Asks for "Device Ownership Password", which is not located on the router at all. Like suggested, i unmarked the protected setup options and now it just fails after trying to connect. I have Windows XP. Any suggestions?
You need to manually add the network using your intel pro set utility. Or just switch to wzc.(wireless zero configuration). How to do it? just click start - go to run - type in services.msc - then look for wireless zero configuration on the list - right click on it then click start.
Then look for the wireless network connection icon on the system tray (that's in the bottom right hand corner of your screen). right click on it then select view available wireless network.
note: if you'll be getting the message "windows could not configure..." click change the order of preferred networks(that's in the same window where you're getting that message) then check the box that says "use windows to configure my wireless network settings" then click ok. after that go back to view available wireless networks then you should see your network now.
note: if you're using a corporate laptop where you don't have admin rights on it you need to use the intel pro
