Question about Samsung Yepp YP-T7JZ MP3 Player
YP-T7J.IMG Error I updated the Firmware and restarted the player, and now I receive the following message:Image is invalidCopy Image File (YP-T7J.IMG) to Data Folder.Anyone have an idea of how to fix this? Thanks.
  • ukmanchild Feb 15, 2008
    Thank you for your help - it was perfect. I apologize - I should have posted a response sooner - I realized I had chosen the wrong firmware package for my player. Once I d/l'd the right package it worked perfectly.
    Thank you for your guidance.
  • Xpmx20x Sep 20, 2008
    I need Help with that to
Thank you zero555! that was amazing!
Posted on May 01, 2008
I had the same problem but it was because i updated the firmware. First of all my mp3 player did not have a Data folder so i created one and copied the firmware. i went through the updating process and formated my player. i turned it on and it said the img was corupted. So i recopied the firmware into the Data file and it upgraded just fine
Posted on Mar 27, 2008
I just had the same problem occur yesterday. I was unable to delete a recorded item that I accidentally recorder for over an hour. So, I had an hours worth of nothing on my player and it was taking up space. I did some things that ended up having the same message as yours on the player. I went to samsung's website and downloaded the firmware on my desktop. Make sure to save it to your desktop. That was the best way for me to get this fixed. Here is a step by step.
1. Go to the samsung website.
2. Go to support, a drop down will be seen and select download center
3. Click on search by model number
4. At the bottom you will see 4 tabs, click on firmware
5. Click on the icon that looks like a folder and says zip
6 I am using Fire Fox browser so when I click it a window will open up and I click save and this will take it to my desktop. I assume this is the same for explorer
7. I go to my desktop and see a zipped folder (20061102100326312_T7J_FW_V10207) and click on it
8. Here is an important step. When you click on the zipped folder and it opens, make sure to click the on the left hand side, extract all files. If you don't this will not work
9. Follow the screen that will pop up (the window wizard)
10. This will unzip the folder and create a new folder on your desktop called (20061102100326312_T7J_FW_V10207(2)). Open this folder up
11. Next, hook up the the YP-t7j to your computer and when the widow pops up (portable device), click on OPEN device to view files using windows explorer.
12. Click on the Icon TCNANDO
13. Now, open the folder (20061102100326312_T7J_FW_V10207(2)) which is the unzipped folder on the desktop
14. Have both windows open, the player window and the unzipped firmware window
15. Highlight both files in the firmware unzipped folder and drag them both to the player window. You should notice on the samsung screen that upgrades are being downloaded. Watch the screen until it says completed. Then unplug the player from the computer and turn on the player. It will turn on and do the upgrades and then it will shut off again. Turn it on again and it should work
Hopefully this will help. I know I put a lot of steps on here. I did this because I know when I search for info, I like step by step. I spent a few hours trying to figure out the problem. So i figured I would do the step by step and hope to solve the problems in a few minutes. I was getting really frustrated trying to fix this and I was worried the player was useless. This worked for me.
I think all the steps are right. I will check back on this post to see if it worked for you. Hopefully you check this site and not have thrown your player away.
GOOD LUCK
Posted on Feb 15, 2008
  • roughriders Feb 16, 2008
    ukmanchild
    Your welcome and I am glad it worked!!!
How to update firmware for vizio vbr100
To update the firmware for the Vizio VBR100 Blu-ray player, you need to download the firmware package to a computer with a CD-R or other optical disc burner. The firmware is a .zip file. Next extract the contents of the compressed folder to see the .ISO file. Use the computer program to burn the ISO to CD. Windows 7 and later included this type of program (right click on the file and choose Burn disc image). For other systems, you need a program that can burn image files to disc. Nero Burning ROM is one such program.
Now make sure that the player does not have an optical disc in the unit and turn it off. If possible, plug the Blu-ray player into an UPS (battery backup). Turn the player back on and wait for the No Disc message. Press Eject to open the disc tray and put in the CD with the firmware. Close the disc tray. The Loading Disc message should appear on the screen followed by the firmware screen. Press Select on the remote to start the update process. (Use the down arrow followed by Select to cancel the procedure.) Wait for the update to finish; you do not want the power to go off during this time. The disc tray will open when the "Success" message is displayed. Remove the CD and press Select. The unit will restart. To check your firmware version, turn on the Blu-ray player with no optical disc in the tray. When you see the "No Disc" message, press eject to open the disc tray. Press the digits 7 8 0 4 in order on the remote. Look at the Revision number of the firmware.
Note: not all versions of the VBR100 can have the firmware updated. Also, Vizio no longer supports this model. There are some third-party sites that claim to have the file. Use caution; suspicious code can be added to the file by various parties.
I hope this helps.
Aug 04, 2016 | Vizio Televison & Video
Where can i find the driver for samsung yp-t7j
i would try this website for all device drivers that you cant find.
http://www.opendrivers.com/driver/233150/samsung-yp-t7jx-yp-t7j-firmware-v1.01-windows-xp-free-download.html
Sep 16, 2009 | Samsung Yepp YP-T7JX MP3 Player
YP-P2 FIRMWARE PROBLEMS
have u tried the reset pin on the back? give that a go.
Feb 12, 2009 | Samsung YP-P2 Digital Media Player
Samsung P2 - partial unbrick
go to samsungplay.com and download the firmware for the yp-p2LAB witht hat it will update images and everything else
Oct 26, 2008 | Samsung Yepp YP-P2 Digital Media Player
YP-T7J
how download music from my yp-t7j
Jul 19, 2008 | Samsung Yepp YP-T7JZ MP3 Player
I had the same problem!
But I found the fix for it after much searching.
First, download the latest firmware directly to your computer's desktop from the Samsung website: http://tinyurl.com/3j4su4
The file is a Zip one so : make sure you extract the 2 files to your desktop!
-Connect your P2 to your computer and go to My Computer.
-Double click the YP2 icon.
-Copy the 2 extracted files from your desktop into the open window. (Do not put them in an already existant folder).
-Unplug the connection from your computer and restart your player.
It will do an update and shut down. Restart it a second time and it will finish the second update.
- There you go, it should work no problem.
The firmware update from having your player connected to the Samsung Media Studio 5 for some reason doesn't work properly.
By doing in manually it works just fine.
The update link I provided is for a US based player.
Just go through the Samsung site to find an update for other contries if you need too and follow the same directions I give above to solve your issues.
Hope this helps!!!
May 17, 2008 | Samsung Yepp YP-P2 Digital Media Player
YP-U2J - Need download - Didn't come with CD
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
CLICK Here to Download : Firmware Update
In case u have WMP 11 and player not working, this error is common after installing Windows Media Player 11
Here is the instruction:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Jan 27, 2008 | Samsung YP-U2X Digital Media Player
Cannot use my player-device manager problem/deleting files
This error is common after with Windows Media Player 11
Jan 01, 2008 | Samsung YP-U2X Digital Media Player
YP-U2JXB & YP-U2JZW Won't sync...Help!
Error C00D1236 virtually always indicates one of two things:
1) The device is trying to sync hidden files--are there any?
2) There is licensed media that is being synced, and the license is either corrupt or has expired. If you have any licensed media, then try going back to where you purchased it (in an iTunes-like music management program? In WMP?) and refresh/renew the license.
The bad news is that until C00D1236 is resolved, you can't sync your device. frown.gif
You can bypass syncing, and directly transfer files, In my computer, the mp3 plaer will be shown as a drive.
Now if one of the two solutions above is not feasible for u, try this:
This error is common with Windows Media Player
Nov 22, 2007 | Samsung YP-U2X Digital Media Player
Samsung Yepp YP-T7JZ MP3 Player Logo
275 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
