I've got some bizzare & annoying problem in some of our servers.All other servers dont have this unknown restart issue. Only the PPPoEservers restart. When it restarts, it shows this message:
"kernel: Dazed and confused, but trying to continue
Do you have a strange power saving mode enabled?"
I did searches on google, didn't find anything regarding this issue,but i found few similar searches; there were unknown solutions forthis. Some showed that it was something to do with the RAM, but ichecked that, it doesn't have anything to do with it.
The pppoe servers are "IBM eserver xSeries 336"
The specifications of these servers:
CPU: 1 x86_64 3.0Ghz processors (Cache: 1024 KB) Intel Xeon
Network: (2X) Broadcom Corporation NetXtreme BCM5704 Gigabit Ethernet PCI
Network: (2x) Broadcom Corporation:NetXtreme BCM5721 Gigabit Ethernet
SCSI: LSI Logic / Symbios Logic 53c1030 PCI-X Fusion-MPT Dual Ultra320
SCSI
CDROM: HL-DT-STDVD-ROM GDR8083N
Graphic Card: ATI Technologis Inc Radeon RV100 QY (Radeon 7000/VE)
USB: (2x) Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller
Storage Device: (2x) Intel Corporation 82801EB (ICH5) SATA Controller (each 36.4)
RAM: 3GB
the kernel version of Fedora Core 4:
linux version 2.6.15-1.1833_FC4smp(bhcompile@hs20-bc1-.build.redhat.com) (gcc version 4.0.2 20051125 (RedHat 4.0.2-8) ) #1 SMP Wed Mar 1 23:56:51 EST 2006
Well thanks, hope there is a quick solution for this.
thanks
Comments:
Feb 02, 2008
- thanks for helping, I'll try that soon, and see if that works. I'll give you a reply if that works.
Thanks again for the help!
Feb 04, 2008
- Hey daverh,
I looked thoroughly for power management options, ACPI and power saving on the BIOS, and there is no option for this.
I remember there is power saving mode in the O.S., but is that going to help if its disabled on the O.S.
If i should disable it on the Fedora Core 4, what are the steps to disable it.
thanks
Feb 05, 2008
- the first time i came about this unknown restart, I though maybe if i update it, it will fix the restart issue, i updated the BIOS a couple of times which didn't solve the problem.
Well the strange thing about this that when i changed one of the PPPoE servers recently to a different type of server by just exchanging both hard drives with 2 hard drives that already got all the setup, O.S, programs installed. and just 2 network interfaces linked. 2 other interfaces not linked - system never restarts. this server is for hotspot page and prepaid services and has its own database which is ok but not so stable and thats y we are using also PPPoE servers. I regularly check the logs and no restarts. It's same hardware as the other PPPoE server but just different services running with the same Fedora Core 4. Now i have a feeling maybe the O.S has problems with 4 network interfaces running at the same time or it can be something in the PPPoE scripts running. Well the configurations of these servers i didn't made them. The configurations was done by a team that came here and did all these. All the other servers from the PPPoE servers don't have this restart issue and the others all have 1 or 2 network interfaces linked. I can't take none of the other network interfaces off because all the 4 network interfaces linked are running each for a purpose. 1 is the External (backbone internet), Internal (SNMP and RADIUS(Database Authentication)) DMZ (IIS linked & Mail) and 4th is Wifi (linked to wifi transmitters). The team left has a quick sketch of the services, network, and firewall configurations. I can go into each of the servers and find out exactly what scripts are in, but its hustle to understand these scripts lol.
thanks for your time and help.
The ASU sounds good, i will look for it and see if i can view power saving mode and ACPI options.
thanks
