SQL Server 2000
HI
I have a problem that i want to select multiple chioce on different tables in one statment.
Hey friend "join" is right choise for ur problem.
hey am searching SQL SERVER complete reference(free)
if u find it pls send d web address to my mailid:nacdestiny@yahoo.com
Posted on Mar 14, 2008
  • 35 Answers
I'm not sure I understand what your trying to do. Are you talking about trying to perform a 'join'? Could you explain a bit more, or even give an example?
Posted on Feb 02, 2008
Recover data from corrupt .mdf and .ldf files.
You can find more information here:
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/569-i-have-a-problem-how-do-i-fix-a-corrupted-database-file
Open your SQL Server Management Studio console. This application shortcut is available in the SQL Server directory in the Windows Start button.
· Enter the system administrator user name and password. SQL Server's administrator user name is "sa." This account is required for privileges to restore the database. If your restoring on a host provider server, use the administrator user name and password they supplied for your account.
·Right-click your database name and select "Attach." In the new window that opens, click the "Add" button to open a dialog box.
·Select your MDF file and press the "Ok" button. It may take several minutes to restore the database if it is a large file. Once the process is finished, browse your tables to verify the data. The database is now restored.
If nothing helped try to use:SQL Server Fix Toolbox
http://www.fixsqldatabase.com/
Nov 28, 2014 | Microsoft SQL Server 2000 Standard Edition...
Tip
How to recover sql 2000 sa password
Microsoft SQL Server 2000 is a full-featured relational database management system that offers a variety of administrative tools to ease the burdens of database development, maintenance and administration. It operates in one of two authentication modes: Windows Authentication Mode (the default) or Mixed Mode.
When you install the SQL Server 2000, you can log in the server with Windows Authentication and SQL Server Authentication if you select mixed mode authentication. If you select Windows Authentication, you cannot assign a sa password during installation. However, you should set the sa password after installation.
It is very easy for one to set sa password in SQL 2000. Just follow the below steps:
* 1. Expand a server group, and then expand a server.
* 2. Expand Security, and then click Logins.
* 3. In the details pane, right-click SA, and then click Properties.
* 4. In the Password box, type the new password.
The type of client connections determines the choice of security mode. If all of the incoming clients support trusted connections, you can use Windows Authentication Mode. If some clients do not support trusted connections, you can select Mixed Mode.
If you forget the sa password, you will need to use MS SQL Server Password Unlocker to reset sa password SQL 2000. MS SQL Server Password Unlocker is easy yet powerful SQL Server password reset software for you to reset SQL password, including reset SA password and other user passwords. It provides you an easy and safe way to reset SQL Server password for Microsoft SQL Server 2000/2005/2008 in a minute. No need for you to reinstall MS SQL Server on your PC. The file in master.mdf format is enough for you to recover sa password SQL 2000.
Steps to reset sql password 2000 for sa as follows:
* 1. Download and install MS SQL Server Password Unlocker.
* 2. Click the application icon to run it.
* 3. Click Open to import your master.mdf file. All the user names of your MS SQL Server will be displayed.
* 4. Select sa account, click Change password button to reset sa password.
* 5. Type a new password, and then click OK to finish your operation.
Note: This method to reset sa password in sql server 2000 is usually applied when you cannot login SQL Server 2000 by Windows Authentication wile you forget system administrator login password.
More information about sa password:
According to Microsoft, System administrator (sa) is a special login provided for backward compatibility. By default, it is assigned to the sysadmin fixed server role and cannot be changed. Although sa is a built-in administrator login, do not use it routinely. Instead, make system administrators members of the sysadmin fixed server role, and have them log on using their own logins. Use sa only when there is no other way to log in to an instance of Microsoft SQL Server.
on Oct 19, 2010 | Computers & Internet
Any Powerful SQL repair tool with new features
Hi Mahi,
If you are looking for any Powerful SQL Repair Tool then I would recommend you to use SQL Database Recovery Software by Aryson.
This tool can recover and repair all your MDF files with attachments.
Hope This Helps !!
Jun 04, 2014 | Microsoft SQL Server 2000 Standard Edition...
How do copy a table from an access database in one folder to another access database in another folder through visual basic code
Simple method Open both tables (or create second) and copy each record from source to target through 'do while not eof' or 'for each' syntax.
Second solution create link in target DB for first table, and use SELECT INTO statment in SQL.
Mar 02, 2009 | Microsoft Visual Basic 6.0 for PC
Transaction replication is poosible in sql server devlper edition
SQL Server 2005 provides a lot of benefits over SQL Server 2000 including within the replication feature set.
You might be relieved to know that, although most of the benefits accrue on the side of a SQL Server 2005 Publisher, you can still set up SQL Server 2005 as a subscriber on a SQL Server 2000 Publisher. Thus, you can begin to merge in the newest release of SQL Server into an existing replication scheme. You can read more about this at http://msdn2.microsoft.com/en-us/library/ms217330.
Although major advantage to SQL Server 2005 over 2000 is that changes to the schema, such as through ALTER TABLE statements, replicate out to all subscribing servers. The cool news in a mixed version environment is that the ALTER TABLE statements will be published to SQL Server 2000 Subscribers from a SQL Server 2005 Publisher.
Very cool!
Jan 30, 2009 | Televison & Video
Restoring files from the database
I suggest you use the Enterprise manager (gui tool to manage SQL).
Restoring a single table is not an option.
You can however restore a file or filegroup.
Make sure to backup before you start and NOT to restore database to its original name or original file location, to avoid acidents.
Normally you will have databases with only 2 files: the data at its Primary file group, and log file.
You may wish to create a new file group and move tables to the new group by recreating them there and exporting data from old table to new table. Then recreate indexes. This may prove to be complex as all tables and indexes have unique names and can't coexist with exact duplicate of them.
oh yea..... did I say backup?
well just in case backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup
but dont overwrite that backup
Feb 11, 2008 | Microsoft SQL Server 2000 Standard Edition...
SQL Server 2000
An easy way to transfer objects (tables, user defined functions, stored procedures, etc.) is to use Enterprise Manager's "Generate SQL" feature. Use this process at your own risk. Doing it wrong could mess up your existing database.
1. In Enterprise Manager, right-click on the old database and choose "All Tasks" then "Generate SQL Script".
2. In the dialog that comes up, click "Show All" then select the checkboxes for "all stored procedures" and "all user defined functions". (You might also want to check some other boxes, depending on your exact situation.)
3. Click the "generate" button and save the script that it creates.
4. Run the script in the NEW database.
If you run the script in your OLD database, it may destroy your objects, and that would be very bad. Make sure you run the script in your NEW database. (While we're on this subject, it's a good time to mention that you should back up your database before you start this process, and you should make changes to a test system before migrating it to production.)
That should move your stored procedures and user defined functions over.
You can use a similar process to move tables, views, users, and other objects over as well.
Jan 17, 2008 | Computers & Internet
Viewing ms Sql Server database on Access
Are you familiar with "Linking" tables in Access? In Access: File --> Get External Data --> Link Tables. This will bring up a dialog box which allows you to browse to your SQL server and select the table you want.
Aug 23, 2007 | Microsoft SQL Server Standard Edition for...
Computers & Internet Logo
46 people viewed this question
Alun Cox
David Payne
David Payne
