Question about Sony STR-DE445 Receiver
Intermittant sound problem
The problem is the center channel will click out,sometimes all channels click out. when i slap the unit they will come back on. after some time,sometimes a long time they will click back off.
Please help.
Michael
  • 2,130 Answers
Slapping the unit causing the missing sound to come back tells me that there is something loose in the receiver. This could be a bad solder joint or dirty switch contact. Vibrations, such as sound, could be jarring the bad connection and causing the sound to cut out when it was just working a few seconds before. I don't believe you have a bad part in the receiver. When a solid state device fails, its gone for good. Again, it soulds like a bad connection. Finding a bad solder joint can sometimes be difficult. What you need to do is take the cover off so you can see the bottom of the PC board and using a good light source and magnifying glass, look for the bad connection. You can try running the receiver with the cover off and using a plastic pen, try pushing down on the PC board and see if you can make the sound cut out. You may be able to isolate the area by where you push on the board. Look for loose wires too. While you have the receiver open, buy some electrical contact cleaner in a spray. Radio Shack used to sell this as TV Tuner cleaner. I don't think they carry it anymore though. Spray the switches and rotate them back and forth several times. See if this resolves the problem. If you do find a bad solder joint, all you have to do is resolder it with some new solder. Make sure you do this with the power OFF. You're not looking at a big bill here. It's an easy fix once you find it.
Good Luck.
- Jim
Posted on Jan 28, 2008
Sony STR-DG710 center speaker makes no sound. Connections are good.
Sometimes these units have the ability to switch the speaker off and on. Look up the speaker settings in the manual.
As each channel in the unit will be separately driven the power amp for the center channel could have failed, but I think it's unlikely unless you have had problems with the sound on it before, or connected it wrongly causing a fault.
Dec 16, 2016 | Sony STR-DG710 Receiver
Why do I often get 'no signal' message on various channels in Samsung DV3 TV?
If the reception is intermittant, check all the external signal input connections; for firmness.
Jul 26, 2014 | Samsung Televison & Video
Preamp intermittent channel
Getting the connections right is a problem. One thing I find helps is the THX DVD discs that certain movies have on them. They have a sound set up to get it right. It makes a tone for each channel so you can hear which channel is working. It should help you set up the system right and determine if any channel has a fault on it.
Feb 08, 2014 | Adcom GTP-870HD 7.1-Channel Amplifier
Sound center
Replace center channel speaker with known good one. If no longer scratchy then the voice coil of removed unit is rubbing against the magnet pole and the speaker needs to be replaced. If the replacement speaker also sounds bad, then the amp for the center channel needs repair.
Nov 23, 2013 | Yamaha RX-V490 Receiver
I have a Sony STR-K502P home receiver. While watching a program the other day the center channel stopped working. Prior to that I had recently noticed a clicking noise like a relay switching off and...
It wouldn't be your output transistors. If they go bad they blow the fuse. Sounds like a speaker relay problem. Have you checked the solder connections on the relays? They sometimes break down. If that doesn't help, I would replace the relay. Center channel goes through RY501. Sony p/n: 1-755-170-11.
Apr 21, 2013 | Audio Players & Recorders
On any channel I've begun to get a intermittant
If this has a digital effects processor read on.., I had a SIMILAR problem on a Behringer GX110.
The electrolytic filter cap for the 5 volts of the DSP effects had gone bad. The 5 volts was dipping when the DSP reset and it would repeatedly reset causing a clicking at about once a second. 50 cent part fixed it. The part is a little undersized electrically so is more prone to failure in the unit I have.
That particular one had the DSP as a seperate board with its own 5 volt supply from the main transformer.
Dec 18, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Center channel drops once unit warms up
You don't have an external amlifuer, do you? You could hook the pre-amp out for the center channel to an external amp and connect the speaker to the amp. That way you could determine if it is the center channel output or the internal amp. Either way you probably need to get it serviced.
Best Regards,
-James
Aug 28, 2008 | Yamaha RX-V659 Receiver
AMPLIFIER CENTER CHANNEL NOT FUNCTIONING
Center channel will not work unless unit is set for Surround or Pro Logic. Make sure center channel's volume is up
Apr 28, 2008 | Yamaha DSP-A3090 7-Channel Amplifier
Channel cut out
Stereo Tech: Sounds like you definitly have a broken solder connection on the main PC board. A bad solder connection is tricky to find somtimes if one is not familiar with exactly what it looks like (kinda like mt st helens with a ring around the top) if you attempt this yourself DO NOT MAKE A SOLDER BRIDGE you will open pandoras box. Good luck
Jan 08, 2008 | Sony STR-DE697 Receiver
Rotel Amp center channel out
if you say you checked the wireing ,did you check the speaker. disconnect on of the other speakers and connect up the center to see if you get sound. still no sound speakers bad. Got sound try unpluging unit for a couple of hours then try it again. still no center . Time for the repair shop. Good Luck
May 26, 2006 | Rotel RMB-1095 Power Amplifier
Sony STR-DE445 Receiver Logo
189 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
