Question about Rosen inVUE II Video Ent. Sys '00-'02 Chevy Suburban w/o Sunroof
'02 monte carlo ss problems
My monte carlo has started shaking when i drive.. and it gets worst if you give it more gas, or turn right. help please!!!
  • Marty marty May 11, 2010
    one of the front wheels is out of balance- get it re-balanced
  • 2,039 Answers
If you give gaz its shake if you let go the gaz does it still shake if it still skake it probably wheel balance if it shake in the stering its the front if you feel it in our seat its the back but if it vibrate only when you give gaz it could be a cv joint or universel joint cheers
Posted on Jan 28, 2008
Hello. i have an 02 monte carlo ss when I try to start it all the regular lights come on but when I try to crank it it doesn't do anything. I tried to jump it but that didn't do anything. please help.
Look for a light on the dash that says SECURITY the next time this happens. It is a common problem with an easy fix.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Oct 11, 2013 | 2002 Chevrolet Monte Carlo
02 monte carlo ss engine fan want start
There are three relays and two fuses that power the radiator fans.
The computer grounds the relays to make the fans come on.
Have you checked the fuses and relays for power ?
Feb 25, 2013 | Cars & Trucks
Oil gauge on a 02 monte carlo ss when the engine is started up the oil gauge goes from L to H & when i idela thje engine it stays on HIGH /
Have your mechanic check the oil pressere with a scanner or a manual gauge if pressure is different from gauge it needs a sender or the gauge needs replaced
Oct 20, 2012 | Cars & Trucks
Oil gauge on 02 monte carlo ss
Sounds like the oil pressure sending unit is bad.
Oct 19, 2012 | Cars & Trucks
Test window switch left side monte carlo ss
I recommend that you will post your question under the correct category (Cars & Trucks) and maybe add more details to it, so it will be easier for Experts to understand the question and answer it.
Aug 25, 2012 | A1 Cardone 2002 Chevrolet Monte Carlo Air...
How to test window switch on 02 monte carlo ss
It should have power and ground in both directions. The switch makes the output to the motor opposite for each direction. I use a test light to check the circuits.
Aug 25, 2012 | Cars & Trucks
03 monte carlo ss won't start after driving a
If you are driving the car and it wont start after driving awhile. Do a wiggle on the CKP (crank position sensor) this sensor is located at the front main engine pulley, I am seeing a lot of loose male to female connection shut car off.
Feb 28, 2012 | 2003 Chevrolet Monte Carlo
Car Audio & Video Logo
196 people viewed this question
Top Rosen Car Audio & Video Experts
Jerry Naidoo
Are you a Rosen Car Audio and Video Expert? Answer questions, earn points and help others
