Question about Brother LS-2125 Mechanical Sewing Machine
I have a Brother LS-2125 and when I try to sew it works for a minute then the bottom thread bunches up and goes no wear, i thought it was my bobbin but im not sure, im not real familiar with sewing machines so any help would be great.
  • 268 Answers
Here are some solutions to try.
* Re-thread your machine
It may be threaded incorrectly.
* Raise your feed dogs If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Posted on Dec 30, 2009
I am having the same issue with it. and i cant figure it outttttt.
Posted on Feb 01, 2010
  • 149 Answers
Http://www.singerco.com/accessories/manuals.html
free manual to download or view
Posted on Jan 17, 2010
SOURCE:
Brother LS-2125 bunches bobbin thread then won't sew.
Check your stitch sample. Dollars to donuts it's the top thread bird nesting (also called thread nesting) under the fabric. Issues appearing under the fabric is usually top thread related. Problems appearing on the top of the fabric is usually bobbin thread related.
Remove the top thread from your machine.
Be sure to start with a brand new needle.
ALWAYS RAISE the presser foot and rethread the top.
Jan 13, 2018 | Brother Sewing Machines
Threading the bobbin
hi Sharon.
not sure if this will help you out because its saying its for the, ls 2125i.. but try this step by step link.
How to Thread Brother Ls 2125i Sewing Machine
or this youtube video link.
How To Thread Bobbin on Brother LS 2125 Sewing Machine
this link might be the best one for you to watch.when you go to this one scroll down the page a bit and you will see where you can watch the video,
How to Thread bobbin on the Brother LS 2125 sewing machine
Nov 25, 2017 | Brother Sewing Machines
My bobbin thread keeps bunching
try changing the needle
rethread the machine top & bobbin, using every thread guide
make sure the thread has not come off the thread take up lever
here's a link for a manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125_EN_272.PDF
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125i_EN_1628.PDF
Jul 17, 2012 | Brother LS-2125 Mechanical Sewing Machine
When i am sewing the thread from the bobbin keep bunching up in the bottom of the material
you might check your needle-roll on flat surface to see if it roll correctly
there are 3 types of bad needles-bent,,blunt,damaged
on some sewing machine the thread can come off the thread take up lever
check the bobbin area for lint or loose threads
Sep 22, 2010 | Brother LS-2125 Mechanical Sewing Machine
I have a LS-2125 brother machine, and when I sew the thread from the bottom catches and breaks. I have taken the bobbin casing apart and cleaned and oiled it, changed bobbins, tried to adjust the...
make sure that it is threaded right, and that you do not have your needle inserted backwards, flat side should face rear of machine, read your manual carefully. If you do not have one, go to www.brother-usa.com and you download one for free.
Sep 07, 2010 | Brother LS-2125 Mechanical Sewing Machine
When I sew a few inches, bunches of threads come out of the bobbin case. It's like it gets clogged or something. I'm getting nowhere with this. Help!
If your bobbin is the correct one for your machine and it is wound tight, not loose and puffy, make sure the thread is going the right way when installed (over the top to the left and then placed flat in the bobbin case). Usually if the thread bunches underneath your fabric it means that the TOP thread is threaded incorrectly. Try re-threading the upper thread. Good luck!
Aug 21, 2010 | Brother LS-2125 Mechanical Sewing Machine
How to stop bobin thread from knotting
When loading the bobbin there is most likely not enough tension on the thread letting it overlap incorrectly. Try wrapping thread around a tensioner when filling and that should help. That way the bobbin is rolled as tight as the tension on the upper thread when sewing.
Apr 13, 2010 | Brother LS-2125 Mechanical Sewing Machine
I have this machine brother ls-2125.my
You need to either adjust the tension or ensure that you have routed the bobbin thread properly.
Apr 11, 2010 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
519 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
