Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FS12 32" TV
When powered on, > > hear > > high voltage for a second, LED blinks 3 times, relay click, then LED > > blinks 4 times over and over as long as power cord remains plugged > > in.
  • chris theodosis Jan 28, 2008
    Hello, I am not a "tech" I fixed a couple of tvs hvbs and flybacks mostly. How diffacult is it to fix?
  • chris theodosis Jan 29, 2008
    Hello could you give me the part numbers for the 2 solutions Thanks you
    Novelist:
  • 123 Answers
Hi
          It is a problem of high voltage transformer.Better change it.
                             or
High voltage supply is what give the high voltage power, consisting of components. You ask for this or do you mean you need the High Voltage Transformer or another Item on the board? Do not understand!!
                             or
    Test the Switching Transformer
SMPS switching transformers, like flyback
transformers, are high Q transformers.
They are responsible for transferring a
large amount of energy in a short period
of time. A single turn short will shut down
the SMPS. Be sure to use the patented
Sencore ringing test to test any suspect
switching transformer.
                   or
call - 1-800-736-2673(toll free)
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Posted on Jan 28, 2008
    Genius:
  • 1,665 Answers
There is a user manual below: It maty contain usefull info.
http://www.nodevice.es/manual/sonymans/manual3536pdf/get5052.html
  • 689 Answers
Four blinks actually a code that indicates power failure. There are several possibilities; Either power supply's component malfunctioning (e.g. dried/blown capacitor). Within the main circuit a failed component might be taking over current. Best diagnostic can be done by a qualified hands on technician by isolating the circuits and testing individually. If you are a tech please let me know so I can give you some instructions.
  • 2,336 Answers
This condition be directed us toward pin modulator transistor Q504 which may shorted. Parts necessary to fix this unit may be D501, D504 and Q504.
Check this site if you need the schematic diagram: //http://www.eserviceinfo.com/downloadsm/19977/SONY_KV32FS16.html
Good Luck.
I have a sony wega trinitron, when the tv is turned on, (no visual, or sound) the red stand by light blinks 7 times, and you hear the tv click off? Please help
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Jun 06, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
Try to remove the vertical IC sometimes it become Shorted causing the B+ to drop. after removing try to switch on back check the B+ if ok and the LED not blinking then change the vertical IC.
Jun 01, 2009 | Sony KV-27S42 27" TV
Sony kv-32sf12 -will not power "ON
Try the 60 seconds unplugging of wall plug in your outlet. Or check your line if this have surge protector. Temporary plug your unit to wall outlet directly. Just check if it still within voltage operating range.
May 10, 2009 | Sony KV-32FS12 32" TV
Cannot power up my Sony Trinitron KV-34HS510.
makes a noise
This doesn't tell us much; is it a click or a sharp snapping sound?
The first can be a relay turning on, the second is most likely related to a high voltage discharging.
If it is a relay, then the set could be trying to protect itself from an overload or the power supply has failed; the blinking ON LED is pointing toward that.
If it is a high voltage discharge (you may be able to see it through the vents in the rear housing) then it is possible that an accumulation of dust and household airborne contaminents has created a path that can be removed with some targeted cleaning.
Dec 04, 2008 | Sony KV-32S45 32" TV
Sony KV-27FS100 No Picture
Check Horizontal Output Transistor, if found bad / short, replace it.
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-32FS120 blinks 4 times
good day.
Have you tried first resoldering the terminals in the circuitry?
Also, try to check for the ABL supply near the flyback. Watch out for the small voltage zener diodes.
response is highly appreciated.
chris
Mar 26, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Kv24fs120 dead set with two led blinks
Two-blinks of the "Diagnostic STANDBY/TIMER LED" indicates one of two things:
1) Horizontal Output (Q502) in shorted on the A-board.
or
2) IC702 is shorted (CB board)
Two-blinks of the diagnostic red LED is a " B+ Overcurrent" problem.
The red LED will blink 2-times, stay off for 3 seconds, then blink 2-times. The cycle repeats.
The circuit board is quite delicate. One should not attempt repairs (unless one has high quality vacuum desoldering equipment such as a PACE desoldering unit).
Feb 01, 2008 | Sony KV-24FV12 24" TV
Sony KV-36HS20
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Jan 28, 2008 | Sony KV-35S45 35" TV
KV-32FS120
Seven Blinks: High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into shutdown. Check power supply and horizontal circuits.
Culbert Communications
New Brunswick, Canada
Nov 23, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
141 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
