Question about Sony SLV-998HF VHS VCR
Intermittent tuner operation
My Sony SLV-998HF has intermittent tuner operation that started happening out of nowhere. Sometimes the tuner works for a little while, then I start getting scratchy video and audio here and there, then goes out completely (blank screen). Stereo and SAP indicators will go out at same time as if signal feed was lost when in fact it has not been. Bad solder joint somewhere in or around tuner is the strong idea I'm getting, would just like more input from someone. I've heard bad solder joints are common with Sony. I've owned unit since new (1998).
    President:
  • 4,402 Answers
Have you tried to move the switch to channel 4 on the back of the vcr ( you will have to watch the vcr on channel 4)
Posted on Mar 17, 2008
VHS Stuck; Cover is off; nothing moves...wheels, tape...nothing...help
Unplug the unit, then plug it back in WHILE holding down the EJECT button ... The tape should come out unless there is a belt broken, missing, or loose.
I have used old, inoperable VCR's for tuners only as well. What happens if you leave the tape in all the time? Does the tuner work like that?
May 16, 2017 | Televison & Video
Sony slv-998hf has loose part
Look for a junker on eBay or similar. This reminds me, I have several machines I can sell for parts!
Nov 13, 2013 | Sony SLV-998HF VHS VCR
On my vcr slv-770hf on play back it jumps and rolls also the sound is low,records real good.
try using a head cleaning kit on the vrc. Or adjust tracking if needed.
Mar 04, 2010 | Sony SLV-998HF VHS VCR
I have a sony slv-d100 combo. DVD works fine, vcr NOT!
this is a mecanical problem, is some gears is broken.
Pease send to repair shop, to check
Nov 27, 2009 | Sony SLV-D100 DVD Player/VCR
Sony KV-27S10 has intermittent tuner issues. moving the cable connection on the back of the set sometimes clears the picture.
This was a common problem with the Tuners of these models. The replacing of the Tuner should fix the Problem. You may be able to order it from Sony.
Here is their Customer Service Number.
1800-222-Sony
I hope this helps,
Skyassoc
Oct 27, 2009 | Sony KV-27S10 27" TV
Hi! I'm looking for a user manual for my newly acquired Sony SLV-2000 VCR. I've Googled and gotten nowhere. Lots of dead-ends. HELP!
Problem solved. I went online and found a pdf file for the Sony SLV-R1000 manual. This manual works just as well for the Sony SLV-2000. I'm a happy camper...
Jan 08, 2009 | Sony SVO-2000 S-VHS VCR
VCR with intermittant audio and video problems
you have to connect VCR output cable to your TV input, thats all, it will be in series, if u want to record any program then on your TV and on record switch of your VCR.
Dec 30, 2008 | Sony SLV-N55 VHS VCR
Sony SLV-640HF Problem
I would be inclined to say that there are only two likely problems that you may be encountering. Either you are getting a bad signal feed, or the connectors on the cable are getting old and need replaced. The connection to the cable can break down over time, especially if they have been connected and reconnected several times. I cannot rule out problems caused by the transition to DTV, but that doesnt seem likely if there are only a few channels affected. As far as "selective failure" of the VCR's built-in tuner, I would say that that is also a very unlikely source for the problem If the tuning components inside the tuner had gone out, I would expect to see a problem on all channels watched through the system. If you are having this problem on all channels of the sony, then the tuner could surely be the problem, but if you haven't used it much that would indicate a problem at manufacturing, however since at least one of the machines is working fine on some channels and not on all of them, I would suspect the connections or the signal from your cable company. Contact them first ands see if they are having signal issues, if not try replacing your connectors.
Dec 26, 2008 | Sony SLV-N55 VHS VCR
Sony SLV-998HF VHS VCR Logo
110 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
