Question about Watches
Watches not working
I have two fossil watches, pr5181 and a pr5183. Both are fairly new with one not ever worn, one just a few times. The worn one quit working, changed battery, still not working. Second one still had plastic sheet between bottom of battery and watch. Removed the plastic sheet and reinstalled battery, still not working. Is there something you have to push to get to reset?
  • 1 more comment
  • bobbyfries Apr 14, 2008
    how do you set the time on a Cartier Pasha
  • WickedRaven8 Apr 16, 2008
    Same issue here. Don't know what to do about it. It's a great watch. Never been worn and it's just not working.
SOURCE: Fossil watch
The watch has two batteries. underneath the large disk battery is a smaller button battery. replace the small button battery and your watch should start up again.
Posted on Apr 16, 2008
  • 2794 Answers
SOURCE: Need to open Fossil watch
Here is the customer care number for fossil:
They should be able to help you out.
Posted on Jun 17, 2008
SOURCE: Fossil ES1592
watch press
Posted on Jun 19, 2008
SOURCE: Set time on Fossil DQ1138 Watch
Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
Posted on Apr 04, 2009
  • 906 Answers
SOURCE: [url=
good day,
hope this link below will solve your problem.
Posted on Jul 30, 2010
Where can I buy genuine leather strap of my fossil watch and at the same time repair its glass..Is there fossil service center here in Quezon city Philippines
There is!
Fossil Saved to your Map View on Map Website Directions Boutique Chain retailer known for vintage-inspired watches, leather goods & more, along with modern designs. Address: North Avenue Corner Edsa, Quezon City, Philippines Phone:+63 2 924 2763
Fossil Philippines Service Center - AllServiceCenters.Com Displaying entire information about Fossil Philippines service center and customer ... Arcade, Ayala Center Ayala Avenue, Makati City, Metro Manila, Philippines. Missing: quezon
Warranty & Repairs - Fossil Rose Tone Watches ยท Stainless Steel Watches ... City & Courier Bags .... India; Indonesia; Macau; New Zealand; Philippines; Singapore; South Korea; Taiwan ... Missing: quezon
Jan 31, 2016 | Fossil Watches
Philippe starck with fossil ph-2006
Fossil Contact Information Main support number 1-800-842-8621
Email support
hope this helps
Mar 25, 2008 | Fossil Philippe Starck PH1026 Wrist Watch
Hello, where could I buy, Fossil CE1000 BAND repair parts?
Can't, new watch time or at least new band time
Oct 12, 2012 | Fossil CE1000 Watch
I haven't worn my fossil watch (FS 4337 model) for some time & decide to wear it & shook it, adjust it, & it dosn't work. Usually when I don't wear it for about 2 weeks, I shake it...
If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
May 31, 2011 | Fossil Brushed Brown Dial Chronograph...
How to get my fossil me3015 watch to work.
I couldn't find this particular model on their web site but the two ME30** watches shown are mechanical automatic types.
Assuming that yours is the same, then you should hold the watch level and swing it gently from side to side for a few minute (100 -200 times).
This will operate the automatic winding mechanism. When fully wound, these watches will generally run for 2-3 days (the Cartier web site does not specify how long the watch will run).
To keep it running it needs to be worn almost daily.
May 05, 2011 | Watches
Hi. my fossil automatic watch stopped working. any advice?
Have you left it off for a few days? If an automatic watch is not worn, it will stop after 2-3 days.
You can get it started again by gently swinging it from side to side for a few minutes. For continuous working it needs continuous wearing.
Oct 22, 2010 | Fossil Watches
Setting time on jr 9304
lendoris I cannot find your exact watch. But if you go to on the opening page click watches, at the bottom of the new page click on Customer care, on new page click on Watch instructions, its under Product information. types of watches can be viewed, choose one like yours and follow instructions
Nov 11, 2008 | Fossil Watches
Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Aug 08, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
Watches Logo
108 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
