Question about Dryers
Clothes do not get dry when using the sensor dry setting on GE dryer.
I have had this dryer now for about 16 months. Clothes do not get dry if I use the sensor dry settings. Even the More Dry setting will still leave the clothes wet. It will dry the clothes if I do a time dry. I have checked the vent hoses, and the all appear fine, including the outside vent. I am thinking that it must be the sensor dry. I was hoping that you could tell me how to check the sensor and see if it is defective.
Thank you!
  • 2 more comments
  • jwesterlund Jan 28, 2008
    Hi catriver. The dryer is a GE model # DCVH515EFoww. It does have a digital display.
    FYI. We cannot use dryer sheets, or fabric softener in the washer as our daughter does not do well with them. Maybe allergic? I have tried cleaning the sensor rods and that did not make any difference.
    Thanks for the reply. I am hopeful that with your help we can determine why it is not working as it used to.
    Jeff
  • jwesterlund Jan 29, 2008
    catriver,
    I was successful in running the test. However the lowest that the voltage would go was to about 1.19 volts. And that was with a rag that was dripping wet. If I wrung out the rag, like the clothes come out of the washer, the voltage would only go to 1.56. It kind of looks like we might be getting closer! What is the next step?
  • jwesterlund Feb 04, 2008
    Thanks for your help catriver. I cleaned the sensor rods and the sensor dry now seems to be working better. It still seems to take longer than it used to to dry a load, but all appears to be working well. Your advice on how to check the sensor was very helpful.
    Jeff
  • Ron Marek
    Ron Marek May 11, 2010
    J, I really need to know the model number here so I don't lead you astray. The moisture sensing rods are part of a circuit that uses a low voltage capacitor. Ranging from 5VDC when it's open and 1VDC when the circuit is shorted. When wet clothes touch the 2 rods, they create a short which discharges the capacitor. When the clothes become dry, they cant short the circuit and the charge builds to 5VDC. When the control board reads 5VDC, it thinks the clothes are dry . If your model has a digital display, a test can be run from the board. On this example of how this works, the capacitor is in the harness near the sensor rods and can be replaced as a seperate componet. That's why I need the model number. If the dryer is leaning backwards, it will be hard for the load to cross the sensor bars. Also, if there is a build up of fab softner on the bars, it will create a false reading. On this certain model, if the rods are not shorted within the first 6 minutes of the cycle, the cycle will terminate. Post back, Catriver.
    President:
  • 878 Answers
Ok, Jeff, I see you have a front loader, electric. On this model we have inlet thermistors, outlet thermistors, and the sensor bars are non serviceable, which means they are part of the blower housing. Not a big deal. Let's put it into a test mode and test the voltage drop of the sensors. They are on the inside of the drum just below the vent gate. 2 bars. Unplug the dryer for 30 seconds. Plug it back in and within 10 seconds press in this order: signal button, delay start, signal button again and delay start again. The consol should show t01. This is test 1. You want to turn the main dial clockwise until the test shows t09, this will be the sensor test. With the drum dry it should show around 5 volts DC. Now take a wet rag and place it over the bars, the display should show a voltage drop to around .5 or 1volt DC. If it does this the sensor is working properly. See if you can run this test successfully and post back. Catriver.
Posted on Jan 28, 2008
  • Ron Marek
    Ron Marek Jan 28, 2008
    Jeff, I got a head of myself, after you turn the dial to t09, press start to enter that test. Then power to exit it after your done. To exit the test mode, do the same key dance in the same order or just unplug the dryer for 30 seconds.
  • Ron Marek
    Ron Marek Jan 29, 2008
    That's not that far out of range, take some emery cloth and go over the bars lightly, see if that makes any difference. Catriver
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
My duet whirpool electric dryer keeps stoping before my clothes are dry
Make sure you are not using a timed drying setting. Use one of the pre programmed functions on the dial. These settings are meant to use a sensor and stop when the clothes are dry. If the problem continues on one of these settings, there is likely a problem with the sensor or your heating element
Sep 15, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How do i change the settings on my GE sensor dryer
check for clogged lint ,,, also may be a bad heating element
Aug 30, 2014 | General Electric GE DBVH520EJWW Electric...
My dryer is not drying my clothes completely. I have to set it to time dry for at least 120 minutes to get a load of clothes to dry. I can feel that the dry is warm .I usually dry my clothes on optimum dry...
Your dryer has a double set of heating elements
1 side of the coils is probably broken and you are getting half the heat.
This is making the dryer take longer to dry them clothes.
Air restrictions in the dryer and vent can cause the heater control to shut down quickly also.
If you have a bad breaker the power will sometimes work and sometimes not.
If all of these are good you might have a problem with the timer.
Most of the GE timers have leaf switches in the that get a burr on the contacts. The come apart simple enough.
I have more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 01, 2011 | GE DWSR463EGWW Electric Dryer
Dryer keeps drying long after clothes are actually dry.
Bad timer most likely, remove power and check continuity on the timer motor. Verify movement of dial.
May 21, 2010 | GE DWXR483EBCC Electric Dryer
I have always set my dryer on automatic dry. I
Clean the sensors ... they are likely coated with something. Alternatively, the sensors could have become disconnected during the move. Remove the back and check this out. Use a 5/16 nut driver - not a screw driver - youwill save yourself a bunckof grief.
Oct 19, 2009 | Dryers
Dryer taking too long to dry clothes
Hello :)
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 03, 2009 | GE Profile DPSB620ECWW Electric Dryer
DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Feb 19, 2009 | Samsung DV448AEE Electric Dryer
Dryers Logo
540 people viewed this question
Top Dryers Experts
Marvin
Marvin
