Question about HP Compaq nc8230 Notebook
Black screen i have an acer 3100....when i turn it on the screen stays black, and when i connect another moniter to it, the moniter says no signal....what can be wronge???? it all happened after my computer automaically downloaded updates for my computer
  • 520 Answers
Doesnt that auto update **** u off.if u choose to install in windows it slows things down and when you choose to install at shutdown you have compatability problems at startup.
start up with os in drive and choose repair ( "r" ) in prompt type in "chkdsk" this may repair any fault and enable boot.
if not startup again with os in drive and choose repair or install...not the repair ( "r" ) option in the first screen.(in first screen choose install,system checks existing os and informs you of it and asks to confirm install new or repair.
Posted on Apr 08, 2008
Press and hold f8 during start up. select safe mode. delete latest update. then restart in normal mode
Posted on Jan 28, 2008
6ya staff
SOURCE:
AOA150 acer asire one won't boot up at all. Have
when the screen is black try hitting ctrl alt delete a few times and you should get some options to work with
Apr 04, 2010 | Acer Aspire 3100-1405 Notebook
I have a acer monitor model #AL1716, the screen goes black and then the acer name comes up. This happens frequently and not in a pattern . I have checked the plugs to be sure they are connected. Please...
1. Does this happen well you are not actively using your computer?
If so In control panel >> Power Options >> the default is "turn my moniter off after 20 min" you can adjust there.
Oct 14, 2009 | Acer Computers & Internet
Acer aspire 3100 screen is black but it works fine through vga.
at the bottom of the laptop screen behind the plastic is a inverter that can fail look one up on ebay ...
20 bucks to fix
New LCD inverter Acer Aspire 2000 3100 5100 5110 5720
Sep 03, 2009 | Acer Aspire 3100-1405 Notebook
ACER 3100 does not boot
have u tried booting the computer with just the power supply hooked up and your battery out? iv'e had the same exact lab top and the battery went bad and the computer wouldnt do anything at all like your talking about. Even if i had the power supply hooked up and the battery. Remove the battery, and try booting it up.
May 23, 2009 | Acer Aspire 5100 Notebook
My acer aspire one would not turn on to linux stuff!!
well which distro are you trying to use, that could be the whole situation right there, depending on the distro.
May 09, 2009 | Acer Aspire 3100-1405 Notebook
Acer 3100 screen wont turn on.
Have you tried hooking an external monitor to the system? If that works you may have accidently switched the screen to an outside monitor. Or you could have a bad connection. Try starting in safe mode and see if it works.
Jan 19, 2009 | Computers & Internet
Acer Aspire 3100 series. Display screen getting dark
This is such a user error. I had the same problem on my 3100-1718. It was as simple as holding down the Fn key and using the left and right arrow keys to change the brightness... I am a goofball for ever letting this stay dark for a month !
Jun 23, 2008 | Acer Aspire 3100-1405 Notebook
No signal input
Check the coolant between the CPU and the cooler to ensure it's not simply over heated.
May 30, 2008 | Acer AOpen AX 6B Plus (91.87810.321)...
My Acer LCD AL1711 went off after seconds of turning on.
This monitor has "back lights" that are essentially like flourescent lights. These are high voltage lights and can easily fail. since you are getting some light initially, I would suspect a defective part that heats up a bit right away and then fails. I would try to replace the entire backlight board. This is the small board on the side (usually).
Dan
Mar 27, 2008 | Acer AL1711BM (Black) 17" LCD Monitor
Black outs
May be your IP board is going out. Replace IP board.
Aug 25, 2007 | Acer AL1916W 19" LCD Monitor
HP Compaq nc8230 Notebook Logo
202 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
