Question about LG 50PX1D 50 in. Plasma Television
Only input that works is HDMI, everything else is black with no sound...
The AV, Co-ax, Composite inputs all do not work. The TV does not recognize anything in the input when I plug stuff into those inputs, and the screen in black with no sound when I manually select those inputs in the menu. However the HDMI works fine. Sometimes I will turn on the TV and those inputs will work, but not usually. The repair people for circuit city have come to fix it twice and even replaced the motherbard of the tv, then it worked for 2 days before stopping working again. is anyone having this problem?
  • ethanelash Jan 29, 2008
    Thnx for the tip, goodthing I have the warranty so they can give me another board for free with installation =)
  • 106 Answers
Try to replace the Main Board one more time.
Posted on Jan 28, 2008
Can I attach a HDMI cable to an Old Samsung TV Model # HLN5065W1X/XAA
Gina, these are all the inputs on your TV
S-Video 4-pin DIN (2 sets) Back Composite RCA (2 sets) Back Component 3 RCAs Back Component (HDTV) 3 RCAs (2 sets) Back RGB 15-Pin Dsub Back Tuner Co-ax (2 sets) Back DVI Digital Input 24 pin DVI Back S-Video 4-pin DIN Front Composite RCA Front
You can not use HDMI cable with this set up.
Feb 22, 2016 | Samsung Televison & Video
Playstation 3 works fine useing the av hook up but won;t work with hdmi cable hook up.
First, make sure your TV is on the appropriate input for the plugged in HDMI cable. Once this is completed, turn your ps3 on. If the screen comes on and is black, turn the ps3 to standby (red light is on) and hold the front power button until the console beeps a second time. This will usually force the ps3 to recognize the hdmi input and will bring up the menu to configure the AV settings.
Aug 13, 2014 | Sony Playstation 3 (PS3) Console
Want Connect to My Laptop HDMI Output
If your TV has no HDMI input to connect with your laptop's HDMI output, surely you need a converter. If the laptop have A/V output, and the TV too have an A/V input, you can connect in between, using an AV cord.
Nov 25, 2013 | Daewoo DTQ-27U1SC TV
How to tune in for blu ray dvd
You do not tune in your Bluray player but connect using an HDMI cable or Composite cable. If you have a HDMI cable connect the Bluray's HDMI out to the TV's HDMI in at the back and using the TV's remote switch the Input source to HDMI. You will see the image from the Bluray player in high definition.
If you don not have a HDMI cable connect the composite out of the Bluray player using the Yellow/Red/White cable to the TV's composite input ( same three color sockets ) and switch to AV input on the TV. Using this connection won't give you high definition image but will work OK.
Apr 23, 2011 | Sanyo DP32746 32 in. LCD Television
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My samsung lcd tv will only show me black and white when i plug my wii in component 2, how do i make it go back to color?
Your problem may be that you need to select the "AV" input on the HDTV. Samsung HDTVs of late combine the composite video with the green input component video. To use the yellow composite video in the green input port you have to select the proper AV input on the TV which tells the TV to go composite video (yellow) instead of component video (green). Try this, it may work.
Aug 13, 2010 | Samsung LN46A650 46 in. LCD HDTV
I wanted to connect hp dv 4 1275 laptop with sanyo tv with hdmi and 3 rca .but its not working .tried everything din work.
You MUST install HDM IDrivers for your Video Card & MotherBoard. You can only use HDMI, OR Component, but NOT BOTH. Sometimes HDMI, requires an AUDIO OUT Cable, this is the Red & White, AV Stereo input.
OR you use COMPOSITE which is YELLOW, Video, now AUDIO, is Red & White.
COMPONENT, you use, Red, Blue, Green, (ALL VIDEO) PLUS you need the Stereo AV AUDIO too, Red & White.
HDMI, should supply BOTH, but as related sometimes you need the Audio red & White AV, inputs & Outputs.
ALL Cables go color to color.
Resolving issues,with HDMI. above.
DRIVERS link above.
Apr 11, 2010 | Computers & Internet
I have a tv sky box in lounge and 2nd tv in a different room connected by a co ax cable. I need a desription or a diagram to get everything working. It worked prior to having a new carpet fitted and the...
Check first that the Co-Ax cable is firmly plugged into your SKY box in your lounge.
(I'm assuming that the carpet fitters did NOT put a nail thru your co-ax cable or pushed the cable onto any metal carpet grippers???)
If they might have done this accidentally, then, that's why it doesn't work!
Then make sure that the co-ax cable is plugged firmly into your second TV. Sometimes the central connector within the co-axial socket becomes loose and needs nipping back together with a pair of long-nosed pliers.
I'm assuming that you have plugged the Infra-red remote eye unit back into the second TV aerial socket - before you plugged the co-ax cable back in?
If you have, press the SKY remote to see if the Infra-red LED can be seen in the remote pod.
Finally, make sure that you have selected the correct channel number (or Input) on your second TV remote to select SKY.
Nov 18, 2009 | Televison & Video
Need some sound to my home theatre system
Just 2feb827.jpgrun red and white composite audio cables from the audio out ports above the AVin1 ports on the back of the tv to one of the audio input ports on the home theater system, remember which input port you connected it to and when you want to watch tv with the home theater sound just switch to that input on the home theater system.
Feb 04, 2009 | LG 42LG50 42 in. LCD HDTV
LG 50PX1D 50 in. Plasma Television Logo
181 people viewed this question
Computer Repairing
Computer Repairing
