It's very easy. attach to PC and drag and drop albums in folders to the player (probably shows as drive 'E' or 'G'.
safely remove from PC and then insert headphone. press the pause/play button on the back to play.( a blue light will show-make sure to charge it up well on the PC!!)
press the track forward or track back to change tracks. hold these to higher and lower volume.
will turn off automatically on pause after a while( blue light will go out)
I BOUGHT MY SON A BEN 10 MP3 PLAYER AND THERE IS HARDLY NO SOUND COMING OUT OF THE EARPHONES....WHAT CAN I DO?
If you haven't solved this problem I have just been on the phone to the manufacturers and have the solution.
Plug the MP3 player in and then load windows media player. (You need to make sure the songs (at least 1) is loaded onto media player first) then click sync on the top toolbar it should show that there is a device connected in the top right corner. Now drag your song to the box below the device and then press sync. Disconnect the device and it should be there. Now when you plug your mp3 back in you will be able to just drag songs into it on through the usual my computer. Hope that helps
Turn it up by holding down the next track button.
