Question about Adobe Photoshop 7.0 for PC
Photoshop how to improve the light setting for more dark photos
    Scholar:
  • 70 Answers
If you use Adobe Photoshop, open your photo, then menu Image --> Adjustment --> try to set the Level or Brightness/Contrast.
With other software, more or less the same menu
Posted on Jan 28, 2008
    Problem Solver:
  • 10 Answers
Please try rephrasing this question. Do you want dark photos to become lighter, or light photos to become darker using photoshop? You are not clear.
-Potter4
What is the purpose of photoshop
Well, it is a way to modify all the different aspects of a digital photo file. Basically, it can improve the look of pictures a great deal. At a more advanced level, you can remove or add things to photos, replace or remove backgrounds, or create artistic paintings and collages. If you want to simply improve regular photos, Picasa freeware is much easier and more satisfying.
Feb 18, 2015 | Adobe Photoshop 7.0 for PC
How can increase the resolution on a photo
Technically you can't improve the resolution. Photoshop or similiar photo editing programs can improve the picture to some degree .
Oct 11, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
PICTURES ARE BLACK
6 Ways To Fix Too Bright and Too Dark Photos
Recompose The Photo This is probably the simplest solution. When taking a photo of a scene with very bright and very dark parts, move your camera to eliminate one of the extremes. In the case of the band, I would have either closed the curtains for the shot, or recomposed completely and photographed from the window looking at the band, and the crowd behind.
Use Exposure Lock If you can't recompose the photograph, instead tell the camera what part of the image you would like to see. The rest of the photo will be either over or under exposed (too bright or too dark) but at least you will see your subject. You can dothis by placing the center of the image at your subject; half depressing the shutter to lock the focus and exposure; move the camera to re-compose the image; and fully depressing the shutter.
In the band image, the camera chose to correctly expose the scene outside, but even if the band member had been correctly exposed, the window would have ended up being over exposed and you would just have seen white.
Some cameras have an option called 'spot metering' to set the part of the image you'd like to be correctly exposed. If your camera has this setting, enable it before using the technique above.
Use Fill In Flash If your scene has a sunny background, but your subject is in the shade (or has a hat on), turn on the flash (as I explained way back in tip number 9 - Using Flash During The Day). I know it seems wrong but it really does work! By using the flash, your subject will look as bright as the background. This would have worked well for the child shot above.
High Dynamic Range Imaging This technique is not for the faintof hearted. It requires a subject that does not move; a good camera with the capability to set the exposure and output RAW images. A tripod and image editing software like Photoshop CS3 are also needed.
High Dynamic Range Imaging (or HDR for short) is a technique for placing both very dark and very light areas in the same photo. It requires you to take a number of photographs of thesame scene - each with a different exposure. First take the shot using the camera's recommended settings. Then, in manual mode and keeping the aperture at the same value as the first shot, take a sequence of shots - each shot having a different shutter speed (above and below the original). You'll have 5-9 shots of the same scene all in different exposures.
Merging the three images to the left creates the HDR image below. Thanks to Photomatix for the images.
hdrmerged.jpgNow import these into your favorite paint program. I use Photoshop, but you can as easily use a cheaper program designed specifically for HDR photos like Photomatix. Follow the HDR directions and the paint program will merge these images into one great looking shot!
Use a Filter If your scene is of a brightsky and a dark ground (for instance at sunset, or on a cloudy day), you can use a graduated neutral density filter. This filter cuts out someof the light from one part of the photo (the sky). This will correctly expose the ground and the sky without needing to use HDR. These filterscan be complex to setup, so I don't usually recommend them for beginners.
Fix The Original Photo in an Image Editing Program twobright2.jpgFinally, if you can't take another shot at the same location, you can fix the original image by changing the levels using a paint program. This works best when your subject is darker than the rest of the photo (because cameras lose detail in over-bright areas). I've brightened the band member in the top image using this technique and while it looks okay in thissmall shot, this technique can tend to amplify any noise in the image. The darker the subject, the harder time you will have fixing the image.
I discuss exactly how to use this technique in lesson 2 of my free Image Editing Secrets course. I have a tutorial for Photoshop, Photoshop Elements, Paint Shop Pro and the free Google Picassa.
- See more at: http://www.digital-photo-secrets.com/tip/140/6-ways-to-fix-too-bright-and-too-dark-photos/#sthash.58eENOTt.dpuf
Jul 09, 2014 | Nikon D3000 Digital Camera
I have old poloroid pictures that are really dark Can I lighten them???
Yes! but first you must scan them into the computer and open them in a photo editor application like Photoshop. There you can do a whole world of editing including lightening your fotos.
Good luck and god bless!
Mar 01, 2011 | Polaroid Office Equipment & Supplies
Photoshop elements 6 will not paste photos
Check your firewall settings, that is what blocking your copy accessing restriction.
Dec 17, 2009 | Adobe Photoshop Elements 6: Windows
Dark picture of furniture with flash
set the lighting settings and the flash settings to auto. you will be able to get an optimal picture everytime.thanks for using fixya! please dont forget to rate my solution.
May 29, 2009 | Olympus C-3000 Zoom Digital Camera
SELPHY printing too dark
I have some experience with color profiles, after trying to fix this problem by changing the profiles in Photoshop, letting the printer manage color, leting PS to do so, and every possible thing.... I found that increasing brightness, and 2 points of saturation on the printer dialog pretty much prints what you see on the iPhoto screen. I have the Selphy 740 not the ES1, but might be the same....  abee9c5.gif
May 08, 2008 | Canon SELPHY ES1 Thermal Photo Printer
Constant blurry photo's!
the solution to this is that your cameras are set to power save just put powersave on off temperarly while you snap a photo or the lighting in the room needs to be brighter with digital cameras even though theres a falsh it cant change the image contrast from dark to light so quickly so it just comes out blurry
Feb 28, 2008 | Samsung Digimax S730 Digital Camera
Photoshop and the R1800
I had the same problem and read everything I could find about it. Finally after tinkering around, I discovered that printing everything using "Photo Enhance" setting produced the best pictures. Also, I use a calibrated monitor and print through Photoshop Elements 5. Lots of Luck! Cyndy
Jan 28, 2008 | Epson Stylus Photo R1800 InkJet Printer
Adobe Photoshop 7.0 for PC Logo
59 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
Laxman Bisht
Laxman Bisht
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
