Question about Akai PDP4273M Television
Buttons on TV are unreponsive - Akai PDP4273M 42" Plasma HDTV
I have a Akai PDP4273M 42" Plasma HDTV that is a little more than a year old. I cannot turn it on/off, change the input sources or the volume. The remote is done. Someone in my house recently dropped it accidentally into a glass of cranberry juice. I washed it, wiped it & dried it, both inside and out and it seems a lost cause. Plus, none of the codes I searched for and found for my Comcast DVR remote work. I had been using the buttons on the TV, but they just stopped reponding. I can't get the TV to do anything, except turn on after unplugging it. Once on, I can't adjust the volume, switch the sources, or even turn it off. HELP!!!!! The volume is stuck all the way down. Does anyone have any ideas on why this has happened? Any ideas on how to fix it? Am I going to have to pay a fortune to get a TV repair guy to come and fix it? I am pretty sure the warranty is up and I cannot find the manual. AKAI's website is a joke, and offers no help or warranty/guide PDF.
  • 8 more comments
  • miadolphins Jan 28, 2008
    • Thanks for the info so far.
    • How about a comcast code that works? I have a HD DVR box. There are only 2 codes on comcast and neither works. Do you think that if I get the original remote or a universal that works, the TV should function fine. I can't get the buttons on the TV to work. It is stuck with the volume all the way down. And the volume display is staying on the screen, which is unusual. It is almost like the lower volume button is stuck, but it is not stuck in place.
    Nope. I've tried those 2 codes. They are unsuccessful.
    If I just get a new original remote? Do you think the TV should function fine? I can't get the buttons on the TV to work. It is stuck with the volume all the way down. And the volume display is staying on the screen, which is unusual. It is almost like the lower volume button is stuck, but it is not stuck in place.
    None of them worked. Do you think a new original remote will work with my TV? Even with the situation I described..the volume is stuck and the display on the screen?
    But my TV doen't have USB inputs.
    No, I do not think so.
    • Why do you think the buttons on the TV became unresponsive?
    • Are you sure the menu for the TV has a "return to factory settings" option?
    • Will the remote override the TV face buttons signal, if it is stuck inside monitor?
    • How reputable is that site for buying original remote? No fakes? Refurbed broken one?
    Okay. On the slight chance that this does not work, what then do you think I have to do?
    Last question...how long would that take to fix and how much would you estimate?
    okay, thanks.
    Genius:
  • 1,067 Answers
I can get u orginal remote
Posted on Jan 28, 2008
  • 20 more comments
  • nick helpap
    nick helpap Jan 28, 2008
    il find manel too give me a few
  • nick helpap
    also comcast remote ill try to find u codes but best remote is logitech one auto finds all ideams for u 99 bucks best buy
  • nick helpap
  • nick helpap
  • nick helpap
    DISPLAY
    (Show Metric Units)
    Screen Size
    42" Diagonal
    Resolution
    1024x1024
    Pixel Pitch
    Aspect Ratio
    16:9
    Contrast Ratio
    3000:1
    Brightness
    1400 cd/m2
    Displayable Colors
    16.7 million colors
    Viewing Angle
    160°
    Display Life
    Response Time
    Screen Filter
    COMPATIBILITY
    Color System
    Formats
    480p, 720p, 1080i
    INPUTS
    Component (HDTV) (2 sets)
    3 RCAs
    Back
    HDMI
    HDMI
    Back
    RGB
    15-Pin Dsub
    Back
    S-Video
    4-pin DIN
    Back
    Composite
    RCA
    Back
    GENERAL
    Bezel Color
    Black
    Power Supply
    120V - 120V
    Power Consumption
    300 Watts
    Standby Power
    Dimensions (W x H x D)
    (without stand or speakers)
    42.2" x 29.7" x 5.2"
    Weight
    75.0 lbs.
    FCC Class
    FCC Class B, Home Use
    Warranty
    1 year
    MSRP
    $1,699
    Production Status
    Out of Production
    Last Ship Date
    Nov 2007
    ADDITIONAL FEATURES
    3:2 Pull Down
    Yes
    V-Chip
    Yes
    Closed Captioning
    Yes
    Picture-In-Picture
    No
    these are the specks fo rthis model
  • nick helpap
    http://www.remotes.com/remotes/servlet/r...
    thats your orginal remote ther she is buy it now ok and mark me as fix ya
  • nick helpap
    no buy that orginal remote only for tv u can try logitech one that has input also u get 30 days to try it it has all the cosdes auto button point it at the devise u wnan program hit auto button it will pick itup for u logitech harmoney remote at best buy erther one perfect so u want comcast code sheet and user inst hold on dont forgetto vote me as fix ya ok
  • nick helpap
  • nick helpap
  • nick helpap
    Try 0098....
    0154, 0236, 0463, 0180, 0282, 0178, 0179, 0038, 0177, 0280....It might work try these
  • nick helpap
    nope i dont see any more codes look like comcast just cheap remote so getyouself that orginal one or this Logitech Harmony 676 universal remote or better ok sams club sells them too they have all remotes and u can update controler lol its way cool ther 300 doler one does lights in house touch screen
  • nick helpap
    0171 try this
  • nick helpap
    ya work when u get remote get in the menu and reset everting ok
    orginal one i would buy
  • nick helpap
    maby do firmware update also use usb thumb drive and web site get all latest fixes
  • nick helpap
    ok thats only on certain models they do that sum do sum dont is ther a serv port
  • nick helpap
    nope i looked inside best bet buy that remote get into menu and resetto factory all of it ok make sure well vented area also and plugede into a good monster cable power strip or good strip never direct in wall
  • nick helpap
    that site is very great best on web buddies bought tonns from them come brand new well packed within 3 days with 30 day warenty dont worry about that the remote will override buton on tv bad clikers behind them losse wire worn out bad signals infred port should do it tho most time it will get new remote get in menu again reset the tv
  • nick helpap
    yes your tv has factory sreset ok all tvs do plmasa factory defult in main master menus
  • nick helpap
  • nick helpap
    will haveto get a control model for front will have to go in shop thats hwy bestto do all this before u try doing that ok if dont work get back with me ill help u more later on ok thx agian
  • nick helpap
  • nick helpap
    1 week and i would say 300 bucks
Akai PDP4273M cant find where to put in cable cord to the back of the tv
Your right there is no aerial connection to your tv I think that you should provide a cable converter with audio video out that is the only solution i think. Good day and best regards.
Jul 29, 2011 | Akai PDP-4216M 42 in. Plasma Television
We have 42" plasma akai
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Jan 31, 2011 | Akai LCT2715 27 in. LCD Television
No picture anymore
I found one of these at the dump with the same issue. Bought a Z sustain board for $75 , replaced it and it works great. I plan on installing some PC style cooling fans in the cabinet as heat is what destroys these sets
Sep 08, 2009 | Akai PDP4273M Television
Getting Akai model PDP4273M plasma to accept a new remote
Hold The Clear Tv buttom until all 4 light flash red , then press code search at the bottom right , then the up arrow until ur tv goes off and finally record , after that u only need to press the red tv buttom to open it or close , If it doesnt open it back its because u press the up arrow after the tv was shut off so do the same thing be using the down arrow .
Mar 19, 2009 | Akai PDP4273M Television
Akai TV repeatedly turns off and on
Yeah. I had the same problem. About 1 month ago my AKAI PDP4273M1 TV began turning off...then on. I happened to stumble on a temporary solution. I held one of the buttons down on the t.v. without letting go...and what do you know....the tv stayed on. So I rigged it to where the button (the "source" button) stayed in and I stuck a small object into the hole next to it (a small nail in my case). The catch is you have to use the remote becase none of the buttons on the tv work. Wonderful...so...I got that fixed and then today my picture gave out about 75 percent. What a Piece of S%#* TV. That is all I can say. My 2 1/2 year old TV is a POS and is going into the dump. Can you say hello to a new VIZIO. Hope that helps. Remember. NEVER BUY AKAI TV PRODUCTS AGAIN!!!!!
Jan 19, 2009 | Akai PDP4273M Television
I have some issues with my akai hdmi model pdp4273m
You can download the manual from the akai website:
http://www.akaiusa.com/
I just did a search on "pdp4273m" at the akai website.
http://www.akaiusa.com/products_detail_features.aspx?cat=VISUAL%20ENTERTAINMENT&subcat=Plasma%20TV/Monitor&productno=PDP4273M
The manual is easy to download from there product page about the plasma.
The manual is a PDF, so I hope you have something like adobe acrobat to read the file.
http://www.adobe.com/
Feb 10, 2008 | Televison & Video
Akai tv remotes
I purchased a HARMONY remote ( logitech ) and it worked for the AKAI PDP4273M .
Jan 06, 2008 | Televison & Video
AKAI PDP4273M Plasma tinted red
TRY THIS BY USING YOUR REMOTE 1-PRESS BRIGHTNESS 2-PRESS FREEZE 3-PRESS MENU 4-PRESS ENTER THIS WILL TAKE YOUR TV BACK TO FACTORY PRESETS. I WENT 3 MONTHS WITH NO TV BEFORE I FOUND THIS OUT.
Sep 06, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Blue Vertical Line- Akai PDP4298ED
I have an Akai PDP4273M that developed the same problem. Checking around some of the av forums, I found a couple of threads that indicated it could be dust or bad contact around the ribbon cable connections on the video control board. I removed the back, loosened the ribbon cables on the board and used my small compressor with an air gun to blow out the dust all around the board and the ribbon connectors. Reconnected everything, turned on tv and stripe did not come back. Problem fixed! Nice and cheap solution.
May 28, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
229 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
