Question about Black & Decker CHV9600 Handheld Vacuum
How long am i suppose to charge my vac?
It runs out of battery in less than a minute ...
how can i prolong the vacuuming time?
  • Anonymous Jun 04, 2008
    Battery does not last very long I am having heaps of trouble with getting a answer from service centre
    President:
  • 1,673 Answers
If your battery is not holding a charge, then you will need to replace the battery. Unless the charger isn't working, but usually it is the battery.
Posted on Feb 05, 2008
My v8 hand held vac is not holding a charge going dead quick
20 minutes for normal use
6 minutes on turbo boost
6 hours for charge
anything less replace the battery
Oct 09, 2017 | Vacuums
My Cordless Dyson has been plugged in for weeks & only offers short burst of power then goes dead
battery vacs run for 20 minutes on normal speed and 6 minutes on high speed
any thing less indicates problem battery pack
Sep 04, 2017 | Dyson Vacuums
I bought a cordless Dyson, three days ago. I have charged it three times. It states that this model has a twenty minute running time. This one runs less than 10 minutes. JU6-US-HEA1415A
If after a few more discharge, charge cycles unit still underperforms then return for exchange or money back. Newer batteries have to be "exercised" a tad before they perform up to specs. And if they say 20 minutes, then hold them to it!!!!!!!!!!!!!!
Nov 28, 2016 | Vacuums
It will not hold a charge. Been plugin for days at a time then it will run a minute then stop
Hello Karen, It sounds as though may have a bad battery or the charger is shutting down before the battery gets fully charged.
Nov 01, 2015 | Black & Decker CHV1210 Vacuum
When is the DC16 red light supposed to change to green?
You can see the manual for the DC16 here: (
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc16_uk_manual_cb_120710%20pdf.pdf )
Following the troubleshooting manual on page 6, fully charging the battery takes about 3 hours, for a run time of 6 minutes, so I'm not sure where 10 minutes comes from. The battery ships partially charged and was supposed to have been charged 3+ hours before a first use to get a full cleaning span.
It's also noted that you can get red lights if the temperature is out of an optimal range, and if the filter is not seated properly, so these would be things to check as well.
On the general checking list - look at the contacts for the battery and for the charger, make sure nothing is bent or corroded. Corrosion can be generally treated with use of some fine sandpaper or steel wool - be sure to blow the area clear of any steel wool fibers if you go that route. A better electrical contact sometimes will allow charging to get above a threshold voltage that will let the 'I'm charged' light turn green.
Good Luck! :-)
Jul 20, 2014 | Dyson DC16 Root 6 Bagless Handheld...
My DD hand vac won't hold the charge for more than one minute and just fades away! It has been charged for 24 hours.
Hi there! Your battery may need to be reset. Try depleting the battery. Run the vacuum until it completely shuts off, then re-charge for a full 24 hours. Hope this helps out! If you still have questions you feel free to reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil.
Jun 30, 2014 | Dirt Devil Vacuums
Very short vacuum cycle time.
the charger sounds like its out take to service center.
Nov 29, 2009 | Roomba Pro Elite Bagless Robotic Vacuum
Hoover Freejet Cyclonic will not charge after battery run flat
basically, the batterie pack is shot and it will cost about £40.00 ish to replace. as you said, a right rip off
Dec 24, 2008 | Vacuums
Westinghouse Unplugged Vacuum Turns off after 5 Seconds.
If both batteries are behaving the same way then this is probably a charger problem. When you insert the battery pack into the charger does the 'charging' light blink for 30 minutes (fast charge) then go steady? I noticed that one of my batteries was causing the light to come on steady immediately I inserted it into the charger. When I tried to use the battery pack I got the same problem everyone else is seeing, i.e. vacuum cleaner shuts off in less than a minute, so I conclude that when the charging light is on steady then the battery is not being charged.
If the charging light does not blink when you insert the battery (i.e. comes on steady or not at all), try removing the battery and re-inserting it into the charger.
Try a conditioning cycle on your battery packs. To do this:
* Insert the battery pack into the charger
* Before the charging light lights press the 'condition' button located just above the charging light.
* The 'conditioning' light should blink. This is a light which does not normally illuminate, and it is located below the condition button and above the charging light. The charger fan will run quieter in this mode.
* Leave the battery pack in the charger for 24 hours while this cycle is taking place.
I'm not a service technician so perhaps someone else might like to post other solutions or corrections to this one.
Mar 07, 2008 | Vacuums
Black & Decker CHV9600 Handheld Vacuum Logo
186 people viewed this question
Top Black & Decker Vacuums Experts
GG TECHNOLOGIES
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
