Question about IBM ThinkPad R40 2681
Charging inconsistant Sometimes, charging works as it should. Other times, the battery runs down and won't recharge, even when left turned off and plugged in for a day. Have removed the battery and booted, then inserted the battery... did not solve it. Power supply is the 4.5A 02K6754 and does deliver 16v. Replaced the battery with a new one, problem persists.
  • 3 more comments
  • K7AAY Jan 28, 2008
    The power supply puts out a good 16v at the coax tip, so the supply and cord are OK. Its power is a coaxial plug and when run sans battery it runs fine, no
    problems. Therefore, it's got to be something after the plug/socket
    combo.
  • K7AAY Feb 25, 2008
    Bought a spare power supply at the time I got the laptop, Problem happens with both power supplies.
    Since I see the power indicator LED is on solid when plugged in, it's not the power supply socket.
  • K7AAY Mar 04, 2008
    I repeat:
  • K7AAY Mar 09, 2008
    Since the laptop runs with no battery on the power adapter, as previously stated, it seems that power is getting through, does it not?
  • K7AAY Mar 13, 2008
    Here's more data. I can get the R40 to start charging the battery again by:
    1. Shutdown, power off.
    2. Remove power supply.
    3. Remove battery.
    4. Reinsert power supply.
    5. Power up, and press [ACCESS IBM] button before Windows starts to boot.
    6. Resave BIOS settings.
    7. Boot into Windows.
    8. Shutdown, power off.
    9. Reinsert battery.
    10. Power up, boot into Windows.
I'm having similar problems on my R40 and I've seen a lot of references to similar problems when I had time to search. I have no idea what is causing the problem, but it's apparently quite common. I replaced my battery in January thinking it must be dying (had gradually crept down below 40% over a period of weeks, even while connected to power). The new battery quickly charged up to 100% and stayed there until I used it standalone last weekend. It got down to 40% and would not go up. I've removed it, cleaned contacts, etc, but no change. It will go down, of course, if I disconnect the plug, but it won't charge. Either ALL the batteries out there are bad, or many R40's have a defective charging system.
Posted on Mar 13, 2008
Until you test the actual power pin you have no way of knowing that it (the pin) or the connection to the mother board isn't bad.
Posted on Mar 09, 2008
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
Sounds like it could be the power pin/socket. Poorly designed at best. The day in and day out pulling and tugging takes it's toll on the poor little connector. I use a cable retention device liek the one in this video to keep my plug intact.
Posted on Mar 04, 2008
    Novelist:
  • 113 Answers
Sounds like the power cable and/or it's connection is going bad. If it's the cable you can certainly replace it, though it may be costly. But if it's the connection on the machine, I've never seen a cost effective long term solution to the problem beyond buying a new laptop.
Posted on Jan 28, 2008
  • 1 more comment
  • Phil
    Phil Feb 25, 2008
    I always hate to order a new cord, and then find out it's the socket - maybe you can find a place in town that might have one in stock that you could return if the problem persists? A laptop fixing place might have one on hand that you can try and see, perhaps.
  • Phil
    Phil Feb 25, 2008
    Must be something with the charging mechanism itself. Unless you got a 2nd bum battery, which seems unlikely. I would check with Lenovo to see if there's been a recall of the unit because of problems like this.
    Sorry to have not been more helpful.
  • Phil
    Phil Mar 09, 2008
    As I said, unless you happened to get a 2nd bad battery, which seems unlikely, it must be the hardware within the laptop that charges the battery that is bad. If still under warranty, or if there is a recall of this particular unit, you can probably get it fixed. If not under warranty or recall, you'd have to pay, and it might not be worth the price.
Charging battery compaq presario c700
If you can reach inside the computer and rub the battery contacts gently to remove the corrosion ,which is invisible , this will help greatly. Sometimes even a new battery will suffer the same. Clean the battery contacts also turn off the laptop and charge it fully do this on a regular basis. Say once every 2 months
Nov 05, 2013 | Computers & Internet
Lens won't close and On/Off button doesn't work
Even though the battery appears to be charging it may be shot. Some batteries if they run down too far can not be recharged. You need to try a new battery in the camera.
Jul 25, 2012 | Nikon COOLPIX S6000 Digital Camera
I have 2 batteries but some how i can not charge even i have left them 24 hrs to charge
Digital camera batteries are usually with an external battery charger.
The charger maybe faulty, the charge adapter will have a LED indicator to indicate that it is charging.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 15, 2012 | Samsung Digimax L730 Digital Camera
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
Dead battery, replaced battery and alternator but still no charge!
if its not charging while running at14.5 volts or so you have a charging problem mabey no power to the alternator if its charging at 14.5 or so and the batery load tests good and its going dead over night you have a draw from some component in the system.
Dec 19, 2011 | 1994 Oldsmobile Cutlass Ciera
Batteries r not charging What could be the problem and could it be repaired
Hello
First, make sure your batteries are rechargeable. But even rechargeable batteries have a lifespan, try charging it into another charger. If it is charging on another charger, then that means your charger is faulty. If it won't charge on another charger, then the batteries are dead, and you need to buy new set of batteries.
Sep 08, 2011 | Nintendo Video Game Consoles & Games
While charging on AC works absolutely fine. But while discharging i.e. Running on battery, shuts down unexpectedly. The same also happens when the the AC adaptor is plugged out at random. Lastly, the...
Aug 10, 2011 | Computers & Internet
I have a power problem with a RIDGID 18v rechargeable drill. The battery charge indicate charge and the unit won't start . One of the batteries was left in the charger for several weeks. I use this...
I leave my 18 volt batteries charging year round even if I do not use my drill I switch batteries about once a month to keep them both up to snuff. your new chargers are made to do that unless the instructions tell you not to. I was told even new batteries will not hold their charge if allowed to completely run down and stay there.
Jan 31, 2018 | Ridgid Garden
Acer 5315 Battery cHarging Problems
All rechargeable batteries have a limited life, and as they age their charge capacity reduces over time and you get shorter and shorter time between charges.
Recharage batteries have a finite number of charge and discharge cycles and batteries over 2 years old are considered nearly worn out. Worn out batteries won't charge up at all.
Jun 30, 2009 | Acer Aspire 5315 Notebook
IBM ThinkPad R40 2681 Logo
80 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
