Question about Compaq MP1600 Multimedia Projector
Compaq mp1600 projector
I bought the video adaptor for my compaq 1600 projector, it said it was compatible with a compaq mp1600 or 1800 projector. I hooked it up to my projector and it doesn't work with my DVD player. The projector works great with my computer. I would like th option of being able to use my DVD or videoplayer also. What am I doing wrong?
  • neOen May 11, 2010
    Is the projector saying "input signal out od range"? if not, check the output signal type on DVD player, it must out put to either S-Video or RCA video, however you have hooked.
4 Suggested Answers
  • 563 Answers
SOURCE: compaq projector
Hi gambill32
If the VGA is a output you could get a converter that takes VGA to Component ( RGB ) and hook up the 3 x component RCA's to the TV 's component in.
This converter can be found at most good PC and AV shops.
Good luck and thanks for using Fixya.
P.S. If you need any further guidance , just send me a request.
Posted on May 13, 2008
SOURCE: ipaq mp3800 projector--no source found check signal cable
compaq pesario c700 audio drver for this link
Posted on Jan 06, 2009
  • 11896 Answers
SOURCE: Compaq mp1600 red car in pactue appears yelow
go to control panel, then go to display properties and try changing the theme to default.
Posted on Jul 11, 2009
Compaq mp1600
please upload a fan picture and showing its model, i have thread can help you to find a new fan
Jan 12, 2013 | Compaq MP1600 Multimedia Projector
When I connect the projector to my PC after the COMPAQ image goes away, it displays "Check Video Cable". What does that mean?
you may need to turn on dual monitor on your computer. sometimes just restarting the PC while connected will do it as well.
Mar 13, 2011 | Compaq MP1600 Multimedia Projector
What is the replacement bulb model number. Thanks
Any of the following part numbers will work:
All are identical parts, HP/Compaq uses different part numbers for the same part in many cases depending on which distribution channel is used.
Aug 16, 2009 | Compaq MP1600 Multimedia Projector
Jul 11, 2009 | Office Equipment & Supplies
Compac MP 1600
your prblem will be in motherboard or in power pack module-start to change powerpack module first then motherboard second- or pass it to good sevice center.
Dec 25, 2007 | Compaq MP1600 Multimedia Projector
Dlp color whel glas
The projector is easy to open. whole side comes off including half silver bit at top you need to search for little rubber dots about 4mm in diameter, pick them out with a knive then undo the screws you will also need to remove one of the hex screws that the vga cable screws into. will not hurt to remove both, just use some pliers to loose them. Also remove the bulb door.
Sep 25, 2007 | Compaq MP1600 Multimedia Projector
Compaq MP1600 Multimedia Projector Logo
128 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
