Question about Nintendo Wii Console
Wii Poer voltage Damage
My niece got a Wii from the US and she turned it on in New Zealand where the power voltage in use is 240. There was a pop sound and yes, the wii would not turn on anymore. I would like to know that if I bought a new poer adapter, would that fix the problem or the whole console is a write off. Thanks for your help.
    Problem Solver:
  • 17 Answers
The problem is that the voltage in NZ is different (higher) than that of the USA, and the power adapter (gray box that plugs into the wall) has blown. Replace the power adapter and use a voltage converter that lowers the power to 115 (or 110/120) volts, and you should be good to go. ;)
Posted on Jan 28, 2008
Looking for a power pack for my Maxtor hard drive & how much for one
first question is ,is it internal or external and where do you live,ie country to work out how much it will cost
if your in new zealand theres always trademe , theres a case and poer pack for 25 dollars on there
Feb 28, 2013 | Computers & Internet
Barrel turns no heat-new fuse-same-new element-same. Old element burned could new fuse pop and I need new one
Be sure to check for lint inside the filter housing and also vent blockage. 240 volts is going into the dryer. The motor runs on 120 so you might have a voltage problem. Heating element needs 240 volts. here is my video let me know if this helps:
Dec 21, 2012 | Kenmore Dryers
The motor popped when I first used it. I had a US version (110 volts) and plugged it into Australian plug with adapter at 240 volts. Any ideas?
All the adapter did was enable you to put 240VAC straight into your 110/120VAC coffee maker. You needed a step down transformer to drop the voltage from 240 to 120 VAC. This is not what you wanted to hear but you have damaged your coffee maker substantially by using the wrong voltage. Also the US version is designed for 60 HZ power vs AU 50 Hz power unless stated otherwise on the input power data plate.
Damage that has probably taken place:
1. Motor PN 8211837
2. Relay and Switch assembly PN: 8212011. .
3. Capacitor PN 8211608
Cost to repair... will be close to total replacement value due to shipping costs & customs of replacement parts
Thanks for choosing FixYa,
May 13, 2011 | KitchenAid KFP750 Food Processor
I just bought a 10 yr. old Schult mobile home and after moving it to a new lot, I have no hot water. The heater is an Intertherm. I checked incoming voltage and it is ~120v, and the plate says 240v. My...
The incoming voltage should be 220-240. Check voltage across terminal that power supply is hooked to.Each incoming leg should read 120 to ground and 240 across . Check to see that thermostat is turned up to highest setting,usually 140 degrees,and check reset button to make sure it stays in in position. If you push reset in and it pops right back out you probably have a bad element. Check elements by going across terminals when you know element should be on.Hope this helps you. Thanks
Dec 19, 2010 | Water Heaters
I live in New Zealand which has 240 volt supply on the grid. The zantrex 2000 works with an input supply of 120 volts. How can I use it?
Hi, OK, there are two ways to achieve this. One. Using an external STEP DOWN Transformer, 240 V AC, to 120 V AC. The ONLY thing that matters is KVA. As long as the KVA is the same ir will work. This means as long as the Output Voltage and Current are the same, it's irrelevant whats on the Secondary. So if
The second, is to remove the existing transformer, and substitute with an exactly the same Secondary Outputs, BUT with a 240 V AC,. Input winding. Most likely it is a simple step Down transformer anyway, that steps down, whatever the external voltage is, down to say 12 -18 V AC. Therefor ANY suitable 240 V AC transformer with the SAME secondary winding(s) will work, no problems. You can even get some transformers Overwound, for 240 V AC, a very common thing, depending on transformer construction. There are a few transformer manufacturers in the "Yellow Pages" contact one of them and inquire.
As a tip, sometimes the existing transformer has TWO 120 V windings, and sometimes only ONE side is used, for US power, and for 240 V AC, you simply connect the other winding in series, and NOW you have got your 240 V AC to whatever.
Sep 01, 2010 | Inverter Xantrex MS2000 Sine Wave Charger...
No power for the wii
Does the outlet you have your console plugged into receiving power? You could check this by plugging in a lamp or something to check for power. If it is getting power, it could be your power cord. If a power cord for the Wii is rolled up too tightly, too many times, the wires inside the cord will come loose and come apart. That may be what happened. Before sending it in or getting a new Wii, you should try borrowing someone's Wii power cord to see if it just the power cord. If it still does not work, you can try calling the Nintendo Help & Support. You can find the number by going to and clicking on the Help (or Support) link and finding a phone number.
Apr 29, 2009 | Nintendo Wii Console
My wi power source just quit
Guest: Rechargable batteries are only 1.2 V each. You should get up to 4.8 V.
I highly suggest running your Wii Fit on nothing other than Alkaline batteries. I've had my Wii Fit for over 3 months and still use the original batteries.
If you feel like you need rechargables, that's fine, but I recommend a quality set of regular AA rechargable batteries that comes with a quick charger (IE: 1-hour). Stick to the same brand of batteries and buy enough for each Wii-Mote, Wireless Guitar, Wii Fit Balance Board, etc.
Amy - Keep in mind that your Wii Fit balance board will ONLY turn on when your program (ie: Wii Fit) is loaded and ready to go. Since the balance board takes up one of the four available Wii-Mote channels, make sure all but one Wii-Mote is turned off before starting Wii-Fit.
Apr 29, 2009 | Nintendo Wii Fit for Wii
Europran wii
Wii consoles are region-specific and different regions also use different television standards.
You have potentially three problems:
  1. Wii consoles are region-specific. Games for US/Canada won't work in a European Wii
  2. European Wii consoles output PAL video signals. US/Canada/Japan TVs except NTSC video signals.
  3. European Wii consoles likely require 220-volt power. US/Canada/Japan is 100-120-volt power.
So now your solutions for each:
  1. You need to get games from France (or at least Europe)
    You can also look into a device called the Freeloader, but I'm not sure if it works with Wii games yet (the original allowed Gamecube consoles to play games from different regions)
  2. You'll need a multi-standard TV, or a television standards converter. Tourist-y camera shops often sell converter boxes. You need to convert from a PAL video signal to an NTSC video signal in order to connect it to your TV.
  3. Check the power adapter of the Wii. If it lists "110-240 volts" or "100-240 volts" (at least a voltage number in the 100-something range) on it, then the power supply will work and you just need an international plug adapter. You can get these from most travel stores and electronics stores.
    If the power adapter does not list a voltage in the 100-something range on it, then you will need a step-up transformer - that will convert power from 120-volt to 220-volt or 240-volt. The transformer may or may not have the right type of power receptacle, so you may also need a plug adapter. Check your local electronics store for this. Tell them you have a device from Europe and want to run it on your local electrical power. They should know what you need. If you have a choice, get one that is designed for computer or laptop use, as the cheaper ones provide "dirty" power which is fine for hair dryers and such, but bad for electronics.
Hope that helps...
Apr 02, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
146 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
