Question about Roper RAS8445KQ Top Load Washer
Roper washer will not drain water
Do you think I should just replace the machine or if it will be around $100 to fix? What should I do?
  • sirrod6 Mar 24, 2009
    washer will not drain nor spin, stops after wash cycle
    Scholar:
  • 72 Answers
It shouldn't be much more than 50 bucks to find a new water pump for it. That's the worse case scenario. It may be nothing more than a clogged or pinched drain hose or a contact not making on the selector/timer switch. Take the back cover off of the head unit, after you unplug the machine, and there should be a sticker with the schematics of what contact makes when the drain cycle engages. Make sure it is clean, and if not, then use an emory board or cloth to clean up and make sure you get continuity through it on a dry run. Reassemble and check for voltage at the pump when it goes through the cycle. Should be at the motor on bottom of the unit opposite the tranny.
Posted on Jan 28, 2008
Roper top loading washer RTW440VQ1 will not stop filling up
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 22, 2012 | Roper RAX4232KQ Top Load Washer
Roper top load washer spins but does not drain water and smells like rubber burning
replace coupler for direct drive whirlpool washer yes roper is a whirlpool washer #part number 285753 you can watch video on youtube to replace
Jan 24, 2011 | Roper RAS8445KQ Top Load Washer
Roper RAX 5133AWP WASHER WONT DRAIN
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Jul 12, 2009 | Roper RAS8445KQ Top Load Washer
I have a Roper brand top loader washer and it fills up but it won't drain or spin.
If the motor doesnt run during the spin cycle and the tub stays full of water. You need to replace the lid switch. This is very common problem. The part should be around 35 bucks. Easy fix.
Jan 30, 2009 | Roper RAK2751WWH Top Load Washer
Amana washer broken, won't drain and sounds like machine gun
Sounds like the transmission is bad. To tell the truth the roper is a way better machine. Whirlpool makes roper and they are basically the same machine so it isnt even a cheap washer. Its a great machine! Better than the amana to start with!!!!!!!!!!!!!!
Nov 21, 2008 | Amana Washing Machines
Agitater spins around, water won't drain.
The model number is located under the lid.
Nov 17, 2008 | Roper RAS8445KQ Top Load Washer
Roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Nov 08, 2008 | Roper RAS8445KQ Top Load Washer
Washer will not spin or drain water
I have a roper washing machine model RAB 2121kw and about a year ago it did the same. I was at the machine when it tried to spin one day and i opened the lid and spun the drum by hand a few times then shut the lid and slowly the drum started spinning. One problem is that i have just moved the washer and i now have an oil leak. When the drum wouldn't spin i think the motor heated the oil seal on the gear case and now it leaks. I have looked into it and don't think its that hard of a thing to change.
May 24, 2007 | Roper RAB2121KW Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
112 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
