Question about Lexmark X2470 All-In-One InkJet Printer
Cartridge i have installed a in a new cartridge but it give me the error to install the correct cartridge
I have installed a in a new cartridge but it give me the error to install the correct cartridge
Posted on Apr 30, 2008
    Genius:
  • 3,587 Answers
We have a link on how to fix your own printer through this link(check for search box further down page)
Posted on Mar 20, 2008
Brand new lexmark original cartridge is not recognised. error report' no cartridge'. all contacts cleaned machine dismantled and cleaned and reassembled. has done this before on occasion with refilled...
1. Open the top front cover of the printer. If the display DOES NOT read Close cover or Insert cartridge, the 32 error is not caused by the toner cartridge and printer service will be required to fix the problem.
2. Make sure the correct toner cartridge is installed for this printer model.
1. Check Lexmark for a list of compatible cartridges for your printer.
2. If the wrong toner cartridge is installed, remove it and install the correct one.
3. If the correct toner cartridge is installed, it may not be seated correctly. To ensure that this is not the cause of the error, do the following:
1. Turn off the printer.
2. Reseat the toner cartridge.
3. Close the lid.
4. Power the printer back on and check the display.
4. If reseating the toner cartridge does not clear the error message and the error started as soon as you installed this particular toner cartridge, the cartridge may be broken. You can check this as follows:
1. Power off the printer and then reinstall the old cartridge. (You can also try a different new cartridge to see if that clears the error.)
2. If the error does disappear, the problem may lie with this cartridge. Please contact the point of purchase, especially if the cartridge is brand new out of the box.
5. If the error cannot be cleared by putting in a new toner cartridge or one that is known to be working, the printer may require service to fix the problem.
May 02, 2011 | Lexmark X2350 All-In-One InkJet Printer
Lexmark c534dn unsupported cartrige
This error message appears on the printer screen when the printer thinks the wrong toner cartridge is installed. To clear it or identify a service requirement, follow the steps below. NOTE: If you succeed in resolving the problem at any stage during the procedure, you not need to perform the remaining steps.
    3. Close the lid.
Feb 15, 2011 | Lexmark C534dn Laser Printer
New Cartrdige detection problem
I can't think of anything other than the obvious which is probably not of any use. Please make sure that you have the correct cartridge and that you have removed any tape or covering from the cartridge. Try turning the printer off and on after you put in the new cartridge. These are pretty simple but there are all I can think of. Good luck!
Mar 11, 2010 | Epson Stylus CX5400 All-In-One InkJet...
Installed new cartridges in Canon i850 and printer seems as though it is printing but does not grab the paper from paper feeder and gives an error (no number). Instructs me to press REsume button and power...
I changed the USB port that the printer was connected to and... VOILA...works like a charm with the new cartridges installed. Not sure what the problem was as windows recognized the printer and the drivers were correctly installed before the new cartridges even came into the picture.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
New cartridge, says cartridge error
1. Try removing the cartridge and unplug units a/c power.
2. Find a damp cloth and wipe the output ports on the bottom on cartridge. .
3. With a Q-tip, go over the round copper pumps on the cartridge tray. ( Where the cartridge makes contacts. )
4. Close door and power up unit.
Unit will give you a error message cartridge not installed.
5. Install the new cartridge.
Close door and fallow any additional instructions given.
( A ) If this does not resolve your problem, re-install old cartridge and see if you get the same error message. If you do not, replace the new cartridge.
Hope this has resolved your problems.
Please rate your techs.
Oct 06, 2009 | HP Officejet J3680 Multifunction Printer...
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
Problem with printing
CRU Fuse Error The toner cartridge is
not installed correctly.
Install the toner cartridge
correctly. See “Replacing the
Toner Cartridge” on page 8.4.
www.zinetic.o.uk
Sep 04, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Lexmark X2470 All-In-One InkJet Printer Logo
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
