Question about Cobra 29 LTD CB Radio
Wired backwards a friend accidently connected pos to neg and neg to pos. The radio smoked a little. Is the radio worth fixing or should I just replace it. Stock radio, no upgades.
  • bexxdad Jan 28, 2008
    thank you for your help, the trip to the cb shop will be the attack route. If they say a stupid price, I'll repost to get walked through the soldering. Thank you again.
  • 2,130 Answers
In many CB's there is an internal diode that is connected across the DC line. When the power is connected correctly, the diode is reversed biased and does not conduct. When the power is swapped, the diode is forward biased and conducts. When that happens, it causes the in-line fuse to blow. Was there an inline fuse in the power leads? I would take the cover off and see if there is a burned diode where the power cord enters the radio. Take a look and see what's burned. Let me know what you find and we'll go from there. If there has been a lot of damage, it may not be worth fixing.
Good Luck,
- Jim
Posted on Jan 28, 2008
  • SHARCNET-USA
    SHARCNET-USA Jan 28, 2008
    Good luck with the repair shop. We'll be glad to help you further if they quote you a high repair bill and you want to try fixing it yourself.
    - Jim
  • SHARCNET-USA
    One more comment. When you get the radio working, make sure there is an in-line fuse in the power leads. It's easier to replace an external blown fuse rather than an internal burned up diode. Good luck! - Jim
  • 126 Answers
Yes Yes Yes. Before anyone tells you different, Yes. The smoke is supposed to happen when you do that. That is a protection diode that fried. It is there for that reason only. In rare cases, more damage can be done, but about 98% of the time it just fries that diode.
You can take it to any cb shop and have it repaired, just tell them the protection diode was fried. They should only charge between $10 and $15 for it. I charge my customers $10.
If you do not have access to a cb shop and are handy with a soldering iron and desoldering iron, I can walk you through this repair. Just let me know. You can post here or email me at rollincbmods@yahoo.com
Dean
Rollin CBs
  • Dean Pitts
    Dean Pitts Jan 28, 2008
    by the way, the protection diode # is D23
  • Dean Pitts
    That is what we are here for. If they try to tell you more than $15, you can call me if u like 903-466-1750. I have no problem straightening them out, lol. That is my cell phone and business phone.
    Dean
    Rollin CBs
Has aftermarket amp and special unit that allows an ipod to show what song is playing on the regular factory radio. The problem is the radio lights up normally but no sound from speakers. Zi did hear a...
Something has been mis-wired. Ensure the speakers are in the speaker slots and the power (Neg and Pos labeled as well) are properly connected. It is fairly common to get the speaker pos and neg mixed up with the power pos and neg. Hopefully, no permanent damage was done. The problem is between your factory radio and the aftermarket power amp.
Mar 12, 2015 | Cars & Trucks
Someone hooked jumper box up backwards on van and tried ti start it it ran great before that after it wouldn't start at all changed the computer now it starts runs a few mins then shuts off what could it...
You will have to take it to the Dealer. You may have burnt out or the "Control Module" needs to be replaced or reprogrammed. Make sure the battery has not reversed polarity also.
Feb 13, 2015 | Cars & Trucks
Cobra 29 lx (new digital display) no power
with no power connected read resistance across power leads---likely protect diode just inside back of radio from red power lead is shorted to ground
THE ONLY THING THAT CAUSES THIS IS THE RED AND BLACK GETTING HOOKED UP BACKWARDS---NOTHING ELSE WILL DO IT.
IF YOU READ A DEAD SHORT WITH RADIO NOT HOOKED TO POWER AND POWER SWITCH OFF--THE RADIO GOT RP(reverse polarity).
May 19, 2012 | Radio Communications
Chevy K5 Blazer military diesel with 12/24v system. Replacing the dual batteries and need to know battery cable pos/neg terminations. Cross connect cable looks like a frame ground. Had it connecting both...
Positive of one battery to hot of vehicle wiring harness--neg. of that battery to positive of other battery--negative of that battery to block (ground)
Aug 04, 2009 | 1984 Chevrolet Blazer
2000 dodge durango-i replace the blower motor and i get nothing. the negative wire is reading with positive power. Why is this??
you have the wires backwards, switch them up you probably have the pos. to neg. and the neg, to pos.
Mar 31, 2009 | 2000 Dodge Durango
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
budman772357@embarqmail.com
Mar 01, 2009 | Minn Kota Boating
I bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
Cobra 29 LTD CB Radio Logo
187 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
