Ipod nano trouble
Everytime i disconnect the ipod nano 4g from my computer its doesn't turn on, only when its connected does it turn on, please help
Ipod
Posted on Sep 21, 2008
  • 97 Answers
Just keep on clicking it. hold the center button and menu button at same time. flick hold swith on and off
Posted on Jan 28, 2008
  • Eseosa Jun 17, 2011
    I forgot my unlock code for my screen,what can i do to reopen.
The unit is blocked does not come on it has been charged showed complete charge
Posted on Jun 20, 2008
  • adriana_pust Jun 20, 2008
    What is causing it? To block and not turn on?
Ipod 4G nano shows 0 songs when disconnected, but shows all data when connected t iTunes. Please help.
If you have all the music from the Ipod on your computer, I recommend you do a factory reset of the Nano. You could have a corrupted audio file that is messing everything up or your hard drive could be failing.
May 07, 2012 | Apple iPod nano
The problem is, i want to put music from my laptop onto my apple ipod 4GB a1051, how do i do that please?
The following information has come directly from the apple support web site.
Adding Content Automatically or Manually
There are two ways to add content to iPod nano: ? Automatic syncing: When you connect iPod nano to your computer, iPod nano is automatically updated to match the items in your iTunes library. You can sync all your songs, playlists, videos, and podcasts, or, if your entire iTunes library doesn’t fit on iPod nano, you can sync only selected items. You can sync iPod nano automatically with only one computer at a time. ? Manually managing iPod nano: When you connect iPod nano, you can drag items individually to iPod nano and delete them individually from iPod nano. You can add songs from more than one computer without erasing songs from iPod nano. When you manage music yourself, you must always eject iPod nano from iTunes before you disconnect it.
The following URL will bring you to the iPod Nano manual. For more information on setting up you iPod see chapter 2: Setting up iPod Nano
http://manuals.info.apple.com/en_US/iPod_nano_5th_gen_UserGuide.pdf
I hope that information above has helped is some way.
If possible please rate this solution.
Sep 02, 2010 | Apple iPod nano
Apple ipod 8G Model# A1285 Shows songs when connected to PC, but when I disconnect it show 0 songs. Please Help.
i have ipod modle A1285 when connect on computer all data show but when disconect for pc no show song video and much more why please sulution me
Feb 27, 2010 | Apple iPod nano
I cannot install music from my computor to my Ipod 4 nano
If you can't connect iPod nano to your computer , make sure;
  • you have installed the latest iTunes software from www.apple.com/ipod/start.
  • Try connecting to a different USB port on your computer. Note: A USB 2.0 port is recommended to connect iPod nano. USB 1.1 is significantly slower than USB 2.0. If you have a Windows PC that doesn’t have a USB 2.0 port, in some cases you can purchase and install a USB 2.0 card. For more information, go to www.apple.com/ipod.
  • iPod nano might need to be reset (see page 64).
  • If you’re connecting iPod nano to a portable or laptop computer using the iPod Dock Connector to USB 2.0 Cable, connect the computer to a power outlet before connecting iPod nano.
  • Make sure you have the required computer and software. See “If you want to double check the system requirements” on page 68.
  • Check the cable connections. Unplug the cable at both ends and make sure no foreign objects are in the USB ports. Then plug the cable back in securely. Make sure the connectors on the cables are oriented correctly. They can be inserted only one way.
  • Try restarting your computer.
Mar 11, 2009 | Apple iPod nano
Ipodnano8GB connection
you have to restart your iPod. press the middle/center button and the menu button for a few minutes
Jan 01, 2009 | Apple iPod nano
Need to reset password on ipod nano
Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using this method, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
Dec 05, 2008 | Apple iPod touch
Ipod nano
Apple iPod is Locked
There is only one way - and it will erase all your songs (applies to most models, not just Nano):
If you lock your iPod nano screen and can’t unlock it
Normally, if you can connect your iPod nano to the computer it is authorized to work with, your iPod nano automatically unlocks. If the computer authorized to work with your iPod nano is unavailable, you can connect iPod nano to another computer and use iPod Updater to restore your iPod software. See the next section for more information.
If you want to change the screen lock combination and you can’t remember the current combination, you must restore the iPod software, and then set a new combination.
Updating and Restoring iPod Software
You can use iPod Updater to update or restore your iPod software. Apple periodically
updates iPod software to improve performance or add features. It is recommended that
you update your iPod nano to use the latest software. You can also restore the software,
which puts iPod nano back in its original state.
- If you choose to update, the software is updated, but your settings and songs are not
affected.
- If you choose to restore, all data is erased from your iPod nano, including songs, files,
contacts, photos, calendar information, and any other data. All iPod nano settings are
restored to their original state.
To update or restore iPod nano with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software installation file and follow the onscreen instructions to install
the iPod update.
3 Connect iPod nano to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod software.
If you use the iPod Updater application and it doesn’t recognize that iPod nano is
connected to your computer, reset iPod nano (see page 45).
If you want to restore iPod software and you don’t have an Internet connection, you
can use the iPod Updater application that was installed on your computer when you
installed the software from the iPod CD.
-Tha Mp3 Doctor
Nov 10, 2008 | Apple iPod nano
Ipod nano 4G
Reset iPod nano
(if your iPod nano isn’t
responding)
Set the Hold switch to Hold and turn it off again. Press the Menu
and Center buttons at the same time for about 6 seconds, until the
Apple logo appears.
May 22, 2008 | Apple iPod nano
Ipod
If your iPod nano won’t turn on or respond
1) Make sure the Hold switch is off.
2) If that doesn’t work, connect iPod nano to your computer’s USB or FireWire port. Your
iPod nano battery might need to be recharged.
3) If that doesn’t work, your iPod nano might need to be reset.
a) Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
b)Press and hold the Center and Menu buttons for at least 6 seconds, until the Apple logo appears.
4) If that doesn’t work, you might need to restore iPod nano software.
Mar 12, 2008 | Apple iPod nano
 Grubhead
Grubhead
