Question about SanDisk Sansa m240 MP3 Player
Rearrange songs on the SanDisk
The songs are listed alphabetically, but I would like to rearrange them manually, how can I do that?
  • robert smith
    robert smith May 11, 2010
    what program are you using ? ie itunes or a nother sorce ?
  • 4 Answers
Creating Playlists on the Sansa M240
The Sansa M240 is a decent device, but if you are like many, you have not been able to create playlists. The instructions with the player and the maker’s website offer little help. Here a solution that I found on-line with some additional detail. The step by step instructions for even those with little computer savvy.
1. power up your M240 player without connecting to your computer. Scroll thru the menu to the “settings” menu. Select “USB”, deselect “auto detect” then select “MSC”. (I don’t know if this step is critical, but I picked up this suggestion from another site)
2. Power down the MP240 and using the cable supplied with your player, connect to the USB port of your computer. The display will show “MSC” when connected.
3. If you have not already done so, download the songs you want to include on your playlist from your computer to the M240. Any number of media player software packages will allow you to copy or burn your songs to a “portable media device” for this step.
4. After your songs are downloaded, on your computer, go to “My Computer” and open the "Sansa M240" icon. On the explorer task bar, select “view”> “details”. You should see several standard folders and all your songs. (Note I have used this for both .wma and .mp3 formats and have intermixed them in the playlist)
5. On your computer, open a new Notepad document and save it to your desktop.
Name it whatever you like, but it has to have “.m3u” as a file extension when you save it.
For example I named mine…. playlist1.m3u, playlist2.m3u, playlist3.m3u.
6. Next, in this newly saved notepad document, type this exactly on the very first line < #EXTM3U > without the brackets.
7. Now, find your first song in the open M240 folder, place your cursor on it, right click and select "rename". When the song title is highlighted hit control + C or "Copy" the entire title, being careful not to change anything. Now place your cursor immediately after the #EXTM3U text, hit return and paste the title of your first song directly below it with NO line space in between.
8. Repeat the steps to copy the title of your next song from the M240 folder. When copied, place your cursor immediately after the previous song title copied in the step above. Hit return Twice to create a single line space after the song title and paste in the next song title at the beginning of the line. Repeat this process til you have built your playlist.
8. After you’ve entered your last song title, it should look something like this. (Either .mp3 or .wma extensions can be used)
First song.mp3
Second song.mp3
Third song.mp3
And so on.mp3
Now, within your notepad playlist document, click File/Save (noting where it was saved) and close the file. Now, find that same original playlist on your computer. Highlight it and copy / paste it onto your M240. I copied mine into a folder called “playlist” on the M240. Then I repeated the process for other playlists, giving each a unique name.
After allowing sufficient time for the file to copy, use the icon in the lower taskbar of your computer to “safely disconnect hardware” to unplug your player. Disconnect the USB cord, power up and your ready to enjoy your playlists.
Posted on Mar 22, 2008
Thanks to dmil, I found a nice workaround for this problem, but you need to have Winamp (mine is 5.52).
Basically you plug in your Sansa (mine is a m240) and on XP it will prompt you asking what program you would like to manage this new device with. Choose Winamp. I had Winamp "play all". Now from the list of all your songs on the player, you can "delete" (which simply takes them off the list) or rearrange them however you like.
Then click "List Options>Save List". On my m240, you need to save it in the same folder as all the songs folders (Music). If you just save it in the root directory, if will say "no files" when you try to use it, though it WILL show up.
Power the beast back on, give it a second, go to Menu>Play Music> Playlists and you should see your playlist(s) there.
Posted on Jun 18, 2008
I am using Windows Media Player. The itunes will not recognize the scan disk.
Posted on Feb 09, 2008
How do I arrange the songs in my individual albums in alphabetical order? When it's the entire song list, the songs are in perfect alphabetical order. But when I look at each individual album, the...
Most of the time the sucks under the albums file won't be in alphabetical order, usually you have to go under the folder and change the view settings. if you can't do that then manually arrange them if possible. and if that doesn't work, they will stay like that.
Sep 28, 2011 | Philips GoGear SA2825/37 MP3 Player
When i turn my sansa fuze on it says "not enough space for music db please free 90mb"and turns back am i able to get it to wrk again?
When the player is rearranging playlists of the music database, it is possible that there's not enough memory left in the player to finish the task.
Connect the player with your computer to delete some files, at least 90 MB, off the Fuze to make it work again.
When not having a backup of the songs, save them onto the computer first.
Here's the support site for Sandisk Sansa Fuze:
Directly to the Sansa Fuze user manual:
Need more help ? Just add a comment.
Apr 20, 2010 | SanDisk Sansa Fuze MP3 Player
I cant change my play list. i want to change my song and i cant reset any of my original ones
Open your MP3 through Windows Explorer, open the Playlists folder and delete whichever playlist you want deleted. Edit it through WMP11 and reinstall. You can rearrange and delete songs through Explorer, but you can't add songs.
Jan 05, 2010 | Sony NWZB135F MP3 Player
Sync songs don't show on my player
It says in the user manual for C-100 sansa player that "various software packages are available to syncrhonize your songs on your device. Please refer to the specific software package instructions. "
I used Windows Media Player 9 and when you use these older Media Players you must remember to change your USB setting on your Sansa player to MSC. Turn on your Sansa Player, Choose the Main Menu and select settings. Don't choose auto-detect, but select MSC. If you choose auto-detect it will default to a setting called "MTP", and MTP wants Windows Media Player 10 to download your stuff.
I'm not familiar with how ITunes works, but perhaps AUTODETECT will work to synchronize your files.
Good luck.
Jun 22, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
How I can order for their name (alphabetically) my songs inside e
MP3 players generally copy music over in a set way.  Usually that's however you have music stored on your computer.
Once on the MP3 player, you won't be able to rearrange the music, in most cases.
You should try arranging the music on your computer (which is time consuming, if you have a lot), and then move it to your MP3 player again.
Mar 19, 2009 | Audio Players & Recorders
"Unknown" listed in spots for songs in player's list of all songs
It's the id3 tag information that hasn't been filled out, most likely.   (id3? Hmmm)
Anyhow, depending on the operating system you use and the program you use for your music, it's easy to change.
If iTunes, just import the song into itunes, and "edit Info" and change all the song information. In Windows I believe you can do it in WMP, or by right-clicking the file.
Alot of the time a song just has the info in the filename, but mp3 players use the id3 tag to identify a song.
Dec 22, 2008 | SanDisk Sansa e260 MP3 Player
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
Dec 05, 2008 | SanDisk Sansa m240 MP3 Player
Shuffle seems to play same songs
The shuffle feature shuffles songs randomly - no way to change the order.
On the Sansa Clip, you have to make the changes to the song order in Windows Media Player first, before you transfer the playlist to the Sansa, using the advanced tag editor function; change the track number. If you have already transferred the song(s) over to the Sansa, you must delete the songs on the Sansa first, or else it will not accept the playlist transfer with the new track order. You can always go back and change the track numbers that are stored in your WMP library after you have transferred the playlist to the Sansa.
-Tha Mp3 Doctor
Jan 25, 2008 | SanDisk Sansa Clip MP3 Player
Song Alphabetizer
The best thing to do is reformat it
Dec 02, 2006 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
346 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
