There could be an unbalanced load of laundry being washed or the drum bearings are loose and need to be tighten or the filter is blocked in your washing machine.
The drum may need to be replaced inside of the washing machine. The washing machine is making a loud noise while spinning then especially if it is either a clanking or scratching sound then there is some type of foreign material that could of had have gone into your washer's filter inside the rubber seal or is simply spinning around inside of it's the drum.
The bearing in the drum has failed and it's always noiier as it spins faster as there is more debris being thrown around inside the hardened steel casing of the bearing. Bad news is that's a write off. Uneconomical repair. It will tear its self apart shortly, probably leaking grease into the wash and leaving black marks everywhere, oor the drive belt will come off, or the drum will impact the front gasket and fill the drum with smoke. Any way you look at it, it's almost certainly going to destroy a load of washing. Throw it away now before it wrecks your washing
What kind of make and model washer do you have?
Your drum is off balance.
Is this happening with all loads or awkward heavy loads?
If the load is too big or heavy you have to stop the machine and adjust the load.
Can not give more info without knowing more.
Hi
Does this happen every time???
If YES... then the machine is not balanced on the floor well.... the 4 stands on which the machine rests have adjustable screws... You will need to fasten or loosen the nuts that will adjust the height of the legs on which the machine rests.... all the 4 legs need to be firmly on the floor .... If one is too high then the machine rocks on its side...
If NO.. only sometimes...
You are overloading the machine with heavy clothes... distribute your wash clothes by weight...
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out, believe it our not even washing machines have shockers to dampen the movement of the drum spinning
