Question about Mitsubishi VS-60805 60" Rear Projection Television
Can you help me please
Do you know what will fix this problem for a Blown Convergence IC on a mitsubishi tv or do i have to get a new one ???...
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Posted on Jan 28, 2008
Mitsubishi ws65713 picture goes out
I know these sets well, you lose brightness but still have sound?
If the green power light comes on for a few seconds and then goes out the set has a self check for error codes:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Nov 02, 2012 | Mitsubishi Televison & Video
How to replace cicuit breaker mitsubishi ws 48511
It does not have a circuit breaker but if green light comes on for a few seconds and goes off:
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
Oct 29, 2012 | Mitsubishi VS-45609 TV
My Mitsubishi ws-65819 shows in an oval shape, can this be fixed, also is there a way i can do it myself to save some money? Also how to play an Xbox 360 in HD?
yes......you can rplace the convergence ic's on convergence module......these are the big stk type ic's and also the low ohm resistors.
These are 3.9 to 6.8 ohm half watt on the yoke return circuit. Let me know how you fare......regards. meder's tv
May 28, 2012 | Mitsubishi WS-65819 TV
I have a Mitsubishi WS65611 I understand that the green lines are fixed and the red and blue lines are somewhat adjustable my green lines are no longer fixed in the top right and bottom left of the screen ...
YES, you either have a fuse that went out or the convergence IC went out... Sometimes it just comes unsoldered and causes the same effect. You need to locate this "IC" and tap on it with something non metallic. Like a ruler or a stick. While the tv is running and crosshatch is up on screen. If the lines get close as you tap on the IC or bang on the tv. then fuse is good and the tv might just need to be resoldered on that CONVERGENCE IC. Let me know how this works for you and if you have any questions give me a call @ 502-773-7969 and i can help u out further.
HAVE A GREAT DAY....Sincerely HDTV GURU JAY
Mar 15, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi model Wt-46807 Power shuts down after turning on. Tried the solution of pressing the menu & input buttons at same time for at least 5 seconds. Power light error code was 2 blinks/pause 2...
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Oct 16, 2010 | Mitsubishi WT-46807 46" Rear Projection...
I have a 60 inch mitsubishi projection tv model # vs-60609 and the convergence is messed up...the tv guy said it needs a chip or a someboard... need help in finding part or needing to know if it can be...
You need to replace the convergence IC your set only uses one IC ( Chip) its STK393-110 you can get a replacement IC at the following link and they provide free instalation instructions with pictures and free shipping. Here is the link.
http://servicemanuals.vstore.ca/
Jul 09, 2008 | Televison & Video
Convergence board
Your model uses a convergence IC Its a STK393-110 you can get a new replacement at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. They also offer free tech support to all their customers. heres the link.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Please help super bowl depends on it
Sony Convergence
Jan 28, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Convergence no adjustment
There are black in color circuit protectors in the set that have blown because of the bad convergence IC's. You will need to measure the voltages on the ICs and make sure you have the correct plus and minus voltages. There should be about + and - 24 volts on each IC. I'm afraid the only way you will know what voltage are what and where they should be would be to get a service manual. i am sorry i do not have this model to share with you. Good Luck.
Apr 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Convergence board
It wouldn't be the entire convergence board, you more than likely have a bad convergence STK-IC. Replacing the IC will take a good bit of knowledge and training as far as electronic repair is concerned, plus a complete convergence set up. In other words, unless your certified, you need to contact a tech. The convergence set up alone has driven men to drink.....
Aug 28, 2006 | Mitsubishi VS-45609 TV
Mitsubishi VS-60805 60" Rear Projection Television Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
