Question about Whirlpool GBD307PDS Electric Double Oven
BM - After Self-Clean Problem -- 30" Electric Whirlpool Double Oven -- Model # GBD307PDQ6
I have a 30" Electric Whirlpool Double Oven -- Model # GBD307PDQ6. After a self-clean session appeared to finish (control panel indicated that cooling started) the control panel and all operations were disabled/failed. I checked the main circuit breaker and nothing had tripped. I took off the trim pieces and lifted the front control panel off to test power to the motherboard. I was getting 120VAC into the board but the step-down transformer didn't show any voltage (high or low side). I'm tempted to pull the oven out to locate the two thermal overload fuses but thought I'd ask an expert first. I have a hunch it may not be a fuse if I'm getting power to the control panel motherboard. I'm thinking my motherboard could be the broken link. What suggestions would you have for me? Thanks - Brian
  • murrdogs Jan 29, 2008
    The model # is...
    GBD307PDQ6
    So you don't think the problem is with the thermal overload fuses?
    Genius:
  • 1,067 Answers
Yes i would say mobo 1st cused form to much heat xpanded an area
Posted on Jan 29, 2008
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
My electric Amana Range with self cleaning oven model Art6100 or Art6000 approx. 11 years old will not work on the clean cycle. Burners and oven work fine. We had the door off and apart to clean a few days...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Replaced control panel and keypad 1 1/2 years ago seen the error codes now I was self cleaning oven everything went off no error codes or anything house breaker ok PLEASE help.
Self clean is hard on controls. I do not recommend self clean. Kills expensive parts. If the temp goes above 300 in the control panel, a control panel fuse will melt, killing the power to the control.
It looks like this:
Service manual for late model whirlpool double oven
and some more interesting oven stuff
Mar 08, 2011 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool electric double oven #RBD305PDQ14 control panel blank
I suspect a poor connection at the wiring to the EOC is the cause of the failures.
Apr 21, 2017 | Whirlpool RBD305PD Electric Double Oven
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
Whirlpool oven caught fire while cleaning
just scrape out the residue and clean it again.
Dec 12, 2008 | Jenn-Air Electric Double Oven
Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
May 10, 2008 | Whirlpool GBD307PDS Electric Double Oven
Brain, check your thermal fuse first. You can do this at the board. lower oven, p26-2 orange or p26-4 red wire to red wire at the terminal block. Should show closed circuit. Upper oven, p18-4 red or p18-1 red to red wire at terminal block. Should read closed circuit. If open, there is your problem. Control transformer is as follows, primary windings, P16-5 red to p16-7 red, 75 to 95 ohms. Secondary windings, p16-2 blue to p16-3 blue , 2 to 4 ohms. I do believe your problem is in the thermal fuse on the back. Post back, Catriver
Jan 29, 2008 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool GBD307PDS Electric Double Oven Logo
238 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
