Television won't start, led flashing
Hi, I've owned this television for about a year now. Now, when I try to turn it on the tv refuses to start. The standby link flashes radically, and I think I can hear a type of static sound coming from the TV. Do you have any suggestions?
  • 48 Answers
If you post make and model, I can maybe give you an idea.
Posted on Feb 01, 2008
LG 17LX1R flashing red LED - TV won't power up
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | LG 17LX1R 17 in. HD-Ready LCD Television
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
Panasonic tv turns off by itself model number PT-50LCX64 then the light flashes yellow
Repair/service manual of this model no. has a list of error code by means of led light flashes and its color and the probable caused of the symptoms. Once you've determine the caused, you may decide whether to fix it yourself or hire a professional. If you want the copy, click here.
Jdvillanueva
Sep 29, 2011 | Panasonic PT-50LCX64 50" Rear Projection...
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
Sep 16, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Won't program to our new TCL television - we have the 222 receiver
I don't show we have a code for the TCL (Australia) brand TV. Below I have provided instructions on how to perform a power scan.
  • Remote: Basic Remote (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Press and release the red TV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the # button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 14, 2011 | DISH Network IR Remote Control
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
Jun 12, 2011 | DISH Network IR Remote Control
I have a LG rear protection tv. I believe 52sz8d-is. When I plug it in the red power led light comes on and the bulb led flashes green but it won't Turn on
Tries change the tv projection lamp.Tv projection lamp ben in the tv like 1 1/2 or 2 years already,tv watches daily 4 or 5 hours every day.Yes.Than the tv projection lamp life are ended,now tv require a new tv projection lamp replacement.
Jun 05, 2011 | LG RU-52SZ51D 52" Rear Projection...
Remote not active with the tv
unessr
I have provided instructions on how you can program your remote to your TV. Without knowing the brand TV you have, I have provided a link with the codes you can try.
Program to TV:
  • Remotes: Basic (Television Only)
    2. Press and hold the TV Power button for three seconds until the LED flashes.
    4. Press OK. Note: The LED will flash three times.
Power Scan:
    3. Press and release the TV Power button.
    5. After the television turns off, press and release the OK button.
The link for the remote codes are at the bottom of the page. Select your receiver type and then your TV brand to get the codes.
http://www.dishnetwork.com/SupportSection/remote-setup
I hope this helps.
Ray Calo
DISH Network
Apr 16, 2011 | DISH Network IR Remote Control
Tv won,t turn on
1-877-778-8876
Call for a service call
Jul 09, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
PFM-42b1e LEd flashing 6 times... 1 sec. picture with green stripes... and then it turned to standby
I have a sony tv PFM-42B1 when I turn it on it go to standby an a red light flash I count count 14 time but I heard that it only support to flash 1 to 6 time how do count the flash
May 06, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
