Question about Whirlpool LEQ9858P Electric Dryer
Dryer door won't close
I had a bunch of lint inside the drum of my Whirlpool model LEQ9858LWO electric dryer. Leaned into dryer to remove it. I must have been leaning on the dryer door when I did not realizing it of course. When I went to start the dryer the door would not close all the way. I did push the accutuater (spelling?) switch and the dryer comes on. But the door just won't stay closed on it's own. I know I can fix this myself somehow and avoid a big service call bill. Any help here? Thanks so very much!
    Scholar:
  • 72 Answers
You probably bent the hinges if you can't see an actual crease in the door. Just pull the screws out of the hinge where it meets the door, and using a large pair of channel locks manipulate the hinge back to it's proper alignment, stopping to put door back on every once in a while to check it. Simple as that. You may have to flip unit over on it's back if the mounting screws for the hinges are not accessible.
Posted on Jan 28, 2008
6ya staff
SOURCE:
How do I get into my whirlpool duet front loader dryer to clean the lint out
Hello. First, turn the power off to the dryer or remove the power cord from the AC outlet. Next, locate the 2 screws in-between the upper and lower front panels and at the bottom front of the dryer--there will be 2-3 screws, usually 1/4 inch hex head, and remove them--use a magnetic nut driver, it makes it a whole lot easier! (note:sometimes, to replace the panel, you have to push up on the bottom of the panel hard to get the screw holes to line up again.) Set the panel aside. Open the dryer door and remove the lint screen from the holder. Close the door. Next, notice the blower housing cover, pic 3, #45, lower left corner. There should be 3-4 screws holding the cover to the blower housing. Remove the screws and cover--use caution--most metal edges inside a dryer are unfinished and razor sharp--akin to putting your hand inside a box of razor blades(ask me how I know this, lol). Remove any lint build-up inside the cover with a vacuum. Again, using a vacuum, suck out any lint from inside the blower housing and fan as best you can. Take care to not damage the fan blades! Now, try to remove as much lint build-up as you can with the vacuum. Be especially careful when vacuuming around the mouth of the heater element. Do the best you can. At this point, re-assemble the dryer using the reverse of assembly. If there is still a lot of lint inside the cabinet and you can't reach it--STOP! In order to remove the remaining lint requires removal of the front bulkhead(large metal plate that supports the front of the drum), drum belt, and drum from the cabinet. This is INVOLVED and can be very difficult to re-assemble if you have never done it before. Call for service. I hope I helped you!
Oct 02, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whilpool dryer LEQ9858LWO takes to long to dry
Have your checked your lint screen? It could be clogged if you use a lot of fabric softener. Take it out and wash it using a stiff brush to remove the waxy buildup on the screen.
Apr 02, 2013 | Whirlpool LEQ9858P Electric Dryer
My Whirlpool gas dryer is not working
Instructions
Check that the dryer door is closing completely. Remove anything that blocks the dryer door from closing.
Ensure the "Start" button is pressed firmly to start the dryer cycle, the dryer is not overloaded and the clothing is not balled up. Any of these things can prevent the dryer from operating and/or drying the clothes.
Use a level to confirm your Whirlpool dryer is sitting flatly and evenly on the ground. Adjust the dryer as necessary for it to be level as the dryer will vibrate and make unnecessary noise when sitting unevenly.
Examine the inside of the Whirlpool dryer drum and in the space around the drum for loose change, pens, hair ties and other items that could have been left in the pockets of clothing. These items will cause noise and potentially cause the dryer to become inoperable.
5
Examine the Whirlpool dryer's lint trap for excess lint. Remove any lint from the trap and place it back into position. Always clean the lint trap between dryer cycles. Inspect the area around the dryer and in the ventilation and exhaust systems. Remove any built up lint and clean the area thoroughly. Built up lint is a fire hazard and can cause operating issues.
6
Check the gas shutoff valve if your Whirlpool dryer is gas powered. Ensure the shutoff valve is turned all the way to the "On" position.
7Check the electric plug and ensure it fits securely in the outlet.
8
inspect both the fuse box and circuit breaker for any electrical problems. Replace any blown fuses, if necessary, and reset the circuit breaker if it has been tripp
Jan 09, 2013 | Whirlpool Dryers
The belt attached to the blower wheel on my Whirlpool Cabrio dryer has come off. How do I reattach it?
Unplug the power cord of the Whirlpool dryer from the electrical outlet before installing a new belt. Remove the lint filter from underneath the lint filter cover. 2 Unfasten the screws underneath the lint filter cover with a screwdriver, setting the screws in a safe place. Slide a putty knife between the dryer top and the cabinet near the front, lifting up on the knife to detach the top from the plastic clips on the cabinet.3 Flip the dryer top back against the wall so it is resting on the rear hinges. Locate the screws on the inside of the upper front panel near the top.4 Unfasten the screws on the inside of the upper front panel with a screwdriver. Lift the panel up off the metal clips on the front of the dryer cabinet. 5 Unplug the door switch connector from the back of the upper front panel by hand, setting the panel out of the way. Slide the putty knife between the lower front panel and the dryer cabinet, pulling the knife away from the cabinet to detach the panel from the plastic clips on the cabinet.6 Place a couple of wood blocks under the lip of the dryer drum to hold it in place. Locate the idler arm near the motor at the base of the dryer.7 Move the idler arm forward to relieve the tension on the belt. Take the belt off the motor and idler arm pulleys, lifting the drum up and sliding the belt off the drum.8 Install a new belt around the dryer drum, looping it over the idler arm and around the motor pulley. Move the idler arm back into position to add tension to the new belt.9 Remove the wood blocks from underneath the lip of the dryer drum. Plug the door switch connector into the back of the upper front panel by hand.10 Slide the upper front panel over the metal clips on the front of the dryer cabinet, securing the top of the panel with screws. Fasten the lower front panel to the front of the dryer cabinet, pressing the panel onto the plastic clips by hand.11 Flip the dryer top back down onto the top of the cabinet, pressing down to secure the top to the plastic clips on the cabinet. Fasten the screws underneath the lint filter cover with a screwdriver.12 Slide the lint filter back under the lint filter cover by hand. Plug the power cord of the Whirlpool dryer into the electrical outlet.
  • Oct 11, 2011 | Whirlpool Dryers
    How do I take off the back to get to elements and fuse on my kenmore elite dryer, I took screws off but the top appears to be welded.
    Getting to the heating circuits is not the same on every model of dryer. Some dryers have heating circuits in the REAR of the dryer, some have the heating circuits located inside the cabinet UNDER the drum and others have heating circuits BEHIND the drum.
    If your dryer has the lint screen on the TOP of the unit, you will need to remove the BACK panel of the dryer to expose the heating circuits.
    If the dryer has the lint screen in the DOOR, you will need to remove the lower toe panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower toe panel comes off by removing the screws under the bottom edge of the panel.
    If you do not have a toe panel, you will need to lift the dryer top and remove the entire FRONT panel to access the internal components.
    If you have further questions, please post back with your MODEL NUMBER so I can determine how your dryer is constructed.
    Mar 12, 2010 | Kenmore 62992 Electric Dryer
    KENMORE DRYER MOD# LEQ9858LWO WILL NOT TURN BUT HEATS
    If you hear a humming, then it is probably a broken or slipped belt from the motor to the drum. There is usually a pully on the shaft of the motor, a tensioner pully on a spring, and a groove on the back of the drum that the belt rides in. If this belt breaks or comes off track, the motor will still spin but the drum won't.
    You will probably need to take the front or back off of the dryer (varies by model) to expose a view of the belt, and once you do this, it will be easier to see if the motor is turning or the belt has broken or slipped.
    If the belt has slipped, be sure to inspect it for wear, and replace it if worn. Otherwise, it will slip again and you'll have to repeat the process.
    Jun 10, 2009 | Whirlpool LEQ9858L Electric Dryer
    Burning smell in in dryer
    Take a flashlight and look inside the drum at the holes on the back end of the drum where the hot air comes in. On mine, there is an air deflector on the back side of the drum and the space between this deflector and the drum was packed with lint. The lint blocked about half the holes. I had to take the drum out, remove this deflector by removing four screws inside the drum then cleaning out the lint. The lint was all brown and scorched.
    Jun 07, 2009 | Whirlpool LER4634J Electric Dryer
    Whirlpool Dryer won't spin
    REMOVE THE LINT FILTER AND THE 2 SCREWS UNDER IT THEN PRY THE TOP UP AT THE EDGES WITH SCREWDRIVER AND OPEN TOP. NEXT REMOVE SCREWS ON THE INSIDE OF THE FRONT PANEL ON BOTH SIDES THEN UNDO DOOR SWITCH WIRES AND PULL FRONT PANEL UP AND OUT. DRUM MAY DROP A BIT. FROM THERE PULL DRUM OUT AND PUT NEW BELT ON AND REASSMBLE. IT WILL BE EASIER TO REMOVE THE REAR PANEL AS WELL TO RE-INSTALL THE BELT TO THE MOTOR AND TENSIONER.
    Apr 13, 2009 | Whirlpool GEW9250 Electric Dryer
    Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
    1. Changing from 3 to 4 wire hookup on a electric dryer
    2. Door switch replacement help for a common door switch
    3. Dryer basics - Venting problems and power supply
    4. Dryer basics - timers and how they work
    5. Dryer basics - power cord problems
    6. Dryer basics - dead dryer
    7. Dryer *general* repair flow chart....Click here
    8. Gas dryer smell
    9. How do dryer thermostats work?
    10. How long can my dryer vent be in length?
    11. How to change a common rear drum seal
    12. How the belt is suppose to look at the motor and idler pulley
    13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
    14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
    15. Help for storing an appliance
    16. Important Disclaimer
    17. I dropped something down the lint filter area....help!
    18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
    19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
    20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
    21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
    22. Inglis, Whirlpool and Kenmore electric element changing procedures
    23. Inglis, Whirlpool and Kenmore dryers - air flow
    24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
    25. Inglis, Whirlpool and Kenmore style dryers - belt change
    26. Inglis, Whirlpool and Kenmore dryer general motor problems
    27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
    28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
    29. If your drum belt looks like either of these....change it!!
    30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
    32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
    33. Pilot flame help
    34. Sample wiring diagrams
    35. Test for ohm meter checking on electric dryers with no heat
    36. Taking apart an Duet or HE3 dryer for a belt change
    37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
    38. Timers and some common Auto dry troubles and solutions
    39. What is a grounded element?
    40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
    Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
    Whirlpool dryer
    You need to check the dryer INTERIOR to ensure there's no lint accumulations on or around the heating element. The exhaust systems on dryers are not perfect and SOME lint often gets by the lint screen and can start the collect inside the dryer. The lint will begin to smolder and give off an odor if it sits on the heating element housing. Make sure the dryer is unplugged before attempting to access the interior. If the model number you provided is correct, the heating element will be located under the drum on the right-hand side. You will need to lift the dryer top and remove the front panel (with the door) to access the inside and vacuum. Let me know if you need further assistance. I hope this information is helpful to you.
    May 08, 2008 | Whirlpool LER5636P Electric Dryer
    Whirlpool LEQ9858P Electric Dryer Logo
    122 people viewed this question
    Top Whirlpool Dryers Experts
    Marvin
    Marvin
    John Tripp
    John Tripp
    Donni Steen
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
