Question about Sony Ericsson K310i Cellular Phone
My battery swell
I wonder why my battery swell, im afraid it will blow...thats why i didnt used it im using it for 10 months...then i figure out the battery swells...
  • lyxen Jan 28, 2008
    i didnt over charge it or charge it overnight, i just know why battery is like that, i didnt optimized charging, u think sony erricson has a low quality in battery?
Hi, Battery is calculated in Cycles and One Cycle is One charging & discharging. In ur case probly u might have used ur 300 Cycles. Most of the people do a mistake of keeping charging for whole of Night but when u talk about the cell phone if u keep in charging for the whole night unnessary Cycles are getting wasted. Mobile charge has a funda like it charges and over a time automatically it discharges as well. so don't keep it in Over night charging. U need to replace the battery. Else u will not get a perfect back up. Madhu AVN
Posted on Jan 28, 2008
What are the side effects of Coveram 10 mg?
The more common possible side effect of this blood pressure medicine (not in everyone though) are
  • dizziness.
  • cough, often described as dry and irritating, shortness of breath, discomfort on exertion.
  • oedema (fluid retention)
  • swelling of hands, ankles or feet, joint swelling (ankle swelling).
Nov 22, 2017 | The Health & Beauty
I need help figuring out how to fix the blower on my son's Elefun ball popper. The music plays but that's all it does.
Tell him to wear a hard plastic insert in a jock strap. The swelling will go down in about 10 days.
Sep 09, 2016 | The Toys
Replacement due to battery swelling?
this indicates that the wrong charger was used for the battery type
it is a result of too fast a charge or the wrong charge (metal hydrox batteries against nicad batteries )
Sep 04, 2015 | Tablets & eReaders
I seen a comment of yours on another ? about brake fluid contamination and my 05 silverado has all brakes locking up. i had put power steering fluid in once a couple months ago due to a line blow-out to...
Well, all rubber seals/components will have to be replaced this includes but not limited to calipers, master cylinder, wheel cylinders, ABS unit... and the system most be flushed. The used of petroleum based fluids is a no no cause the rubber components in the system are not compatible therefore causing the rubber to swell and the brake system to fail.
Apr 14, 2014 | 2005 Chevrolet Silverado 2500HD 2WD
I have a razor 300 i charged overnight wheel turns but wen i get on it it wont pull my weight im 10 yrs old but it works wen walking at side ov it please help
check your charger and batteries with a multimeter and make sure that they are showing the proper voltage, also visually inspect the batteries for bulging or swelling, probably one or both of the batteries are bad
Jun 10, 2012 | Razor E200/300 Electric Scooter battery -...
It has not been used in a year charged it and when u go on it not going
check your charger with a multimeter and make sure that its putting out enough volts, also inspect the batteries for swelling, if they are swollen chances are they might be bad
May 15, 2012 | Razor E100 Electric Scooter
The inlet drain light and rinse aid light have both come on and the dishwasher is humming but not working. Any suggestions?
Hello Mark,
You didnt say so but i think it is a Miele dishwasher,its the only brand i know of with a Intake drain light
A fairly common occurence with Miele dishwashers is the seal on the pump/motor assambly swells up freezeing the motor.Miele makes tool to free it up very easily,if it doesnt reoccur the seal just swelled and it will be ok once freed up.If it does reoccur the seal needs to be replaced. Any Miele authorized service company will have this tool and could free the motor up within 5 minutes and only a couple uses will tell if it will swell again and need to be replaced, if you contact via their website,they may send you that tool. To use it remove lower rack and pump filter and insert into the side of the pump hole(you will be able to see that hole with the filter removed) and rotate it back and forth at first it will resist then should quickly break free,if it is had to turn the pump/motor seal kit would need to be replaced.
Aug 07, 2011 | Dishwashers
Battery swelling , seems like over charging
Feb 21, 2011 | 1990 Yamaha XT 600 E
Razor e300 batteries are bulging. Is that normal?
Bulging battery means u have to replace it, the plates started to oxidize and pushes the everything out!
Nov 09, 2010 | Razor E300 Scooter
The hot air won't circulate to upperstairs
2 possible causes. 1 there is a blockage in the ventilation system (possible collasped ductwork) or 2 the fan motor is going out. The motor could be going out due to the winding swelling as the motor is run heating the winding causing the windings to swell slowing the motors rpms.
Feb 22, 2010 | Bryant 463AAC005BA Air Conditioner
Sony Ericsson K310i Cellular Phone Logo
247 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
