Compaq Presario M2000 PC Notebook
Problem for Compaq Presario M2000 PC Notebook
Compaq Presario m200 Laptop system recovery
By ginge9146 on Jan 28, 2008
Hi I have a Compaq Presario m2000 laptop and need to restore it to factory spec, I dont think it came with recovery discs as I think they are partitioned on the hard drive. How do I do a system restore ? The operating system is windows XP
Comments:
Jan 28, 2008
- No I don't but I am not aware that I received any discs and thought these days that they were on the hard drive but partitioned.
Jan 31, 2008
- Thanks very helpfull, problem solved
Clarification Request
Posted by melnavz on Jan 28, 2008
Do you have any important files on the harddrive?
Same Problem
Sep 23, 2009
-   I am unable to delete partition in my compaq presario M2000
plz solve it
Thx & Regards
Rajneesh
-   rajneeshkamp
Dec 17, 2008
-   I havea Compaq Presario M2000 notebook that has had a Malware for the last 2 weeks ans I have tried a nuber of cleaning programs some work in Safe mode some do not.
I have been able to save files to an external hard drive and make sure thay are clean.
Now I just want to runa recovery disk or via a memory stick into my laptop and get back to running normal again.
Peter E (Australia)-   4peter
May 09, 2008
-   I have a Presario M2200 and also need the recovery disc, I installed a new hard drive and need the recovery disc to get the lap top to work, how do i get some how get the soft ware?-   BuilderJohn
Apr 12, 2008
-   I do not have the system recovery disk for my laptop. The Compaq Presario M2000 PC Notebook. The instructions said to complete a system restore restart computer and press F10 all this does is ask if I want to startup in safe mode. How do I do the system recovery to set things back to the factory settings?-   Joesafeen
Best Solution
posted on Sep 23, 2008
Very Helpful)
jouster146
Rank: Apprentice
Rating: 100%, 2 votes
i have a problem i want to restore my compaq m2000 to factory standard but i cant because my disk drive does not show up in my computer and when i try to use a disk it doesnt work
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jan 28, 2008
Helpful)
melnavz
Rank: Wiz  Compaq Expert
Rating: 84%, 728 votes
If you have important files then you should backup it first.
You insert the recovery disc and start with it. the system will runit automatically and restore the original one. Hoever im not sure if the 2nd partition will be affected.
You also insert any windows Bootable installation disk and from there, there is an option that you format only the C:\drive however if you have no important files on 2nd drive or d:\drive you can delete both the partion and repartition it with 2 partition drive.
more notes in installation windows is here: http://support.microsoft.com/kb/316941
hope this help,
Plese leave comment b4 u rate, Thanks! melnavz
Comments:
Jan 28, 2008
- Ok you can do the restorationof the original state of your system. just follow the solution above. however if you dont have any CD/DVD utilities u can doawnload it here: http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-002&h_lang=en&h_cc=us&h_product=212728&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us
just click the the model of your stuff.
thank you.
Was this helpful?
Yes
No
Solution #3
posted on Nov 11, 2009
Very Helpful)
lavanyaarora
Rank: Wiz
Rating: 80%, 34 votes
buy or download a windows disk. insert it and format the partition and install a fresh copy
Was this helpful?
Yes
No
Solution #4
posted on May 21, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
just did this last night actually
put in the windows os cd, and when the screen says press any key to boot from cd, do so
to restore to factory settings without creating a partition, you can choose to delete your C drive partition, after which it will automatically restart and install from the os cd. Then install all your drivers and you should be ready to go
Popular Solutions for Compaq Presario M2000 PC
Questions and Unsolved Problems for Compaq Presario M2000 PC
Do you recommend Compaq Presario M2000 PC Notebook?
Answer
Answer
MY presario M2000 notebook will not power on. Battery & power adapter has been replaced.I... (More)
Answer
when press the ON baton only the lights of num lk and caps lock blinks, no booting
Answer
splash screen shows desktop black compaq M2000
Answer
my compaq presario m2000 is too slow to charge what the problem?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Compaq Presario M2000 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
