REFILLS JUST ISN'T A GOOD IDEA. THE INK IS NOT THE SAME AS HP CARTRIDGE INK AND YOUR PRINTER WAS MADE FOR HP INK, NOT SOME GENERIC BRAND. THE FACT THAT IT DOESN'T WORK UNLESS YOU STICK IT IN WATER, ETC. SHOULD TELL YOU SOMETHING IS WRONG HERE. REFILLING IS MESSY, AND CAN CAUSE LEAKS IN YOUR PRINTER AND REALLY MESS THINGS UP. THE BEST BET IS TO USE THE PROPER INK CARTRIDGE WITH YOUR PRINTER. THATS THE TYPE OF INK IT WAS DESIGNED FOR.
    ARCLIGHT1217
    Jun 05, 2008 | HP PSC 1110 All-In-One Thermal Printer
    I want to refill the ink cartridges (black 30 - colour31) myself....how do I do it?
    Filling is easy - but messy. I use No 40 cartridges for my pixma ip2200.
    For the black cartridge, carefully remove the label. Drill a 2-3mm dia. hole in the depression in the top. With a syringe fill, using about 10ml of black ink. Plug the hole with a suitable bung and away you go!
    You will however lose the ink level indication as it is not a genuine cartridge - but that is unreliable anyway.
    Don't refill more than a couple of times as the foam inside the case eventually perishes and all the ink runs out.
    Whilst the cartridge is out of the printer give the jets a wipe with a wet tissue. This is usually quite effective in removing dried on ink.
    You can do the same with 41 colour cartridges but it is a bit more tricky locating the correct place to drill.
    Good luck
    Apr 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
    HP 57 refill problem
    You are doing nothing wrong. The nozzles are clogged. Try taking a clean syringe and put your finger on one of the magenta (red) refill holes. Fill the syringe with air. Put it on the second magenta refill hole and blow the air inside. That should force out the ink that has dried and that is not letting the new ink come out. You might have to do that several times. Sometimes, it can help.
    If that doesn't work, go to a refill shop, they should be able to clean the print nozzles on your cartridge, no need to buy new ones.
    Feb 12, 2008 | HP Easy Refill Kit for (HP) Black Inkjet...
    Canon all in one printer refill ink cartridges
    i have just filled my mx 310 with the jet tec refills as instructed....but do not insert the rubber bungs...instead put some celotape over the filling holes... then with a needle...pierce the celotape where the hole is( pin *****).... this set up is now able to breathe as originally designrd. Mine prints fine now this has been done (trial and error), but i might try better quality ink next fill. Its also wise to use glossy paper 230gsm or over for good results.
    GOOD LUCK.
    Dec 20, 2007 | Office Equipment & Supplies
    HP Easy Refill Kit for (HP) Black Inkjet Cartridges Printer Logo
    79 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
