Question about Bose 3 2 1 GSX System
Bose PS321 No Sound
My Bose PS321 home Theater System has absolutely no sound. It worked fine, was disconnected to reconnect to different TV and had no power. I checked and replaced blown fuse inside power supply. I got it powered up, but then no sound. This unit had previously been connected to this same TV before without a problem. Checked the MOV and it doesnt appear shorted. R10 appears to have gotten hot because its dark, but offers an adequate measurement. Any suggestions? Thanks!
  • 13 more comments
  • Anonymous Feb 23, 2008
    Same thing exactly
  • Gary12345 Feb 26, 2008
    Our unit powers up, but we get no sound. We always have had problems with this thing. We should have gotten an expensive, high end system. Oh wait a minute, we did!
    Buyer beware: observe all the Google hits for "bose repair". It must be all the moving parts that wear out - oh wait a minute, there are no moving parts. There's just junk electronic parts inside of a fancy marketed, overpriced product here..
  • Anonymous May 03, 2008
    There is no sound from my Bose 3-2-1 system. It was working ok a day ago and suddenly nothing works. I can't even play the DVD any more. How do I check if the fuse has blown or determine the cause of this using some basic troubleshooting steps.
    Thanks
    JD
  • fasiaca May 28, 2008
    Same porblem - no sound. I've had this unit for over 3 years and the sound just stopped working. Any possible solutions?
  • Anonymous May 29, 2008
    Mine plays sound, but only the music score, etc. There is no audible dialog on movies. Weird. Oh, then suddenly there is this loud BUZZZZZ!
    This thing has already been sent back to BOSE for repairs. They have a flat rate that they insisted on charging, even though we were less than a month beyond the warranty (and, in fact, the damn thing broke while within the warranty--I procrastinated).
    Their stuff is junk. We also bought the super duper WAVE cd/radio with a CD changer that stopped working and ate my CDs after almost no use.
    Finally, we originally financed through them with a very predatorial finance company. It was a horrible experience.
    We'll never have anything to do with BOSE products again.
  • rstarrh8 Oct 29, 2008
    have a sony bravia and a bose gsx 321, i have it all connected according to the instructions. the only cale we dont have is a digital audio out cable. is there any tricks to getting the speakers to work. i already changed the tv speaker to outside display. need help with initial set-up
  • chris522 Dec 04, 2008
    My sound plays fine for DVD, CD but when I put on to my TV no sound, it did work then one day nothing.
  • Anonymous Dec 05, 2008
    tuve un apagon en la casa y luego no emite sonido.
  • Anonymous Dec 07, 2008
    same thing..mine worked fine w/ my sony bravia for a while and now no sound! i tried to hook the system up a couple of different ways - no luck. i had to send this pos back once because the sensor did not work and now this. i doubt it is still under warranty. what a waste of money. hopefully they will offer good customer service and let me send it back so they can diagnose the problem. if they want to charge me hundreds of dollars i am going to just throw it in the trash. sad.
  • Anonymous Dec 09, 2008
    Our Bose DVD player had been working fine.  Then the next day, NO SOUND!  We didn't touch it or change anything.  All the lights come on, but not sound.  Why???
  • bertucjx Dec 19, 2008
    I have the same problem. I moved apartments and when I went to reconnect at my new apartment...no sound!! All power works dvd's play, cd's play the radio still tunes but no sound whatsoever out the speakers. Not sure why that is?
  • Anonymous Dec 21, 2008
    i dont get any sound out of the 321 system
  • Anonymous Feb 19, 2009
    My bose 321 was working, then the sound popped out and then nothing. No sound at all...
  • david pickell
    david pickell Feb 21, 2009
    bose ps3-2-1 . I unpluged the system to move it to a different location and when I plugged it back in, the fuse blew. I replaced the fuse but now there is no sound. has anyone figured out a solution to this?
  • david pickell
    the fuse blew so I replaced it but now it has no sound. ??? I'm lost, can anyone offer a solution? any help would be greatly appreciated.
The power supply is 29 volts raw voltage,the IRFI44N fet on the power board is used is a switcher.
It reduces the voltage to 17 volts which is required for the AV3-2-1 meda center.The higher voltage biases the sound to cut off and can blow the drivers,try changing the fet and see if plays........
Posted on Apr 05, 2009
Hi - I had the same problems - it was working, then the sound popped out and then nothing.  I referred to the Bose website and it said unplug the power pack for a few seconds, which resets the system.  After that all was fine.  This is the easiest first step.  If this doesn't work, your system may need to be serviced.
Posted on Nov 21, 2008
    Scholar:
  • 99 Answers
First things first @ Gary12345 Bose is and has always been overpriced and never offered the quality that you would expect from the price. I would stick with brands that actually offer quality like Dennon, Onkyo, Harmon Kardon, and others. Now for the problem. kamige21 it sounds like you have it open and are checking the components. I would try to find the power supplies and look at the high voltage power supply to see if the transistors are open as that sounds like the most likely problem from what I read. If they are not then I would check the amplifiers see if they are showing open. look for any capacitors that are bulging as that is a sign that they are bad or are going bad.
Posted on Mar 13, 2008
I am having an even worse problem, my system works for 10 seconds then it disconnects and does not eject either. to make matters worse i live in Algeria. no Bose Tech support around here. and no one here knows the brand let alone the system.
Posted on Apr 20, 2008
Bose system is just over 1 yr old, hooked up to Smart Tv ( same age) sound was working fine, turned volume down, no sound at all after that
Hi, You have a Bose Home Theater System hooked up to your television and I'm wondering if you're controlling the volume through the Bose Home Theater System or the television because both have a volume control and if you have the television volume turned down and you're using the Bose Home Theater System for volume or visa-versa then you're not going to get a decent sound. I hope you know what I mean...... CHEERS..
Mar 31, 2016 | Bose Audio Players & Recorders
Bose Lifestyle V35, sound but no image.
Thank you so much the unplug the power from the system worked after hours of trying other stuff
Huge thank you
Aug 14, 2012 | Bose Lifestyle V35 Theater System
I have a Bose Lifestyle v20 home theater system and whenever I use the radio ( FM/AM ), no sound/music comes out. The rest are fine, but only the FM/AM ones dont work. It used to, but now its gone.
I hope you checked if the antenna wire is connected before reporting this defect.
All modern radios have automatic muting. No sound will come out unless the receiver gets enough signal strength to give you an undistorted sound, so if your antenna wire is disconnected you will get no sound.
Jun 15, 2011 | Bose Lifestyle V20 System - black Theater...
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
Audio problems with Bose 321 system
Hi, sounds like the centre front speaker is disconnected. Check the wiring on that, if all is good there then a fault most likely with the amp. To make sure try connecting a different speaker to the centre channel just for test purpose to eliminate a speaker/cable fault. Best of luck
Jul 11, 2009 | Bose 3·2·1 II System
I have a BOSE Lifestyle 48 without sound
Not sure if this is the same problem, but I lost audio from the Stored, TV, Radio and my external speakers, but still had audio for the CD/DVD. I contacted Bose (Australia) support and they talked me through a solution that worked for me.
Remove the power cord from the Media centre, then while holding down the 'All Off' and 'Vol down' buttons on the Media Centre, reconnect the power (and continue to hold the buttons down). After 10 secs, release the buttons and turn the Media centre on. Everything worked fine for me after doing this.
Full marks to Bose for the phone support. I hope this helps someone else.
Jun 24, 2009 | Bose Lifestyle 48 System
No sound through Bravia speakers after BOSE removed.
Did you ever have audio through your tv before?
It's likely that your Comcast cable box was connected directly to your Bose system, and not your television.
You'll need to check the connections from your cable box, to your television.
Mar 17, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Jul 19, 2008 | Bose Lifestyle V20 System - black Theater...
Ps321 subwoofer
Yes you can wire it to anything but your going to loose power if the amp cannot handle it
Jun 18, 2008 | Bose 3 2 1 GSX System
Bose 3 2 1 GSX System Logo
5,879 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
