Question about Sony KV-35S45 35" TV
Sony KV-36HS20 Hello my tv won't come on i can see the red light flashing 7 times and i can hear the clicking sound when i press the power bottom but the tv won't come on, i was wondering how expensive it could be to repair it and if it.s woth doing it. Thanks
  • Anonymous Apr 19, 2008
    i press the power button but the tv shuts of and the timer standby red light is blinking.but i can here the clicking when in push power button
    President:
  • 4,402 Answers
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Posted on Jan 28, 2008
6ya staff
SOURCE:
I have a sony wega trinitron, when the tv is turned on, (no visual, or sound) the red stand by light blinks 7 times, and you hear the tv click off? Please help
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Jun 06, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a Sony Wega KV-34HS420 TV that takes several tries to turn on. When I push the power button or remote power on I hear the normal click and the sound comes on for 3-5 seconds but then I hear a second...
Since the set appears to "recover", it suggests either a poor solder connection or bad cap somewhere in the power supply. The 7 blinks indicate the problem circuit is in the horizontal area. Check the regulator (STRxxxx) IC in the power supply. If you do not have experience working with TVs, please refer this repair to a shop. The regulator IC costs around $25.
Dan
Nov 16, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have a sony 32'' I think. model # KV-32FS10, serial #8047927, made Jan 2000. During a move, the tv was dropped and now when you press the power, your hear the click, the red click light flashes...
It sounds like that in the drop you may have cracked the main PCB. The PCB's usually crack around the heaviest part of the PCB. Probably around the flyback transformer.
Oct 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power clicks on and red power light flashes but no picture
The problem might come from the fuse inside was blow out. if you have a multimeter then open the rear cover. The fuse lays near the power cord. Take it out and use Ohm meter to check it connectivity. If it is no connectivity meaning the fuse was blow out. Replace a new one with the same value (Ampere and Voltage). If it does have connectivity, the problem needs technician to find out as it relates to many parts on the circuit board.
Aug 11, 2009 | Sony KV-27S46 27" TV
Sony wega kv-36hs20 will not turn on
Mar 02, 2009 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Sony vega kv-36hs20
Have just posted this - twice, elsewhere - I'm afraid the sets are getting old:
"I think you are either suffering from a failed power supply or the supply is cycling because of a 'downstream' problem that could be in the high voltage circuit. In each case, the blink count probably would tell you approximately where the problem is located but only a Sony tech will have access to the codes. After all, we are only mortals.  "
Aug 25, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Jul 03, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
PLEASE HELP QUICK! 36" Sony blinking 4 red times
probably this is the small mailfunction,probably some contacts,but you probably not a qualified to do this repair ,so please call a service man
Feb 07, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Tv wont turn on
How many times does the light flash, as there is a code that can give an indication as to what circuit is bad.
Jul 15, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KV-35S45 35" TV Logo
164 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
