Question about Frigidaire PLMV169DC Microwave Oven
Night Light Microwave works fine, except when i try to turn off the worklight/nightlight it will not go off unless i push very hard on the keypad, or by taking the control pad out and then pressing the key pad.
  • 43 Answers
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Posted on Jan 28, 2008
LG microwave LMVM2075ST panel started acting crazy after I cleaned it. Will not do anything if I push a button except beeping noises. Any suggestions as to what is going on with this machine? Should I try...
liquid probably has entered keypad laminate; causing a short. unplug unit, direct warm hairdryer to entire keypad; plug back in; and hope for the best. if no luck; replace keypad. also never spray anything directly onto keypad; always clean with a moistened towel with light force.
Sep 07, 2009 | LG LMVM2075 Microwave Oven
Microwave PLMVZ169 GCB night light push button does not work. Replace the light bulb. Push button still does not work. The work light does when I push the night light it stays on. Just wondering how to...
Q - While trying to change the light bulb on the oven, the bulb broke. When it did, it threw the circuit breaker and the whole oven went out. After resetting the breaker, everything on the oven works except there is no power to either light socket. Any ideas or suggestions on what to replace?
A - You tried to change the light bulbs with the power still on.....tsk tsk!!
Hate to say this....but probably blew out part of the circuit on the smart board ( the brains behind the key panel you touch ) when the short blew. The light relay on the smart board may have been damaged but 9 out of 10 times when I check them, the board itself is damaged.
check out this problem.
please do rate the solution.thank you for using fixya.keep updated.thanks,
May 03, 2009 | Microwave Ovens
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
Night lights do not work
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa:
Feb 02, 2008 | GE JVM1660 Microwave Oven
MMV5000BAW maytag over-the-range microwave
Found this in the GE section instead of Maytag, but we're happy to answer it anyway.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doen't fix it.
If not, you may have a shorted keypad or bad control panel, either of which we can repair economically.
Please write back with more details if you need further help.
Nov 25, 2007 | GE JVM1870 Microwave Oven
Doesn't heat anything anymore...
check highvoltage section and diodes and finally replace magnetron...
Oct 13, 2007 | Sharp R-1500 Microwave Oven
This is a problem with the control panel assembly, which we repair nationwide for $39.95. This is most often caused by the filaments shorting when the bulb blows, or by not disconnecting the microwave from the power line when removing or installing a bulb. Full information on our service is available at our site, which is linked at our listing here on FixYa:
Aug 09, 2007 | GE JVM3660 Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
216 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
