Question about HP DeskJet 1280 InkJet Printer
HP 1280 PRINTER TROUBLE SHOOT
The printer was jams with paper. After removing the paper, the " power-on" no longer working including all other keys. Upon inspection, they were no sign of burn Power supply, except the ink got sprinkled all over.
  • 55 Answers
Are u sure that power supply is burnt n gone ,because i just want to share that if the back side door is not fixed properly ,the printer will not power on,so pls try if u have not
do revert
thnx
Posted on Jan 28, 2008
Our printer HP 1280 we can print 1 page only then trouble will occur paper jam even theres no paper clog inside the roller..
clean your printer from inside carefully and use orginal HP inks then you will not face any problem
Feb 19, 2012 | HP Deskjet 1280
Paper jam hp deskjet 1280
Hi syarief03120,
Actually you can manually remove the paper from the printer. It can be pulled out from the feed area.
And to clear the paper jam message: You have to take the back cover off, there is a reset switch in the top left hand lock hole. Use an object to push in the pin hole. After that put back the cover on. This should help you fix the problem.
Hope it helps.
Thank you for using Fixya.
Apr 15, 2011 | HP DeskJet 1280 InkJet Printer
Trouble shoot keeps saying paper jam and there is no paper jam
Try removing and reinserting the access door at the back of the printer. It works most of the time.
Feb 07, 2011 | HP PSC 1315 All-In-One InkJet Printer
Carriage jam problem/1280 printer
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Sep 06, 2010 | HP DeskJet 1280 InkJet Printer
HP deskjet 1280 paper jam
Yes you can manually remove the paper. It can be pulled out from the feed area (pulled out backwards).
To clear the jam status....
Take the back cover off, there is a reset switch in the top left hand lock hole. Push a pen (or similar) into this hole, the switch will give slightly and be the same depth as the others.
put the cover back on, all should be well
I’m happy to assist further over the phone at https://www.6ya.com/expert/dan_91204789c5bd4b93
Sep 11, 2009 | HP DeskJet 1280 InkJet Printer
Setting custom paper size for hp 1280 in win vista
we loss the CD hp deskjet 1280 Serial No.CN65P8ZOHH want printer drivers
Apr 14, 2008 | HP DeskJet 1280 InkJet Printer
My hp deskjet 1280 printer is not coming on
well..sometimes when a paper jam occurs, it shuts the whole system down..
you may wish to remove the s/w for that printer through control panel
go here for updates drivers
re install the s/w
run test page, calibrate and clean cycles.
Mar 27, 2008 | HP DeskJet 1280 InkJet Printer
Power problem
I'ts because there are a paper jam
I have the same problem and I solved it myself
-.... look into the lock behind the printer remove it then put it back again >>>>>>>>
Dec 17, 2007 | HP DeskJet 1280 InkJet Printer
Paper jam
Carefully pull it out. Try not to rip the paper, because you may get some stuck inside. It may be necessary to open the printer up and even remove part of the cover to get it all out.
Feb 13, 2007 | HP DeskJet 1280 InkJet Printer
HP DeskJet 1280 InkJet Printer Logo
154 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
