Question about Whirlpool GU2400XTP Built-in Dishwasher
Will not start wash cycle
I installed our GU2400XTP dishwasher last week and it worked fine--no problems. For unknown reason, it stopped working yesterday. The electronic touch screen lights up and accepts all cycle commands, however it does not Start the wash cycle. I have tried the "Cancel/Drain" button several times. It cycles for the 2 minute cycle, which should clear all problems, and turns off when the cycle completes. However, it still will not start for new cycles. Our 2-digit display does not show any errors.
  • 72 Answers
The circuit boards on these types of units are kind of finicky. If there is any seepage of the steam generated by washing that gets into the door skin, then it can toast a circuit in no time flat. It is more than likely the momentary switch but the only way to find out is to remove the inner skin, pull the board, and look for toasted components and check continuity through said switch.
Posted on Jan 28, 2008
Whirlpool quiet wash plus dishwasher
Sounds like the timer module is going bad. Might be getting moisture on contacts. That would explain why it works one time and not the next.Just trying to help!
Aug 14, 2013 | Dishwashers
Starts but will not go into wash cycle
My solution to this problem was to simply unplug the power from the wall for a few seconds...plug back in, try to cycle again and the wash cycle starts fine now. May have been caught in a cycle loop or something. Any way this solution worked for me hope it works for someone else.
May 23, 2010 | Whirlpool GU2400XTPS Built-in Dishwasher
My dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Dec 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
Is the right cycle selected? Refer to the “Cycle Selection
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Please remember to leave a rating.
Oct 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold Quiet Wash Plus GU940SCGZ3
Press the cancel button, Then cut power to the dishwasher for a period of time. restore power to it then try a cycle.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Start light blinking
Test mode is Heated dry - Normal - Heated dry - Normal in 6 sec....
does it blink slowly or three time or fast or 7 times then repeat... let me know and I can help
Jul 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Problems with Whirlpool dishwasher model GU1500XTKB0
have they checked the thernals on the bottom of the tub
Mar 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Error code 2H.....or stops on last minute
I don't think you'll find it's the control board.
I think you'll find it's the heater box.
Not an easy job to do yourself unless of course you know what you are doing.
I would suggest you contact Bosch. One other possiblity is that the water inlet is blocked, although to be honest this is very rare.
Deep Diver
Dec 31, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Whirlpool GU2400XTP Built-in Dishwasher Logo
213 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
