Question about Lanzar SVD26MUT Car DVD Player
Phase linear uv8
How do i get my new ipod nano to play videos on screen of radio
  • Steve Corey May 11, 2010
    Whats the model number, brand and does it already play dvds?
    Problem Solver:
  • 10 Answers
One thing to note about the adapter. Apple uses a different standard from the rest of the world. For some reason, they swapped the video with one of the audio RCA plugs. If you use an 'ipod' 35mm to RCA adapter, you won't have a problem. If you use a generic adapter, you will have to swap the video and one of the audio RCA plugs. I don't recall if it was the right or left.
I ran into this again when I tried to use my 'ipod' 35mm to RCA adapter for my camcorder. It didn't work until I swapped the RCA plugs.
Not sure why Apple chose to do this. Kind of gives me a bad feel for an otherwise good company.
One other comment. I tried connecting an external camera to the front 35mm jack on my Lanzar unit. It didn't work. I don't know why. The manual doesn't talk to this connection. However, they supply an audio/video/RCA adapter for the front AUX plug. maybe it was just my unit. I had a problem connecting my audio ipod to this at one time and had to get it fixed. Maybe they didn't fix the video part.
Good Luck
Posted on Apr 21, 2008
  • KariSue Aug 14, 2008
    The key here is 'NANO'. The new nano's will play video. However, they don't output video to an external screen. I've tried this and it doesn't work on any TV I have including the Lanzar. If you ask 'google', you will see others that have noted this problem. Audio out works fine. You need a standard ipod for video out.
I have an indash screen with the box to the screen under my passenger seat...i bought one of the home kits to hook an ipod to a television i bought an adapter to plug the home kit into my car...because my box only takes rca and the homekit was set up for s video i bought a cord off-line...there may be a cable out, but make sure the cable hooks to the bottom of the ipod not the top
Posted on Apr 05, 2008
    Champion:
  • 227 Answers
Assuming that your unit have a rear video/audio input, you need an adapter cable. 35mm to video/audio rca. You may find one on Ebay or RadioShack. Goodluck.
Posted on Mar 08, 2008
Phase linear uv8
Hola Hope this might help a little. You may have to read. Sorry, I can\'t post too many pics or video, but this link should help I hope. The link provides details and goes over the wiring. If not, google it or check on YouTube.
Instruction Manual - Page 1
http://www.helpowl.com/q/Jensen/UV8/Technical-Support/phase-linear-uv8-schematic/9778
May 10, 2013 | Audio Players & Recorders
Linear phase uv8 and letting my kid watch movies while i drive
You can let your kidwatch DVD but not while your driving unless the screen is out of the view of the driver
Feb 17, 2010 | Phase Linear UDV9010 Car DVD Player
No cd audio from my phase linear uv8
It sounds like you have a factory amp in the vehicle. Check behind the radio to see if you have the blue wire from the deck hooked up to anything. You probably do. So take the blue with white stripe wire coming from the deck and hook that up instead of the solid blue wire.
Jan 20, 2009 | Phase Linear UDV9010 Car DVD Player
The UV8 needs to use The Pink wiere to play an CD audio?
I got through to tech support. For problem of no audio from DVD or CD (can only hear radio), reverse the Blue wire (power antenna) and the Blue/White wire (external power amplifier). This should solve the problem.
Nov 26, 2008 | Jensen VM9510 Car DVD Player
Have no sound when the cd and dvd is played
you have a factory amp in your vehicle so what you need to do is take out the uv8 and make sure the remote wire from the unit " blue and whit stripe " is connected to the remote wire of the car harness.
the way you have it now is the power antenna wire " solid blue " the is connected to the remote wire of the unit
Oct 29, 2008 | Jensen VM9510 Car DVD Player
Phase linear UV8 gone crazy
the disc in my phase linear wont play
Sep 02, 2008 | Car Audio & Video
Uv8 problem!!!! please help
Ipod controls usually go to the cd changer input or auxiliary input. They might have just updated the the looks but usually the inside is the same, especially if they have the same model number. By the way you can get that ipod cable really cheap on ebay.
May 21, 2008 | Jensen VM9510 Car DVD Player
Phase Linear UV8
I have same problem with same uv8 but i use remote to activate am/fm then hit setup on rem.enter 543210 and a new menu came up. ( listening for the beep after each 3 is pressed ) select the hammer in upper left hand corner of screen, select brake bypass to on, then hot the X near bottom os screen. this works for me it should work for you.
Jan 11, 2008 | Jensen VM9510 Car DVD Player
Phase Linear UV8
go to setup hit 543210 but hold 0 then turn the bake override on and then hit the X
Dec 11, 2007 | Jensen VM9510 Car DVD Player
Lanzar SVD26MUT Car DVD Player Logo
180 people viewed this question
Top Lanzar Car Audio & Video Experts
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
