Question about Creative Labs Sound Blaster Audigy 2 Platinum Sound Card
Static I get loads of static in my system. I've tried to find the source, but hav been unable to find it.
  • 1,067 Answers
Need new drivers cheak eq defult it
Posted on Jan 28, 2008
Why am I getting the HDMI Error. Unable to display video(H15005 - HDCP link intergrity check failed?
The hdmi outputs on the uverse receivers are garbage, I recomend using them. Go to Walmart and buy a component cable install it and never worry about the hdmi error again.
May 29, 2014 | AT&T UVerse
Left channel static
I have seen dirty switches or pots cause constant static. I would get some contact cleaner and try spraying it into all switches and pots, and work them to clean the contacts. Also, check to see if there is static in a low-level output such as the one for a tape recorder.
Mar 29, 2014 | Marantz Audio Players & Recorders
Static sound from one channel after playing for a while--time it starts varies.
You don't say what a 1055 is and it is hard to know what you are asking with a lack of ID on the equipment at fault. Sounds like a source selection problem maybe a switch or if electronics a CD4066 IC.
Mar 25, 2013 | Audio Players & Recorders
Just white screen with blue border
That normally happens because of the static electricity that builds up on the system board of your machine. This might be a result of sliding the laptop on the bed or carpet which make the static electricity to build up on the machine. Remove the battery, remove the power source, and remove any cd from the CD drive and hold down the power button for at least 2 minutes just to drain the static electricity out of your system
Feb 22, 2012 | HP Compaq FP 7317 17" Flat Panel LCD...
My speakers do not work on my system even though i hear static through them??
Static is audio, so the speakers are probably working. What source(s) produce the static (FM maybe)? Have you referred to the manuals for setup and are NOT mismatching speakers and amps?
Feb 28, 2011 | Philips HTS3151D/37 Theater System
A java code for anagram
public class AnagramApp {
static int size;
static int count;
static char[] charArray;
public static void main(String[] args) throws IOException {
String input = "Java Source and Support";
size = input.length();
count = 0;
charArray = new char[size];
for (int j = 0; j < size; j++)
charArray[j] = input.charAt(j);
public static void doAnagram(int newSize) {
int limit;
if (newSize == 1) // if too small, return;
// for each position,
for (int i = 0; i < newSize; i++) {
doAnagram(newSize - 1); // anagram remaining
if (newSize == 2) // if innermost,
rotate(newSize); // rotate word
// rotate left all chars from position to end
public static void rotate(int newSize) {
int i;
int position = size - newSize;
// save first letter
char temp = charArray[position];
//shift others left
for (i = position + 1; i < size; i++)
charArray[i - 1] = charArray[i];
//put first on right
charArray[i - 1] = temp;
public static void display() {
System.out.print(++count + " ");
for (int i = 0; i < size; i++)
Nov 22, 2010 | Computers & Internet
I hav Dlink 502T router and i got an static ip from mtnl now i want to access my printer using static ip Remotely
You will have to use remote desktop.
Please follow the instructions given in the below link.
Sep 08, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
You can use the netsh command to configure Ip adresses.
1. IP via DHCP:
netsh set address name="MyLocalAreaConnection" source=dhcp
2. static IP:
netsh set address name="MyLocal AreaConnection" source=static addr= mask= gateway=
- no line breaks in the commands
- change names and numbers to your needs
- check on mistyping and spaces between the commands
Feb 23, 2009 | Microsoft Windows Server Standard 2003 for...
TV will power up, however all it shows is static.
There is not enough information in this description to even start addressing a problem, there are so many things that can be at issue.
Jan 04, 2018 | JVC LT-40FH97 40 in. HDTV LCD Television
Unable to access Internet, WAN IP Address present
First you will need to open up your internet browser (Internet Explorer/Netscape) and go to You will be prompted for a username and password. By default there is no username and the password is admin. Once you arrive at the routers setup page click on the Advanced tab. Once the page finishes loading, you'll find you will be on the "Filters" tab. Look down and make sure that there are no numbers other than 0 in the boxes on that page. If there are, then you will need to replace them with 0's and click Apply, then Continue. Once you've done that, you're going to want to look for Dynamic Routing at the top, and then click on it. Once that page finishes loading, make sure that the "Working Mode" is set to Gateway, not ?Router?, and that tx and rx are set to Disable not RIP-1 or RIP-2. If a static IP address has been set on the computer, verify the gateways matches the Router's LAN IP Address. If there aren't any installed gateways, add the Router's LAN IP Address. When setting static IP Addresses, you must also input the DNS servers. For more information on assigning static IP addresses, please see the related article on assigning static IP addresses. If you?re still having difficulties, please contact Linksys Product Support.
Feb 16, 2006 | Linksys WRT55AG Router
Creative Labs Sound Blaster Audigy 2 Platinum Sound Card Logo
82 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
