Question about Mitsubishi WS-55857 55" Rear Projection Television
Mitsubishi WS-55857 55 Turns off
My rear projection TV turns off after 30 or so minutes. I have run a fan on the boards trying to cool it down, but it does not seem to take a difference. Any help?
Oh, I am not sure if its related, but the picture kinda pulses a little bit. I don't think there is a time correlation between when that happens and the TV turns off.
Thanks for any help,
~Eric
I have the same problem and it is costing me $300 to fix it. Not that big of a deal but a pain none-the-less. I'm sure we aren't the only ones that have found defects with this television set.
Posted on Feb 13, 2008
I have a Mitsubishi rear projection TV (WS-73909) that didn't turn on and had a green blinking light. I replaced the 7 DM capacitors and now it turns on. Both the remote and front control panel ca
Let me know as I can look for this---the set has a keyboard lockout that is cleared by holding the menu or another front button for more than 5-10 seconds with set on---I can find the service manual and check if needed.
Nov 04, 2012 | Mitsubishi WS-73909 73" Rear Projection...
Ws 65511 tv turns off by itself
This can be due to poor solder joints that develop over a period of time with constant heating and cooling thereby the solder becomes DRY and so non conductive. So if you can make a good observation and when the set starts up if the TV is tapped on the board then this is confirmed. Use a good soldering iron to carefully solder such dry solder joints, take precaution not to bridge the connection.
Secondly it can be due to heating up that thermally shut the circuit. If so use a good cooling when the fault occurs or if after the rear panel is removed and cooled by a fan the set tends to work more the fan can be either of these mentioned.
You can simulate and confirm by heating with a hair dryer.
Sep 30, 2011 | Mitsubishi WS-65511 65" Rear Projection...
TV turns itself off after about 5 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes. It started turning off...
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
May 04, 2011 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS 65809 65" Rear Projection TV. Turns
Hello There, Its seems that the circuit board has problems. You'll have to get it replaced ASAP before the board is ruined completely.
The same thing also happened to me 2-3 weeks ago. the techs came in and had to replace the board since 1 circuit was damaged.
It will cost around $100
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial}
Thank you for using FixYa!
I hope that I helped you & that this post is helpful to you at most!
Don't forget to rate! :)
Jan 16, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Powers on and off.. wont stay on
Check to see if all the fans are running. The fans are needed to cool the engine off while it is running. Double check the fan for the DMD board for this fan is a common problem.
Mar 23, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS 65513 turns itself off
Probable four bad caps in DM module = 1000mf/25v
Common repair for qualified Mits tech...........T.
Nov 11, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65869 65 in. Power Light
They are little green soldered in fuses located on the center board (the one with the STK's on it) toward the rear of the set near the large transformer.
Aug 24, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Open Questions:
Mitsubishi WS-55857 55" Rear Projection Television Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
