Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Kitchenaid mixer mades a high pitch squeak when mixing
My mixer works well, but lately it makes a hgih pitch noise when it mixes. Does it need to be oiled? Can I make the repair myself?
  • 25 Answers
Take it to a local repair shop and they should be able to fix it in no time.
Posted on Mar 26, 2008
You may have a few screws loose or need to replace the grease.
Posted on Oct 18, 2012
Hot to repair if it show (error 17 and 32)When we push button start (magnetic switch lock) maybe 0.21s (the magnetic switch is unlock)
Posted on Oct 08, 2011
My Kitchenaid mdl: KSM 155gbca is making a loud bumping noise with or without an attachment.
It is more than likely in the planetary or the fuse gear inside the gear box. Try it once you have the planetary off before you go looking inside the gear box. Easiest is planetary problem but far far more likely is the fuse gear.
Aug 08, 2014 | KitchenAid Artisan Series Tilt-Head Stand...
Making High Pitch Noise, Sounds Strained
the drive shaft bush is dry ( probably from dough getting up the shaft) have the unit serviced /repaired and properly lubricated using food grade lubricate
Mar 20, 2017 | Bosch Food Mixers
Kitchen Aid HDPro 5 quart bowl lift mixer is making clunking, rattle type noise when mixing anything heavier than egg whites.
You are probably going to have to remove the top housing and look and listen while it is running. Does it lose drive when it is being noisy? You need to remove the back cover, the silver band with Kitchen Aid on it and that will expose the 4 screws holding the housing on. Remember fingers and tools OUT while it is plugged in or running. I can't be a lot more help to you, we don't have that model in NZ.
Mar 07, 2014 | KitchenAid Professional Heavy Duty Series...
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
My kg25h7x varies the mixing speed on its own
The Kitchenaid uses a centrifugal switch to maintain a constant speed. This must be sticking to cause this. You mixer will need to be disassembled and inspected.
Jul 03, 2012 | KitchenAid K45SS Classic Stand Mixer
My Kitchen Aid Pro5 squeals when it's running. I may have overheated it when mixing bread dough. It seems to be running okay. It just makes a very high-pitched noise now. What can I do to fix this?
Get a Copy of the Repair Part List of your model from Kitchenaid.com.
Most likely it is the Worm Gear (17) grinding at low speed the Worm Gear Follower.(19)
You don't have to replace it now, but it is best to open the Transmission Housing and
inspect all the gears conditions. Clear all the grease to expose them. The Bevel
Gear (21) sits right on top of the Worm Gear Follower. (See Repair Part List)
If its teeth look sharp and all metal shiny, then that is the source of your noises.
Eventually, all the teeth will be chewed away and the planetary assembly will stop turning.
Jul 01, 2011 | KitchenAid 450 Watts KM25G0XWH Stand Mixer
My Kitchenaid mixer (k5ss lift bowl?) smells hot
I think you have a K45SS. It sounds like there is a problem with one of the gears, probably the worm gear. The worm gear is designed to be the first to fail if the mixer has struggled with a heavy dough or other difficult to mix substance. The best way to establish the cause will be to open the head up and check the gears for signs of damage.
Jan 25, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Jan 02, 2010 | KitchenAid KP2671 Professional 6 Series...
Dough mixing paddle will not stay in my wife's Viking mixer
pour a little wesson oil into the attachment holes and work the release while inserting and removing the attachment. Make sure the unit is unpluged. The oil will lubricate the lock mechanism.
Oct 28, 2009 | Viking VSM700 Stand Mixer
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
2,256 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
