FixYa.com
Tags:
Kitchen Cooktops
Generic problem for all Kitchen Cooktops
Kenmore Radiant Ele Cooktop (by 2 users)
posted by jpjames on Jan 28, 2008
Cooktop elements do not turn off after they heat up, it's like a thermostat or sensor fails to detect when they are full hot. What needs to be repaired? Three of the four elements are this way now.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Feb 10, 2008
I now have two elements on our GE Profile Electric Cooktop that will occasionally fail to cycle (they stay continuously on unless the control is turned off). Shutting them off and then back on will usually get them to start to cycle again but will fail again at some point in the future at random. Totally unsafe. What parts should I be checking and how?
Best Solution
posted on Jan 28, 2008
Helpful (85)
ranger25
Rank:Wiz Wiz
Rating: 83%, 47 votes
They have a thermal overload resistor in the burner itself and they have a propensity to burn out, making it either all off or on, or it could be the infinite switch. I would check the resistor first. All the way cool you should get close to no resistance. Heat it up with a blow dryer and there should be more resistance. For the infinite switch, you will have to check resistance across the leads that correspond to each pinout as to what it goes to. You can find this out by backtracing the wire to each terminal on the block. Replacement of either part is the only option, there are no safe alternatives to repair them. Hope this helps. BTW, you can go here for parts.
www.appliancepartsdepot.com
Rating Locked! (?) jpjames has rated this solution as Helpful
This Problem Also Relates To: GE 30 in. Profile JP350 Electric Cooktop GE 30 in. JGP328 Gas Cooktop GE 30 in. JP326 Electric Cooktop GE 30 in. Profile JP938 Electric Cooktop GE 30 in. Profile JP989 Electric Cooktop GE 36 in. Monogram ZEU769 Electric Cooktop GE Monogram ZEU36 Electric Cooktop
Can you Help with these Kitchen Cooktops problems?
Jenn-Air JGD8130 Gas Cooktop
ignitor click and sparks, but...
My gas cooktop with 4 burners... Answer This...
Kitchen Cooktops
jenn air cook top
I broke the glass cok top on my... Answer This...
Thermador 37 in. SGSX365 Gas Cooktop
Ignitors Continue to Spark
The ignitors continue to spark... Answer This...
Zanussi 23 in. ZKT641H Electric Cooktop
Zanussi Ceramic hob ZKT641H...
Hello,...my prob is........ Answer This...
Kitchen Cooktops
Replacement cartridges for...
Our current Jenn-Air... Answer This...
Repair Service
Find Kitchen Cooktop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
